Inner Rear Tire Wear 1993 4Runner
Discussion in 'Wheels & Tires' started by Rosecat314, Oct 18, 2022.
  1. Oct 18, 2022 at 5:23 PM
    Rosecat314
    Rosecat314 [OP] New Member
    1993 Silver 4Runner
    I have a 1993 Toyota 4 Runner in good condition. One set of back tires destroyed from where identical on both on the inside. Replaced tires, had alignment and tires are ruined again. (See picture. ) ive had it to 2 alignment places. Rear passenger reading is -1.036. Rear driver tire is within range. Took to a body shop. The mechanic said the axle was bent and then offered to buy the vehicle. Would any other mechanical issues be to blame? Thank you?20221015_090641.jpg
  2. Oct 19, 2022 at 10:59 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Not an alignment issue, axle is more than likely it to happen equally on both sides of the truck.
  3. Oct 19, 2022 at 11:00 AM
    Overland WT
    Bryan
    West Texas
    2017 TRD Off Road
    And no, its not that expensive to fix it. I wouldn't sell it for an axle related issue. He wants to buy it since he can fix it cheap and turn it around.
  4. Oct 25, 2022 at 12:07 PM
    MAG GRY TACO15
    MAG GRY TACO15 New Member
    stock wheels? have you jacked the rear end up and free spun the tires to see if its rubbing on anything obvious?
