Independent Fog light mod
Discussion in '5th Gen 4Runners (2010-2024)' started by c4inam2n, Mar 2, 2016.
  1. Mar 2, 2016 at 10:59 AM
    c4inam2n
    c4inam2n [OP] New Member
    Sam
    Long Beach, CA
    2015 SR5p 4x4
    Hoping I might be able to get some help here. I've done this mod on my taco and my IS by running power to the actual fog relay directly and seen this done on older gen 4Rs but the 5th gen on T4R.org has a different method (by Antman). I've reached out to Antman but no response yet hoping he might be able to shed some light. My question is does the 5th gen have it's own relay or is it integrated else where that the old method of supplying power to it directly is not feasible!?
  2. Mar 2, 2016 at 4:14 PM
    c4inam2n
    Sam
    Long Beach, CA
    2015 SR5p 4x4
    Update: Jeff (Antman) replied "The reason the mod is a "work around" of the factory relay is because the factory relay is sealed in a box under the dash. No real way to get to it!" So for those if you haven't already seen his thread on T4R.org and want this mod for your rig here you go.
  3. Jan 5, 2017 at 9:04 AM
    jester243
    Dan
    Spokane, WA
    I was just looking for a way to do this and damn that is a lot of work to accomplish it. I kinda liked the way it was on the taco, just bend a leg on a relay and run 1 wire. :pout:
  4. Jan 5, 2017 at 10:31 AM
    ramonortiz55
    ramonortiz55 New Member
    Ramon
    That's a lot of work.
    djwantke likes this.
  5. Jan 21, 2017 at 5:10 PM
    Hardscrabble
    Hardscrabble New Member
    Scott
    2005 SR5 V8
    Antman's procedure for the "fog light anytime" mod isn't all that difficult. I accomplished it on my Moms 2010 Runner, and she just traded for a 2016 Runner, and requested the mod to be done again. She really liked having her fog lights on with the high beams.
  6. Jan 21, 2017 at 5:14 PM
    ramonortiz55
    Ramon
    whatchu doing here :spy:
  7. Jan 21, 2017 at 5:19 PM
    Hardscrabble
    Scott
    2005 SR5 V8
    :anonymous: Well...between my wife's '05 V8 Runner and my Moms 4Runners (she just bought her 4th), I'm checking out ways to spend my time and money. Which reminds me, I need to order some Iggy lights. :facepalm:
  8. Jan 21, 2017 at 5:24 PM
    ramonortiz55
    Ramon
    doooo eetttt
    Hardscrabble[QUOTED] likes this.
  9. Aug 23, 2019 at 9:21 AM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    is there any other way to accomplish this with out Antman's way
    any body else has any suggestions or work around
    I was thinking just tapping in to the fog light wires by the fog lights and running the wires back to the dash and pulling a power supply from an ignition with a fuse and a relay does that sound right or not please advise me thanks
  10. Aug 23, 2019 at 9:38 AM
    Firefly21
    Firefly21 New Member
    Duane Frazier
    18 off road premium trd
    Hid lows 3500 drl / high Led interior Led reverse Led oem fogs Sequential blinker Trd intake Unifilter pump mod Apex recover points BF Goodrich KO2 (matching trd spare) Kicker front tweeters Tvd overlays S2 yellow wide fogs Apex black sequential rear tails Cartrim home blue convex mirriors
    I was thinking just to install aftermarket baja/rigid in the factory location so they can be on Anytime. Then adding smaller lights off the factory wiring ...small eagle eye marker lights or something behind the grill...hella 500s. Not sure
