Installed Raptor Light and now nothing works
Discussion in '5th Gen 4Runners (2010-2024)' started by Thacrow, May 6, 2025.
  1. May 6, 2025 at 12:48 AM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    Any ideas?
    roooo likes this.
  2. May 6, 2025 at 2:42 AM
    Beachguy
    2024 TRP ORP
    See a doctor. They got pills for that.
    Thacrow[OP], djwantke, roooo and 2 others like this.
  3. May 6, 2025 at 4:04 AM
    UncleShorty
    UncleShorty New Member
    Here we go... AGAIN...
    Have you checked the Turboencabulator fuses?
    You could be parked in an area of low magnetic flux. Try jacking up both wheels on the driver's side to re-distribute the E squared interval.
    Hope this helps...
  4. May 6, 2025 at 4:47 AM
    take them out
    siblue and roooo like this.
  5. May 6, 2025 at 5:10 AM
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    If you like Raptor lights on your 4Runner, I hope you like Raptor lights on your children's graves because you're weak, your bloodline is weak, and you will not survive the winter.
  6. May 6, 2025 at 5:23 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Damn I know @Thacrow knows his way around wiring too. My money is on a fault with the lights themselves.
    What brand did you go with and was it a fuse tap to make them work?
  7. May 6, 2025 at 5:26 AM
    Buba1
    Buba1 New Member
    Ontario
    MGM TRD Pro
    What do you mean by nothing works? What doesn't work? In the pic it looks like all your lights work...
  8. May 6, 2025 at 5:43 AM
    true!
    Thacrow[OP] likes this.
  9. May 6, 2025 at 6:54 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
  10. May 6, 2025 at 6:57 AM
    2019 TRDP w/Kangs brah!
    Craptor lights. Probably used the IGN fuse, huh?
  11. May 6, 2025 at 6:59 AM
    He's just yanking the raptor light chain...nothing works? The camera worked.
    Saker, Photon_Chaser and Thacrow[OP] like this.
  12. May 6, 2025 at 7:09 AM
    do yourself a favor and take them out. This is a sign that they werent meant to be
    roooo and whippersnapper02 like this.
  13. May 6, 2025 at 7:32 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    This is why I only install high quality raptor lights
  14. May 6, 2025 at 8:42 AM
    West Coast, Sierra Mountains
    Pretty sure the problem is that red wire...
  15. May 6, 2025 at 8:44 AM
    Imdav2u
    23 TRD PRO
    We need more information or we can't help you. Nothing works is a pretty broad statement.
  16. May 6, 2025 at 8:46 AM
    1SilverRunner
    Tejas
    I installed raptor lights and now I have erectile disfunction.
    Plz hlp
  17. May 6, 2025 at 8:48 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    :rofl:
  18. May 6, 2025 at 8:50 AM
  19. May 6, 2025 at 8:58 AM
    When I installed Raptor Lights my engine started when I turned them on, any ideas?
  20. May 6, 2025 at 9:00 AM
    Have you tried turning it on and off
  21. May 6, 2025 at 9:08 AM
    Imdav2u
    23 TRD PRO
    Go see you doctor, there's a procedure to fix that, I think it's called a adsomedicktome.
  22. May 6, 2025 at 9:21 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Thacrow[OP] and roooo like this.
  23. May 6, 2025 at 11:47 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  24. May 6, 2025 at 1:03 PM
    Thacrow
    2021 ORP
    Speed holes
    Yeah that's the problem. The heated seats also dont work now.
  25. May 6, 2025 at 1:31 PM
    I thought this was entirely a troll thread, is it not lol cuz otherwise I’ll try to help and try to resist raptor light jokes
  26. May 6, 2025 at 1:35 PM
    It looks like all your lights work except the low beams.
    Take two of the wires from the raptor and connect them to drivers side, the rest of the harness will know you are providing 6 volts of current to the electrical system so now you take 2 more wires and connect them to the passenger side and now that makes 6 + 6 = back to 12 volts
    This will split the power from the raptor lights which each have 3 volts so if you install another set of raptor lights, that will force the electrons to gang up on each other but they're gonna also spread out because theyre hard to catch so they'll distribute themselves proportionally throughout all of lights!!
  27. May 6, 2025 at 1:50 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    I'm not sure if that was meant to be a pun but if not, [​IMG]
  28. May 6, 2025 at 3:34 PM
    Thacrow
    2021 ORP
    Speed holes
    Lmfao
  29. May 6, 2025 at 3:36 PM
    FourBelugas
    23 white ORP
    It's no laughing matter. I know a guy who installed Raptor lights on his Taco. 3 years later, BAM! Divorce. It gets bad bro.
  30. May 6, 2025 at 4:01 PM
    scottiezilla
    scottiezilla New Member
    1. Goto church, confess, n repent
    2. Kill breakfast n cook on open flame
    3. Cut down the tree out front alone
    4. Pour Everclear in open wound
    5. Beat sun in staring competition
    6. Backhand your neighbor
    7. Listen to something loud from ‘76
    8. Pee outside…in public
    9. Wait for moon, n howl
    10. Turn on Die Hard
    Now, @Thacrow , if you didn’t have to itch anything during all this, all hope might be lost
    Side note: secret step 11.
    start new thread entitled
    “How to grow a pair”
    Otherwise, sell the minivan
    Technologic80 and Thacrow[OP] like this.
