Ironman 4x4 LIFT 2020 4runner with KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by irfan0922, Dec 30, 2020.
  1. Dec 30, 2020 at 5:58 AM
    irfan0922
    irfan0922 [OP] New Member
    siblue and Rainier42 like this.
  2. Dec 30, 2020 at 7:00 AM
    Rainier42
    Rainier42 New Member
    Johnny
    Bucks County, PA
    2020 Silver 4Runner Venture
    Sliding Cargo Tray, 265/70 R17 Falken WildPeak A/T3W tires, Interior Vled bulbs, LED Fog Lamps off of a 2020 TRD Pro w/Yellow Lamin-x film, Pedal Commander, TRD Pro shift handle, Subaru front tweeters.
    Good video, I like seeing how you reason through things. Will be installing after market struts on mine, so was interested to see how you deal with KDSS.
  3. Dec 30, 2020 at 8:35 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Do you need feed back on the shocks or your video ???
    Mtbpsych likes this.
  4. Dec 31, 2020 at 4:01 AM
    irfan0922
    Nice question:) , actually i did not add detail description regarding feedback
    i want to know that if i keep 3 inch lift , this will not hurt drive train
    anyone else tried Ironman and want to know opinion on this , etc , feel free discussion .:cheers:
  5. Dec 31, 2020 at 4:17 AM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    You will be fine at 3”. And keep in mind that you suspension will settle after a few weeks.
    Doglover2003 likes this.
  6. Dec 31, 2020 at 4:50 AM
    Red_5
    Red_5 New Member
    Been running a 3" Ironman Foam Cell Pro Stage 2 + KDSS for over 5,000 miles with zero issues. I've off-roaded it plenty. Zero issues. Been on overlanding trips with many configurations of passengers and cargo. Zero issues. Maybe issues will crop up later? It's possible, but so far, so good.
    4runGirl88, ericam38 and DrewMan like this.
  7. Dec 31, 2020 at 6:53 AM
    irfan0922
    thanks everyone
  8. Dec 31, 2020 at 8:11 AM
    Dillusion New Member
    KYle
  9. Dec 31, 2020 at 11:07 AM
    ForRun
    ForRun 4Runner
    2020 orp
    Not always true. I have eibach adjustable front and rear and has settled "0" in 8k miles
  10. Dec 31, 2020 at 12:38 PM
    irfan0922
    @Dillusion in the picture you can see my cv angle
    captrussia253 likes this.
  11. Dec 31, 2020 at 12:50 PM
    KYle
    Yours looks adjustable. Compared to runner fans.
    Did you measure before and after?
  12. Dec 31, 2020 at 12:53 PM
    irfan0922
    possible i have factory tires 265 , 285 will lift you cv excel
  13. Dec 31, 2020 at 12:58 PM
    KYle
    Pretty sure tire size does not affect CV angle.
  14. Dec 31, 2020 at 6:23 PM
    ThePnsh3r
    2020 TRDOP
    Then you must’ve bought a well broken in suspension lol. Any spring will settle some after install. Unless your pre-install preload is far exceeding the weight on the springs to where putting it under constant load (after it’s been installed and vehicle on the ground) was negligent difference (a very heavy duty spring will have similar effect) Or you’ve got a well worn in spring installed.
    My inronman FCPs did settle by about 1/4”over the course of 3 weeks as compared to after just installed (and post alignment).
  15. Dec 31, 2020 at 6:26 PM
    ThePnsh3r
    2020 TRDOP
    You are correct. Cv angle is determined by the relation of transfer case output to the center of the wheel hub. Putting smaller or taller tires will not change how compressed the suspension is - hence angle will remain same. Installing stiffer and longer springs will push your control arm down more in relation to the output on the transfer case - which gives you greater cv angles.
    Installing a taller tire does not compress your suspension any more or less - so cv angle will be unaffected.
    The effect that will be apparent after installing taller tire is overall lift of the vehicle as measured from the frame to the ground. That is your “total lift”. Tires + suspension lift = total ground clearance increase.
    irfan0922[OP] likes this.
  16. Dec 31, 2020 at 6:33 PM
    ThePnsh3r
    2020 TRDOP
  17. Dec 31, 2020 at 8:39 PM
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    Question: when you install your new shocks & coils; Did you adjust your KDSS to allow it to level out? … See Toyota Owners Manual regarding adjusting. Reason: Seems like I read on the forum about passenger side leaning a bit or sags downward on that side of the vehicle.
  18. Jan 1, 2021 at 1:24 PM
    captrussia253
    captrussia253 New Member
    Ruslan
    I had 3/4” lean to the passenger side on my GX460 with KDSS. I too have the Ironman stage 2 lift. I corrected the lean with Ironman 20mm rear coil spacer and toytec 1/4” front strut spacers. All is leveled now and it’s been 6 months with several off road trips with no issues.
    DrewMan and Red_5 like this.
  19. Jan 6, 2021 at 9:05 AM
    irfan0922
    @DrewMan when i first installed ironman 4x4 , yes it did lean down , i got passenger side 4 inch lift and driver side 3.1 , and when i sit on driver seat i saw it pushed my 4runner down pretty visible lean , after 2 weeks ( i do not drive a lot ) everything get normal , both sides ( driver + passenger ) i was getting 3.1 , i talked to Iron Man and they send me second set , which i installed in this video , these set of shocks did not give me any lean at all .
    i did not adjust KDSS at all .
    i will closely monitor soon to see did ironman did something on the driver site shock system .
    because they did mentioned on the box , driver site and passenger side
    DrewMan likes this.
  20. Jan 7, 2021 at 10:32 PM
    DrewMan
    Middle Tennessee
    Thanks for the feedback; which series of Ironman Lift Kit or just shocks did you chose? … just curious
  21. Jan 8, 2021 at 3:39 AM
    irfan0922
    @DrewMan
    FOAM CELL PRO SUSPENSION KIT SUITED FOR TOYOTA 4RUNNER 2010+/LEXUS GX460 - STAGE 1
    2.5 lift performance load (0-110LB) Front
    2 Lift Performance load (0-660lb) rear
    i am getting 3inch lift due to no winch or bumper , i am planing to bring the lift down to 2 inch or 2.5 because of rough ride and CV excel angle .
    on the begging on this thread , i have posted a Video .
    DrewMan likes this.
  22. Jun 14, 2021 at 12:12 PM
    Lurapenal
    Lurapenal New Member
    2020 4Runner ORP
    Hello, I order the same Kit you have. Ideally, I will get the same look as yours so I'm curious to know if you made any changes to the struts or did just installed as they came out of the box?
    DrewMan likes this.
  23. Jun 21, 2021 at 5:34 PM
    ThePnsh3r
    2020 TRDOP
    I have only tightened the setscrews on the adjustment rings. I asked to have it set to 2" front because I wanted to maintain that slight factory rake.
    DrewMan likes this.
  24. Jul 15, 2021 at 2:46 PM
    Acefaaace
    Acefaaace New Member
    Ariel
    2020 SR5 Premium
    Need some help. So I ordered the foam cell pro stage 2, 2.5" front performance springs, and the only option was the 2" rear coil performance springs. I Was wondering if this was going to give my vehicle a leveled look or if the rear was going to be too high? I'm looking to get a slight rake in the rear when I have it installed.
