Installing Eibach stage 1 Pro Truck lift
Discussion in '5th Gen 4Runners (2010-2024)' started by whododat, Aug 10, 2022.
  1. Aug 10, 2022 at 4:58 AM
    whododat
    whododat [OP] New Member
    Hello from TN,
    I am looking to install the Stage 1 Eibach kit on my 21 4Runner TRD ORP. The truck is stock as it sits and I plan on leaving the stock UCA's on. I have found several videos on it but have a couple of clarifying questions.
    -Will I need any special tools for this, such as a certain type of torque wrench for the hard to reach areas or odd locations?
    - Should I mark the nuts/bolts after I torque them to check afterwards?
    -Are there any special tricks or useful steps in making it easier for me, either for the front or rear installation process? Such as lifting the axle on one side during a certain time of the process in the rear.
    The front parts have been pre-assembled already.
    I will be taking my time and doing it in my garage, just trying to do it correctly.
    Thanks in advance.
  2. Aug 10, 2022 at 4:44 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Its pretty straightforward, take off old, install new the same way you took old stuff off.
    You may need a spring compressor, jack stands, 2 jacks makes it easier. Take your time and follow the instructions that come with kit
    Also make sure to retighten all bolts after 500 miles.
  3. Aug 10, 2022 at 5:46 PM
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    I did the that kit on my 2019 about 3 months after I purchased it. I took a chance and bought a cheap Harbor Freight spring compressor and lo & behold - it worked! Did front & rears with no assistance but did take me 3 days due to mandated old man naps.. I've been pleased with the product.
  4. Aug 10, 2022 at 8:25 PM
    The only bolts you would need to mark beforehand is if you use the 'no spring compressor' method to remove the front shocks and coils. It requires loosening the cam adjust bolts on the lower control arms so you can lower the LCA after removing the bolts that attach it to the wheel hub. You use the marks to get the cam adjusters back to as close as possible to where they were when you retighten the cam adjuster bolts. It will need to be aligned anyway, so close is good enough. Should you use another method, ignore.
  5. Aug 10, 2022 at 8:26 PM
    If the front shocks and springs are already assembled, no spring compressor is needed.
  6. Aug 10, 2022 at 8:55 PM
    Sandbuster
    Central Florida
    2019 TRD Offroad
    Quite true but look at the risks and inherent education he'd be missing..... :llama:
    glwood54[QUOTED] likes this.
  7. Aug 11, 2022 at 3:33 AM
    whododat
    Thank you all. Yes, the front shocks and springs are pre-assembled.
  8. Aug 11, 2022 at 9:03 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    ^^ then it's a simple straightforward installation
