It’s TOYOTA Tuesday
Discussion in 'General 4Runner Talk' started by djwantke, Sep 30, 2025.
  1. Oct 7, 2025 at 10:05 AM
    Toyota has been making sewing machines since the mid-‘40s. Legend holds that the Toyota logo, with its intersecting ovals, is a representation of the motion of sewing machine needle and a rotary hook.
  2. Oct 7, 2025 at 11:19 AM
    This I did not know. Chalked up to my new thing learned today.
    djwantke[OP] likes this.
  3. Oct 7, 2025 at 11:57 AM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    TOYOTA Tuesday, Week #2
    A second favorite photo of my first and only Toyota.
    Gman2530, BS67 and Steely123 like this.
  4. Oct 7, 2025 at 12:14 PM
    You thought Toyota only makes vehicles?
    LCJ77 likes this.
  5. Oct 7, 2025 at 12:52 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
  6. Oct 7, 2025 at 4:45 PM
    The night and next day after clicking 5100’s up from 0” to 0.85”.
    Gman2530 likes this.
  7. Oct 7, 2025 at 4:46 PM
    Rad truck
    Ontario?
    4onto[QUOTED] likes this.
  8. Oct 7, 2025 at 6:33 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Yep. Born and raised. Next April, I'll have had it for 30 years.
    djwantke[QUOTED][OP] likes this.
  9. Oct 7, 2025 at 7:24 PM
    Finally got the trash picked up and the suv aired out after changing the garbage cans at the park. I think I caught Typhoid or tburchulosus. Covid test came back negative, must be a new strain.
  10. Oct 11, 2025 at 1:10 PM
    That’s very cool
  11. Oct 11, 2025 at 1:25 PM
    it’s Sideview Saturday. show off your sideview & sidewalls:
  12. Oct 11, 2025 at 1:36 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
  13. Oct 11, 2025 at 6:33 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
  14. Oct 14, 2025 at 3:50 PM
    just got off work.
    T.T. Week #3:
    Photon_Chaser, 2Toys and BS67 like this.
  15. Oct 14, 2025 at 4:42 PM
  16. Oct 14, 2025 at 4:48 PM
    Since these are Thailand made vehicles they are relatively affordable in south Asia.
  17. Oct 14, 2025 at 4:55 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Not really!
    A middle trim level will run about 55k USD out the door when converted.
    Extremely expensive considering it sits slightly below the 4runner.
  18. Oct 14, 2025 at 5:20 PM
    In Sri Lanka (South Asia). There's ton of Prados but not much market for Fortuners.
  19. Oct 14, 2025 at 6:19 PM
    #49
  20. Oct 14, 2025 at 6:23 PM
    #50
    Yep, they really have a 2 door version.
  21. Oct 14, 2025 at 6:30 PM
    #51
    ^Looks like Toyota had to put the fuel tank behind the rear axle (where the spare tire is on a GX460). If Toyota tried this in the US, they'd be sued into oblivion within 24 hours:
    They look absolutely hilarious when lifted on 35s:
    Steely123 and djwantke[OP] like this.
  22. Oct 14, 2025 at 7:12 PM
    #52
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    I had this '18 2WD SR for two years. It was a nice, basic truck, but man, even with no t-case or front axle and 4.30 gears, that 2.7L was slow. And the base six-speaker sound system was really bad.
    Steely123 likes this.
  23. Oct 14, 2025 at 7:21 PM
    #53
    They have 2 tanks. That's the auxiliary tank. Main tank is the same location as 4Runners and GX have.
  24. Oct 14, 2025 at 8:48 PM
    #54
  25. Oct 14, 2025 at 9:09 PM
    #55
    I don't know about the short wheel base 2 door one. The 4 door ones have 2 fuel tanks 80something and 60something with a total of 150 liters. Too lazy to google exact numbers at 10pm in the night. LoL.
  26. Oct 15, 2025 at 3:56 AM
    #56
    LOL, i literally had to look like 3 times to make sure this wasn't a RC truck.
    2Toys likes this.
  27. Oct 16, 2025 at 12:29 PM
    #57
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    You don't have to go that far, or rather in the other direction ;-)
    Here in Europe, Toyota only officially offers the Landcruiser (Prado), RAV 4, and the Hilux pickup in this category.
    The Landcruiser is also often seen here in the short 2-door version.
    We just don't have that much space on the roads and in parking lots.
    Sequoia, 4Runner, Tundra, and Tacoma are very exotic here and only available as individual imports.
    Toyota SUV market Switzerland: https://www.autoscout24.ch/de/s/mo-land-cruiser/mk-toyota
    Here's another one in a funny format:
    4onto, Lc200 and kmeeg[QUOTED] like this.
  28. Oct 16, 2025 at 8:18 PM
    #58
    Curlystooge
    Curlystooge Member
    Flyover
    2022 limited in magnetic grey
  29. Oct 16, 2025 at 10:11 PM
    #59
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Absolutely nothing wrong with that. I would really like a base model four-door Prado with silver steel wheels, cloth seats and the turbo diesel engine.
  30. Oct 21, 2025 at 11:52 AM
    #60
    It’s TOYOTA Tuesday. Workin 12 floors above the 4R
    2Toys likes this.
