It’s TOYOTA Tuesday
Discussion in 'General 4Runner Talk' started by djwantke, Sep 30, 2025.
  1. Sep 30, 2025 at 11:23 AM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    It’s TOYOTA Tuesday, drop down a favorite pic of any of your Toyota’s
  2. Sep 30, 2025 at 11:43 AM
    Pentangler
    Pentangler Happy Member
    Present & past
  3. Sep 30, 2025 at 2:06 PM
    Wife and daughters
    Wife and my truck
    Something I’ve been eyeballing for quite some time. Wanting to buy. Don’t need it. Wouldn’t use it. But hate to see it rot away.
    brownersd, 2ndGen22re, BS67 and 2 others like this.
  4. Sep 30, 2025 at 2:44 PM
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
  5. Sep 30, 2025 at 3:15 PM
    Borracho Loco New Member
  6. Sep 30, 2025 at 3:21 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    I need to get out & get some good fall pictures!
    brownersd, Photon_Chaser and BS67 like this.
  7. Sep 30, 2025 at 3:28 PM
    I need to find a pic of my friend’s ’89 Supra Turbo. :cool:
    Goodness, what a screamer!
  8. Sep 30, 2025 at 7:39 PM
    Oh man, someone on my fb just posted their 3rd Gen for Tooshie Tuesday.
    Wow
    brownersd, Steely123 and BS67 like this.
  9. Sep 30, 2025 at 8:00 PM
    that ole girl is CLEAN
    djwantke[QUOTED][OP] likes this.
  10. Sep 30, 2025 at 9:25 PM
    Photon_Chaser 65,322 smiles and counting…
    West Coast!
  11. Oct 1, 2025 at 10:08 AM
  12. Oct 1, 2025 at 1:22 PM
    I want that camper.
  13. Oct 1, 2025 at 6:27 PM
    It’s a 92 or 93 Dolphin, there are a few different models. I cant pick out what model it is because the generator is in a different spot than pretty much every other pic online. Most all have the generator in front of the rear tire, this one is behind the rear tire. I dont know if it runs, or what it looks like, i spotted it driving back roads a few months ago. Its still there today. I looked up who owned the property and they are out of town. I've thought about writing them a letter.
    Jennyjo14 likes this.
  14. Oct 1, 2025 at 6:28 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    ratcoon likes this.
  15. Oct 1, 2025 at 6:45 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    I know it is a niva
  16. Oct 5, 2025 at 12:41 PM
    22 ORP
  17. Oct 5, 2025 at 9:12 PM
    3JOH22A トヨタ純正ジゴロ
    5G 4R & 3G Taco w/ SCREENS
    SCREENS & Gimmicks
  18. Oct 5, 2025 at 9:46 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    2009 Toyota Fortuner MT 4x4. Came with a 3lt turbo Diesel. Made a modest 165bhp but had waves of torque right from 1200rpm. Like any diesel, no point hammering the pedal, quick shifts and keeping it within the power band was the key.
    This is the South Asian cousin of the 4runner and in some markets actually comes with the same 4Lt. NA petrol. Ofcourse over the years it has been updated.
    I still prefer driving a manual compared to an auto though.
    4onto and BS67 like this.
  19. Oct 6, 2025 at 4:58 PM
    Interesting! Thanks for sharing dis.
    Right hand drive has gotta be a trip.
    Believe it or not I’ve only owned three vehicles my adult life, the first two were manual transmission no power doors no power locks no AC. My 2016 trail premium runner is what I consider luxury! 2020+ is too much tech and luxury for me lol
  20. Oct 6, 2025 at 6:00 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
  21. Oct 6, 2025 at 6:42 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I loved this car. Mine had about 220kms ( 137k miles) before I sold it.
    It had all the creature comforts, a very frugal diesel and Toyota realibility. Was often tastefully modified.
    BS67 likes this.
  22. Oct 6, 2025 at 6:54 PM
    You owned the grey one?
  23. Oct 6, 2025 at 6:55 PM
    Is this a toyota? Lol!
    Don’t make me enforce thread rules people :laugh:
  24. Oct 6, 2025 at 6:59 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Not this particular one but Yes, same color, trim and year. It was more than a decade ago.
  25. Oct 6, 2025 at 7:42 PM
    Oh nice ya hear you
    Man 10 years ago I was a single bachelor HAHA
  26. Oct 6, 2025 at 8:09 PM
    3JOH22A トヨタ純正ジゴロ
    SCREENS & Gimmicks
    kolter45 and brownersd like this.
  27. Oct 6, 2025 at 9:47 PM
    brownersd likes this.
  28. Oct 7, 2025 at 3:36 AM
    kolter45 likes this.
  29. Oct 7, 2025 at 7:08 AM
    Bagman
    Georgia
    Not mine, but had one just like it. No cellphones back in the day for pics...
  30. Oct 7, 2025 at 8:41 AM
    Toyota made boats, fork lifts, and engines for airplanes.
    In the 1990s, Toyota also developed the FV2400-2TC, a twin-turbocharged, twin-plug aircraft engine based on its UZ V8 car engine
    The FV2400-2TC Aircraft Engine
    • Engine Basis: This engine was a twin-turbocharged, twin-plug version of Toyota's 1UZ-FE V8 car engine.
    • Production Certification: In 1997, the U.S. Federal Aviation Administration (FAA) granted production certification for the FV2400-2TC, making it the first car-derived engine to achieve this milestone for use in aircraft.
