Inverter upgrade?
Discussion in '5th Gen 4Runners (2010-2024)' started by Thacrow, Mar 7, 2023.
  1. Mar 7, 2023 at 11:55 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    Anyone upgrade their inverter? If so what did you do?
    How about alternator? Anyone know a good high output alternator brand?
    Seems like it would be cool to have maybe 1,000 watts of AC. could run an extra outlet.
    This would also free up a switch on the dash. Wouldn't need the stock inverter switch.
  2. Mar 8, 2023 at 12:07 AM
    If you’re planning on using the existing wiring, ensure it’s up to the task, if there are increased amperage loads. Good luck.
    Thacrow[OP] likes this.
  3. Mar 8, 2023 at 12:11 AM
    Thacrow
    2021 ORP
    Speed holes
    Would definitely upgrade the stock wiring. And thank you.
  4. Mar 8, 2023 at 1:41 AM
    11x
    11x New Member
    2019 trd limited
    No need for a new alt in a lot of cases. I can’t speak exactly for Toyota but in the past I have had factory Chevy and ford alt rebuilt up to 120 amp.
  5. Nov 2, 2023 at 1:22 PM
    blue4runner
    blue4runner New Member
    Geoff
    2018 blacked out Limited
    matching front window tint, chrome delete, TRD off road wheels with 275/R17 K02's
    I to a new alternator to a reputable Alternator shop. He was able to take the 120 amp stator out and swap in a 240 amp stator from I believe the Sienna. Same case as the stock alternator so it installs easy. No finding a different belt.
    I did install the voltage booster and I run 2 group 31 Odyssey batteries one for starting and the other for my sound system. I'm getting 14.2 volts.
