Is it the head gasket? 2005 V6
Discussion in '4th Gen 4Runners (2003-2009)' started by weydagizi, Sep 11, 2021.
  1. Sep 11, 2021 at 12:09 PM
    weydagizi
    weydagizi [OP] New Member
    Hi all,
    I have a 2005 V6 with 208k miles on it. A few weeks ago the CEL light came on together with the VS track and VSC. I thought it's the gas cap issue, so I did the "reset" (turned the cap until it clicked once, disconnected the battery for 5 min). Lights went off, but then a few days ago they came back again, then yesterday they went off now it's on again. I also noticed that a little coolant disappeared from the coolant tank (about 1 finger in 600 miles of driving). Today I had the codes read and it gave me P0306 Cylinder 6 misfire. Also, I have a rough idle for not more than 5 seconds, but not every time, only sometimes. Otherwise the car drives great, no overheating, no smoke, oil looks clean, coolant looks clean. Is it the head gasket or I have hopes that it's something less expensive, such as water pump and the intermittent rough idling is actually spark plugs and coils? One can only dream...
    Thanks!
  2. Sep 12, 2021 at 9:19 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    There is a chance that your gas cap is bad and not sealing properly. My Corolla had the same lights and after I replaced the cap, the lights never came back on. It read a bunch of codes but it was the cap after all. Try that first. It is the cheapest fix. If it happens again then go for the plugs and wires. From what I understand, the best sign of the head gasket going is white substance in the coolant. Good luck.
  3. Sep 12, 2021 at 9:56 AM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    My guess is you have two separate issues going on.. one is the gas cap, the other is the missing coolant. Being that you have a 2005, my thoughts go to head gasket. You can try to do basic things to try and help the bad idle, but spark plugs and coils don't make coolant disappear.. if you can't find any other leaks, it's got to be going somewhere, most likely into cylinder 6 and out your tail pipe. Check your weep hole, bottom corners of the radiator, all your hose connections, overflow tank connection, etc. Definitely do the due diligence to rule out other things, since it sounds like it's a small amount going missing for now and you probably have time before it gets worse, if it is actually a head gasket.
  4. Sep 14, 2021 at 9:30 AM
    Toy Yoda
    Toy Yoda New Member
    A whole finger worth is not a small amount of coolant loss, you should be able to easily see if the rad or other places are leaking, if not wet it will be a pink crusty residue.
    Gas cap will send a specific code for emissions evap, it wont or at least shouldn't trigger a misfire code in a cylinder. When you unplugged the battery that cleared the codes but then they came back, most likely not gas cap related.
    Being a 2005 chances are it's a head gasket, there are testers that can determine if there is combustion gas in the coolant, it wont always cause milky oil or white substance in coolant.
    Best of luck finding what it is but if it is a head gasket dont go to a dealership for repair, a competent shop or mechanic can do the same work for far less $$.
  5. Sep 27, 2021 at 8:35 PM
    Letsflyman
    Letsflyman New Member
    96 Tacoma 400k running strong
    I'm finally admitting defeat and having the gaskets done on my 05. Last thing I want or need is a blown motor. I'm also getting the heads completely rebuilt and installing a brand new oem chain....and everything timing chain related. Guides, sprockets, tensioners etc and the water pump, even though it's relatively newish.
    And this coming from a guy who believes in the old adage, don't fix it if it ain't broke.
  6. Sep 28, 2021 at 5:29 AM
    Toyofan87
    Toyofan87 New Member
    Seth
    Blue & Grey Hwy Gburg
    1987 Toyota 4Runner SR5
    Official welcome
    Letsflyman likes this.
  7. Sep 29, 2021 at 4:31 PM
    Yinzer
    Yinzer New Member
    2005 4Runner
    How much all that gonna cost ya ?
  8. Sep 29, 2021 at 4:57 PM
    Letsflyman
    1k labor.
    825 for all oem timing chains and parts, including a new Aisin water pump.
    100 bucks for the revised head gaskets from Toyota.
    About 250 for the Felpro gasket set. Just not using their head gaskets.
    350 to go through and rebuild both cylinder heads.
    45 bucks for new head bolts.
    So about 2700.
    It helped a lot that I started buying all the parts a couple months back. But keep in mind that I could prob have saved money by reusing the timing chain. Wasn't too much wear when mechanic checked it out, but I just wanted all new stuff in there. I do a lot of driving for pleasure. Better safe than sorry.
    Yinzer[QUOTED] and spencermarkd like this.
  9. Oct 3, 2021 at 10:34 PM
    For future reference. Pull the spark plug. They usually tell the story of why the misfire happened.
    I hope you aren't going to be too mad when it happens again after all that work.
    The Mechanic, a good one, should still take a quick look to determine what the root cause is and rule out common culprits like a bad coil pack or plug or wires or injector....or he's liable to be looking at an angry owner.
  10. Oct 3, 2021 at 10:48 PM
    Letsflyman
    But my coolant gets lower, plugs and coils brand new, exhaust in the coolant, and the occasional misfire codes p0304. Pretty sure it's a head gasket.
    Thx tho.
    importman likes this.
  11. Oct 3, 2021 at 10:51 PM
    You confirmed exhaust in the coolant?
    I don't see that in this thread. I must be blind.
  12. Oct 3, 2021 at 10:59 PM
    Letsflyman
    You aren't blind. I posted that in another thread. I was just in here replying to another post. You know, trying to add quality content...maybe commiserate a bit.
