Issues with acceleration
Discussion in '2nd Gen 4Runners (1990-1995)' started by Goose14, Dec 4, 2023.
  1. Dec 4, 2023 at 10:36 AM
    Goose14
    Goose14 [OP] New Member
    Molly
    '95 Gold 4Runner
    Does anyone have any ideas on what might be causing my '95 4runner(automatic) to have trouble shifting from first to second gear? My rpms go crazy even if I'm just trying to get up to 20mph from a stop. I did just replace the MAF and the fuel injectors and before that I'd never had this problem. The only issue was a code 25 which we got to go away. Let me know if you need more info to help, thanks!
  2. Dec 4, 2023 at 11:42 AM
    Define "RPMs go crazy". Like the engine revs out before it shifts into first?
    To me it sounds like the transmission is slipping. Pray it's just low on fluid. I would check that.
  3. Dec 4, 2023 at 4:08 PM
    Goose14
    Molly
    '95 Gold 4Runner
    Yes the engine revs out before it shifts. Okay I'll check that out. Thank you!
  4. Dec 5, 2023 at 9:28 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Mine did that many years ago. Turned out to be a sensor. Sorry that I do not remember which sensor it was. Check and see if it is throwing any new codes.
  5. Dec 7, 2023 at 10:13 AM
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    A340h (4wd) transmission right? If so its probably a shift solenoid. Its a well known problem on those transmissions. Fairly easy fix. Drop the pan and replace the solenoid, should shift fine again. General rule of thumb though is while you're in there change the trans filter and the other solenoids as they are probably on their way out too. Doesn't sound like a trans slipping problem to me
    AppalachianPatriot likes this.
  6. Apr 28, 2024 at 6:03 PM
    getaway88
    getaway88 New Member
    Marcus
    RENO NV
    '95 4runner 3VZE (3.slow)
    4" lift K&N filter
    Got the same project going and I'm under there now to change the filter and solenoids but I can't seem to get the dang filter out. Anybody got any suggestions? Got dam near the same specs; 95, 4x4, automatic, a340h.
