Is this engine sound abnormal?
Discussion in '5th Gen 4Runners (2010-2024)' started by danielmiao, Sep 22, 2023.
  1. Sep 22, 2023 at 10:02 PM
    danielmiao
    danielmiao [OP] New Member
  2. Sep 22, 2023 at 10:18 PM
    Foothills
    Foothills New Member
    Sounds similar to our engine with 137k miles.
  3. Sep 22, 2023 at 10:23 PM
    danielmiao
    is it normal for this 1GR-FE engine with only 900 miles?
    I'm new to both 4Runner and this engine, thanks
  4. Sep 22, 2023 at 10:35 PM
    All normal. This engine is not quiet.
    mrmike7189 and TrailSpecial22 like this.
  5. Sep 22, 2023 at 10:38 PM
    Foothills
    Yes your recording is the normal 1GR-FE engine sound, others will weigh in to confirm.
  6. Sep 22, 2023 at 11:07 PM
    Steve Berman
    Steve Berman New Member
    Sounds fine to me.
    Most reciprocating noises to worry about will be evident when you first start the car, or when applying load
    RUNNER4DAN likes this.
  7. Sep 23, 2023 at 5:38 AM
    Sailormilan2
    Sailormilan2 New Member
    Dale
    2020 4Runner TRD Premium
    At the risk of getting flamed for starting a new "oil thread", there are reports from both Tacoma 4.0L V6 and 4Runner 4.0L V6 owners that the engine seems quieter after going to a heavier weight oil. It may work for you, and it may not.
    Rocko9999 and jgalt like this.
  8. Sep 23, 2023 at 5:55 AM
    7Runner
    7Runner Forum Loiterer
    2018 Silver SR5P
    Normal for a 5th gen 4Runner.
  9. Sep 23, 2023 at 7:52 AM
    ipnpulz
    ipnpulz New Member
    2023 TRDOR premium T4R
    Sounds better than some ...
  10. Sep 23, 2023 at 8:03 AM
    TRD Ted
    TRD Ted New Member
    Four years in a 3rd gen Tacoma and two months in a 5th gen 4Runner I’d be more afraid if these engines didn’t sound like they are going to blow up….
    Trail Runnah likes this.
  11. Sep 23, 2023 at 8:13 AM
    For months I was convinced my engine was broken and about to blow. That was about 80k miles ago, I just hit 160k, and still runs great getting 21 mpg.
    Apparently sounding like it's about to shoot a valve spring through the hood is a Toyota thing.
    MooreKen, danielmiao[OP] and 5thToy like this.
  12. Sep 23, 2023 at 9:02 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Yeah, I went through the same thought process listening from the same location from the perspective of fifteen years prior with 2 4.7 L V8 Toyotas which were smooth as silk. The 4.0 V6 is a noisy motor.
  13. Feb 23, 2024 at 4:29 AM
    Nx95240
    Nx95240 New Member
    Brian
    Cleveland Tennessee
    2021 4runner TRD
    3"lift from toyota... Jlw6 10" sub.. Ceramic tint..275/70/17 atw4...more to come
    Well I just bought a 2021 runner OR and this is what iam hearing alos. I have a 2011 tacom OR until I got this runner.
  14. Feb 23, 2024 at 5:24 AM
    Sprouty115
    Sprouty115 New Member
    2018 4Runner
    If you want to hear mechincal clatter find any mid-70's BMW or Moto Guzzi motorcycle and listen to them while they are running and you'll think your V6 is an S-Class Mercedes.
  15. Feb 23, 2024 at 5:37 AM
    Nick4RNR
    Nick4RNR New Member
    sounds just like mine.
    Rocko9999 likes this.
  16. Feb 23, 2024 at 10:58 AM
    Ryan99Z28
    Ryan99Z28 New Member
    Ryan
    Matthews, NC
    2023 4Runner Off Road Premium
    Sounds like my 23.
  17. Feb 23, 2024 at 11:42 AM
    JS222STL
    JS222STL New Member
    2020 SR5 premium
    Sounds like my 2020. First time I heard it in the cold I thought I bought a diesel.:eek: She purrs like an old sewing machine.
  18. Feb 23, 2024 at 4:29 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    mrmike7189 and JS222STL like this.
  19. Feb 23, 2024 at 5:37 PM
    ATL4R
    ATL4R New Member
    2024 Limited
    Sounds like my ‘24. I think it’s even more profound while sitting in the driver’s seat. It’s almost like a diesel engine sound.
    Yotaholic likes this.
  20. Feb 23, 2024 at 6:15 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
  21. Feb 23, 2024 at 6:17 PM
    Yotaholic
    Olympia, WA
    Wait when you fire it and the temperarure is 10 degrees outside lol. All normal, the thing sounds like a diesel
    Tama1968 and CreekRunner like this.
  22. Feb 23, 2024 at 6:35 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Put a mic against an engine it would be pretty loud no?
  23. Feb 24, 2024 at 5:33 AM
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    This is one of the first things I asked on here too when I brought home my Runner. Nobody prepared me for this noisy engine lol
    Yotaholic and CreekRunner like this.
  24. Feb 24, 2024 at 8:54 AM
    CreekRunner
    CreekRunner New Member
    2013 4runner
    I bought a used 2013 3 weeks ago and almost called the dealership and told them they sold me a 4runner with a bad motor. The first morning I started it to go to work it was idling at 1200rpm and sounded very strange. It didn't sound like that at the dealership but I'm guessing it's because they already had it warmed up for my test drive. I was so relived after jumping on youtube and investigating a bit.
  25. Feb 24, 2024 at 8:58 AM
    CreekRunner
    2013 4runner
    The level of panic I went through the first morning I had my 2013 because of this scenario. It was 20 out and man I thought that thing was toast. Almost called the dealership but YouTube saved the embarrassment.
  26. Feb 24, 2024 at 2:55 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Modern engines are designed with short skirt pistons that will tend to "slap" the cylinder walls until they reach operating temperature and thus reduce the clearance. Even at operating temperature they may still make a bit of noise compared to older engine designs with longer skirt designs. At RPMs above idle the pistons will no longer rock in the bores. It is nothing to be concerned about.
  27. Feb 24, 2024 at 5:38 PM
    Tama1968
    Tama1968 New Member
    Florida
    sounds just like my 2019 / 84k miles
