Insufferable rattle
Discussion in '5th Gen 4Runners (2010-2024)' started by Sandman588, Aug 30, 2024.
  1. Aug 30, 2024 at 1:39 PM
    Sandman588
    Sandman588 [OP] New Member
    I’m having a rattle in my 2022 4Runner Limited. It seems to be coming from a driver side door panel. I took it to the Toyota dealership where they took the panel off made sure all the screws were tightened and put insulating foam around contact points. The noise is still there as you can see from the video. anyone have any ideas because it’s driving me crazy.
    https://imgur.com/a/lOXeIBU
  2. Aug 30, 2024 at 2:16 PM
    Check the roof rails.
    Ripper238 and Borracho Loco like this.
  3. Sep 5, 2024 at 5:24 PM
    Sandman588
    So I’ve isolated the rattle to this exterior chrome piece just below the window. Can I just place this piece or reinforce it somehow?
  4. Sep 5, 2024 at 5:26 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    You should be able to replace it. I replaced all of them years ago on my 4th gen when the seals failed
    Sandman588[OP] likes this.
  5. Sep 5, 2024 at 5:39 PM
    Sandman588
    Yeah I was just reading more about them. Apparently it’s the chrome door belt molding. Looks pretty easy to change. Maybe this starts the chrome delete.
  6. Sep 5, 2024 at 5:55 PM
    Pavo
    Pavo New Member
    Are you sure it’s not your splash guards? I had a rattle coming from behind the vent on my 22 4Runner they took it apart and put foam then there was a rattle from the roof near the moonroof so I traded her in
  7. Sep 5, 2024 at 6:35 PM
    TrueTexas
    The Woodlands, TX
    Its been a long time since I did it but I want to say it was as easy as pulling off the old and pushing the new ones on. No actual tools needed.
  8. Sep 6, 2024 at 6:22 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Sell the runner and go get the lexus.
  9. Sep 6, 2024 at 8:10 AM
    Sandman588
    So before I went out and bought the new part and tried it I decided to try one other idea that I had seen on Reddit. It actually worked. It’s been days now without the rattle sound. I just don’t know what the permanent fix is. I out electrical tape around the door latch/striker. IMG_1735.jpg
    j4unner likes this.
  10. Sep 8, 2024 at 7:05 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    So is it the chrome window piece or the door striker?
  11. Sep 10, 2024 at 2:36 PM
    Sandman588
    Well, apparently neither. The door striker seemed work until it didn't. I bought the chrome piece and installed it, but the rattle is still there. No idea where to go after this.
  12. Sep 10, 2024 at 2:54 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Looks like one of the screws on the door striker is loose.
  13. Sep 10, 2024 at 2:54 PM
    Did you check the roof rails bolts etc?
  14. Sep 14, 2024 at 4:25 PM
    TroutMan
    TroutMan New Member
    I'm sad you didn't figure it out because my 2019 has had this for years and it's the one rattle I've not tracked down and solved. My theory is that it's inside the door panel, not the outside.
    I saw that on the new Tundras, there's a similar noise on the passenger side that turned out to be window seals that were not holding the window firmly when closed so there was some vibration. I was going to look at that too.
  15. Sep 15, 2024 at 5:18 AM
    Sandman588
    Yobruhitsme likes this.
  16. Sep 15, 2024 at 9:58 AM
    2Turbo
    2Turbo New Member
    I had a rattle, driver front, inner fender liner was loose, had to get different plastic rivets from harbor freight to make tight
  17. Sep 15, 2024 at 11:52 AM
    Ripper238
    2019 TRD OR
    In the end 4Runners are rattle boxes. So i put 600 watt stereo system in to drown it out.
    Nick B likes this.
