Is -44 offset possible with 3inch lift
Discussion in '5th Gen Builds (2010+)' started by Dillen808, Jan 3, 2019.
  1. Jan 3, 2019 at 9:06 PM
    Dillen808
    Dillen808 [OP] New Member
    Dillen
    2018 4runner
    3inch rough country lift
    Hi I just wondering if it would be possible to do 20x10 -44 offset for my 2018 4runner with a 3inch rough country lift installed?
    Or will i only be able to do a 20x10 -24 offset?
    I will be putting
    RBP Repulsor MT 33x12.50R20LT(LOAD E)
  2. Jan 3, 2019 at 9:26 PM
    Dark Knight
    Dark Knight New Member
    Get your sawzall ready.
    Neither offset is going to fit without lots of modification on a 3” lift.
    Backslider, Snickel Fritz and jgcaps like this.
  3. Jan 3, 2019 at 9:57 PM
    Dillen808
    Dillen
    2018 4runner
    Minor trimming for this here? So my -24 will work with minor trimming
  4. Jan 3, 2019 at 10:08 PM
    Dark Knight
    Good luck to you sir
  5. Jan 3, 2019 at 10:26 PM
    Dillen808
    Dillen
    2018 4runner
    To you to I will keep you posted on the new wheels and tires
  6. Jan 9, 2019 at 11:57 PM
    Dillen808
    Dillen
    2018 4runner
    Well there you go they fit
    jgcaps, RedRunner15 and Dark Knight like this.
  7. Jan 10, 2019 at 12:03 AM
    Snickel Fritz
    Snickel Fritz New Member
    West Texas
    2018 TRD ORP - Silver
    How's the rub at full lock in forward/reverse? When tucked? I just noticed that in your convo with the seller, they mentioned a 2WD SR5- if yours is 4WD you might have rubbing that they didn't.
    Backslider likes this.
  8. Jan 10, 2019 at 6:28 AM
    Dark Knight
  9. Jan 10, 2019 at 7:25 AM
    Dillen808
    Dillen
    2018 4runner
    on custom wheel offset they show ones with 4wd to, minor rub at full turn only if going over a bump
    Snickel Fritz likes this.
  10. Jan 10, 2019 at 7:11 PM
    Dillen808
    Dillen
    2018 4runner
    Here we go
  11. Jan 11, 2019 at 3:53 PM
    Snickel Fritz
    West Texas
    Dillen, you might want to remedy any rub that you do have, even if it seems like a minor thing that only occurs in uncommon situations. If you're only rubbing a slight bit on the plastic liner, you *might* not damage anything over time. If you're rubbing on metal, you could end up with serious damage should you ignore it, maybe even causing a catastrophic failure at speed.
    Glad to see that your setup mostly worked for you, though. Enjoy your ride!
  12. Jan 11, 2019 at 5:20 PM
    Dillen808
    Dillen
    2018 4runner
    NO rubbing on any plastic, only at full turn when you hit a bump......
  13. Jan 17, 2019 at 12:52 PM
    Agent_Outside
    Agent_Outside New Member
    2011 T4R Limited
    Many people have the misconception that lifting a 5th gen gives you more tire clearance, that’s simply not possibly with the design of the IFS.
  14. Jan 17, 2019 at 6:04 PM
    Dillen808
    Dillen
    2018 4runner
    What do you even have?
  15. Jan 17, 2019 at 6:09 PM
    Agent_Outside
    2011 T4R Limited
    In reference to what? Suspension?
  16. Jan 17, 2019 at 10:14 PM
    Dillen808
    Dillen
    2018 4runner
    Yes lift or wheels?
  17. Jan 17, 2019 at 10:15 PM
    Dillen808
    Dillen
    2018 4runner
    Let’s see a picture
  18. Jan 18, 2019 at 12:43 AM
    Agent_Outside
    2011 T4R Limited
    I don’t see how what I have is relevant to my statement but sure...6987507E-6B60-43AC-9BBC-B39239367B48.jpg
    Extended travel King suspension, Icon 2” rear springs, JBA upper control arms, with 33.3” tires on TuRD Pro wheels.
  19. Jan 18, 2019 at 8:25 AM
    Dillen808
    Dillen
    2018 4runner
    You don’t have a offset rim.....
    Try to put 33.3 with offset rim on stock height
  20. Jan 18, 2019 at 8:51 AM
    Agent_Outside
    2011 T4R Limited
    What I have does not change the fact that a lift does not create clearance.
    As I said it’s a common misconception that a lift gives you tire clearance, but that is just not true with the 4Runner’s IFS. There’s 4 movements for a wheel/tire - steering left, steering right, full suspension compression, and full suspension droop. There is a fixed range of motion throughout any combination of those movements. When you lift it you do nothing to change the range of motion and in turn, the space the tore can occupy. You’re just changing the static location of the tire inside that same range of motion which means you did nothing to add more clearance.
    Let’s say you have 8” of total suspension travel and that at static ride height when stock you have 4” of available up travel and 4” of available down travel. Now you lift it 2”, you didn’t create more room, you just made it so the static ride height moved up within the same 8” range. You would now have 6” of up travel available and only 2” of down. If a bigger tire rubbed at stock ride height while turning right and you lift it, you did not fix the rubbing, you just changed when it happens (when turning right with X amount of braking the wheel will be in the exact spot it rubbed at before and will still rub all the same). Lifting it can change the conditions in which it runs but it’s impossible for it to add clearance.
    You need to change the space the tire will occupy compared to the stock to actually create more clearance - that can be done with changes in tire width and diameter, wheel offset, different suspension geometry, the location of the lower control arms via the alignment adjust cams, etc. Shock length and aftermarket upper control arms can change the range of motion, and bump stops can be used to reduce the range of motion upwards to keep from stuffing a bigger tire into the fender. There’s lots of things and a lots of variables that will help you clear a bigger tire but on independent front suspension, with all else equal, ride height is not one of them.
  21. Jan 18, 2019 at 1:32 PM
    Backslider
    Backslider Gun Nerd
    Tooele, Utah
    2017 T4r SR5 Premium With Extra Pickles
    Press the pretty buttons in my signature for modifications or to see my terrible Instagram page!
    Your front wheels look very far forward in the wheel wells - what is your caster?
  22. Jan 18, 2019 at 6:42 PM
    Dillen808
    Dillen
    2018 4runner
    That’s awesome I’ll keep that in mind:)
  23. Jan 18, 2019 at 7:56 PM
    Dillen808
    Dillen
    2018 4runner
