Intermittent vibration above 50 mph
Discussion in '3rd Gen 4Runners (1996-2002)' started by 4runnerdantheman, May 2, 2021.
  1. May 2, 2021 at 9:32 PM
    4runnerdantheman
    4runnerdantheman [OP] New Member
    dan
    1997 black 4runner Limited
    none
    Vibration above 50mph usually means u joint right? I think something else is wrong. A u-joint vibration problem would go away if i took my foot off the gas and stopped accelerating ( while remaining above 50mph). The vibration i am experiencing now is different, it vibrates even when just coasting, above 50 mph. To make the problem weirder, it is an intermittent problem. It doesnt do it all the time. Any clues? please. thanks, Dan
  2. May 2, 2021 at 10:51 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    I wouldn't rule anything out until it has been thoroughly inspected. Have you checked all the mounts?
  3. May 3, 2021 at 2:16 AM
    Welcome from Wisconsin!
  4. May 3, 2021 at 11:49 AM
    Yeah, a u-joint vibration usually goes away when coasting. You can get a clunk when putting it in drive or reverse too.
    So how did you rule out the brakes/wheels/tires? Those are the first culprits.
    Seems like a few people have found the drive shaft, if it has a rubber insert in it, can go bad.
  5. May 7, 2021 at 7:47 AM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    could also be tires / rotors/etc out of balance....as well
  6. May 7, 2021 at 2:00 PM
    markmb45
    markmb45 New Member
    South Ogden, Utah
    2013 4Runner Trail Edition
    3” OME Lift, JBA UCA’s, 275/70R17 General Grabbers, ARB air compressor
    I had the exact same issue. It was a u-joint. Replaced it and all is well.
  7. Jun 6, 2021 at 11:50 AM
    Ambush
    Ambush New Member
    AJ
    99 Black Limited (Kitt) 99 Tan limited (Desert Storm) 2001 Silver SR5 (Silver Surfer)
    If the u-joint does not help, it could be your driveshaft out of balance. TRUST me I have been through this with 2 of 4runners. They make the shafts with this RUBBER piece in it and there is no way to replace it. They get out of balance. It is SOO annoying.
    SlvrSlug likes this.
  8. Jun 8, 2021 at 8:41 AM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    A loose rear differential pinion nut can cause a vibration.
