Is it okay to ditch the factory engine skid plate if I don't off road?
Discussion in '5th Gen 4Runners (2010-2024)' started by Loco x Toyota, Apr 29, 2022.
  1. Apr 29, 2022 at 11:59 AM
    Loco x Toyota
    Loco x Toyota [OP] New Member
    Cedar Park, TX
    TRD Pro Solar Octane
    Does anyone know if the factory engine skid plate serves any structural or other important role?
    I don't plan on off roading at all, so any problem if I just remove it? Thanks
  2. Apr 29, 2022 at 12:01 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Why would you want to remove it?
    grizzlypath and Toy4X4 like this.
  3. Apr 29, 2022 at 12:10 PM
    There's plenty on the road that can jump up and hit your oil pan. A Heep in front of me lost the fancy hitch cover that said, "Remove For Recovery" or whatever, went under my truck and made a nice clank against the Pelfrey skid I had on my Tacoma.
  4. Apr 29, 2022 at 12:24 PM
    Loco x Toyota
    Cedar Park, TX
    I want to do the spin-on oil filter conversion, and looks like the conversion will add length compared to the OEM cartridge filter and will not clear factory engine skid plate.
  5. Apr 29, 2022 at 12:26 PM
    Loco x Toyota
    Cedar Park, TX
    that's a good point, maybe I should just fork out another $400 for RCI skid even if I don't offroad but to prevent road hazard.
    The TRD Pro skid looks like a PITA every time needs removal for oil change
  6. Apr 29, 2022 at 12:27 PM
    My only concern would be the oil filter. If you went with the aluminum conversion, then probably ok.
    If an aftermarket spin on sits a lot lower than that would concern me too.
    LandCruiser likes this.
  7. Apr 29, 2022 at 12:27 PM
    I believe people use the spin on conversion with the stock skid. Personally I don't see a need for the conversion but that's me.
    Toy4X4 likes this.
  8. Apr 29, 2022 at 12:54 PM
    Loco x Toyota
    Cedar Park, TX
    yeah, aftermarket ones come with a door panel that can be removed for oil filter access, worst case I'll just leave it open
  9. Apr 29, 2022 at 12:57 PM
    Loco x Toyota
    Cedar Park, TX
    baxter adapter says it won't clear factory skid on their website
    I agree, there's never a need for the conversion, but just less mess and fewer procedures. I use fumoto style drain plug, and if I use spin-on filter, I can crack it loose and spin it off to a zip lock bag not a single drop on the floor
    MeefZah likes this.
  10. Apr 29, 2022 at 1:08 PM
    I use a Motivx drain tool for the housing. No mess.
    Thatbassguy and 7385 like this.
  11. Apr 29, 2022 at 1:40 PM
    afret
    North Idaho
    As for the OP's question, I don't think it's a problem to go without the skid. I'm leaving it on but will take it off if/when I drive the 30 miles to the dealer and back.
  12. Apr 29, 2022 at 3:35 PM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    The biggest dent I got in my factory skids was a helmet I ran over on the highway. Was trapped in the lane and it rolled over after someone else hit it…left some nasty marks and a huge dent in my gas tank factory skid. It was worse that the damage to my trd skid.
    the biggest hit I took off-road was a rock….I am also pretty sure I bent the radiator support bracket I bit the front of the trd skid into with that one…still works, no cross threading, just a little stiff to tighten.
    moral of the story…skids can be used anywhere.
  13. Apr 29, 2022 at 4:23 PM
    matoolie
    Michael
    2021 Lunar Pro
    It does suck the OEM plate needs to be removed for oil change. But you can change the bolts to studs which helps quite a bit. See this thread. I’ve done this.
    7385 likes this.
  14. Apr 30, 2022 at 3:01 AM
    Matt83
    Matt83 New Member
    Northeast
    I think that is an incredibly bad idea. There are many objects that can cause severe damage on road when they get tangled up under your truck.
    I could also see a dealer or insurance company blaming the lack of a skid plate when processing a claim or repair.
    In addition, underbody panels and skids play a large roll in underbody airflow and removing them can be detrimental to the vehicle. Not sure if this is the case with a large body on frame SUV, but it is a factor to consider and maybe a topic someone else can shed light on.
  15. Apr 30, 2022 at 5:45 AM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    My biggest PITA when removing the stock skid plate was unhooking the front tabs, so I cut them off and now it's so much faster to change the oil. If you stay stock I'd highly recommend it, though just be careful to support the plate when you're removing the last couple of bolts.
    Bgdv1 likes this.
  16. Apr 30, 2022 at 5:58 AM
    Those front tabs were most likely designed for a shop to allow the skid to hang while they did the oil service with the truck on a lift. Pain for the DYIer, helpful for a shop.
  17. Apr 30, 2022 at 6:13 AM
    When I bought mine, all the front skids were missing. I proceeded to drive around like that for close to 2 years before I finally replaced it with an RCI. I really wouldn't worry about it.
    My Pontiac Firebird, which obviously sits way lower to the ground than a 4Runner, has no engine skid and driving that for 15 years I've never had a problem.
    Think about most passenger cars, they don't have engine skids and they do fine. What they do have is maybe a plastic shield that is there more for aerodynamics than actual protection from anything.
    K-Paul likes this.
  18. Apr 30, 2022 at 6:17 AM
    If you're not off-roading, maybe buy the TRD skid, and just cut holes in it where you need to access the filter and drain plug?
    Also, somebody posted on here recently that there's a generic version of it on Amazon for less than 200 bucks.
  19. Apr 30, 2022 at 7:00 AM
    afret
    North Idaho
    THIS ^^^
  20. Apr 30, 2022 at 7:18 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    The 4R is the only vehicle I have ever owned that has a skid plate. Passenger cars don't come with one. No need 'cause they aren't off-roading. If you don't like it, take it off.
    Trail Runnah likes this.
  21. May 2, 2022 at 11:15 PM
    Altitude4x4
    Altitude4x4 New Member
    2019 Voodoo Blue TRD Pro
    Don't do it, there's plenty of knuckleheads on the highway that don't secure their cargo. The skid may save critical engine components someday.
    LandCruiser and Slopemaster like this.
  22. May 3, 2022 at 6:03 AM
    MAXIM
    MAXIM New Member
    It is not skid plate but "engine under cover" made from thin sheet metal. It will protect vital components from stray road debris. By removing stock cover you'll expose lower radiator, plastic oil filter housing, A/C lines, brake lines and many other components. Why would manufacturer go trough trouble putting that cover in, knowing 99% of drivers won't take this vehicle off road.
    7385 and LandCruiser like this.
  23. May 3, 2022 at 8:23 AM
    Billyrides
    Billyrides New Member
    Billy
    St. Charles MO
    2015 SR5P
    Fuel Tactic wheels 17x9, -12, 275/70/17 Wildpeaks, Diode Dynamics LEDs, Cali Raised LED Molle panels, Pedal Commander, 6112/5100 (6-4), Bilstein rear springs
    I'm in the same boat as Trail Runnah. When I bought my 2015, it did not have the front plate. I have had no issues in the past year. However, if I hadn't missed the RCI tax time sale, mine would have the RCI plates on it right now. There's a lot of parts that are under that plate that I don't particularly want to have to replace. I can control where I go and what I do when I'm off road, but I can't control someone's ladder flying off their truck driving down the highway and taking out my radiator.
  24. May 3, 2022 at 10:08 AM
    afret
    North Idaho
    A skid plate might not be of much help if a ladder comes flying off the truck in front of you.
  25. May 4, 2022 at 10:25 AM
    MAXIM
    MAXIM New Member
    Tire chunks, medium size rock, stick, chunk of road concrete, racoon... Why do I have to define road debris hazard items?
  26. May 4, 2022 at 1:00 PM
    Billyrides
    Billy
    St. Charles MO
    2015 SR5P
    I think I'd probably be much better of with a chunk of steel guarding my radiator than nothing at all, but I see your point. Now I guess I have to think of every possible hazard on and off road before I send RCI my money.
  27. May 4, 2022 at 1:30 PM
    Altitude4x4
    Huh? Do you not own skid plates? I didn't know a ladder is a skids achilles heel yet they'll support my whole truck high centered on a rock.
  28. May 4, 2022 at 2:54 PM
    afret
    North Idaho
    Well if a ladder flies off a truck in front of you and comes through your windshield................
  29. May 4, 2022 at 3:55 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    I have hit all of the above mentioned items numerous times in over 45 yrs. of driving vehicles that did not have any under body protection what-so-ever.
    A few scratches and some blood, guts, and fur were the only issues. Never a mechanical problem.
  30. May 4, 2022 at 4:31 PM
    2112 R
    2112 R New Member
    I would highly recommend at least some sort of plate/protection. When my RCI Alum plates arrived I removed the stock plate and then had to pause the install job. During that time I drove for a week without the front skid. When I went to finish getting the RCI up there you could tell from all the dirt, dings, road garbage etc that I had been driving without anything installed. Luckily no real damage, but I could image doing that on a full time basis over time there would be some sort of damage eventually. Amazing what a small thin metal plate can do.
