In need of rear lift coils
Discussion in '4th Gen 4Runners (2003-2009)' started by cp5555, Feb 2, 2026.
  1. Feb 2, 2026 at 8:06 AM
    cp5555
    cp5555 [OP] New Member
    CJ
    Currently, I am running Tacoma TRD take offs up front, which act as a leveling kit. on the rear i have some new shocks equivalent to the front.
    i am in need of some new rear coils, but i have been dragging my feet a little bit, as I do now know what to get, and i am torn. the vehicle sits perfectly level right now and i would be ok with 1 inch in the back, but i think 2 inches would be too high. this summer we will be taking a long road trip and it will be loaded down for long periods of time so i would like to get some new springs on there to handle the weight. does anyone have a recommendation ?
  2. Feb 2, 2026 at 8:13 AM
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    Whats your budget?
    Dobinsons sells like a TON of different height/spring rate coils.
  3. Feb 2, 2026 at 8:47 AM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    Eibach sells a 1” rear for the 4th gen and their 5th gen 1” would give you approximately 1.25-1.5”. I ran the 4th gen version on my 17 for a number of years.
    Pentangler likes this.
  4. Feb 2, 2026 at 10:58 AM
    20 Venture/17 Taco
    2' from ICON is what I started with. It was ok and good even when loaded. However, as the 4R got heavier I ended up with Dobinsons. The sky is the limit once you start looking....next thing you know you are doing a whole suspension job.
  5. Feb 3, 2026 at 10:46 AM
    cp5555
    CJ
    This might be a silly question but i dont know the answer so ill ask it. i am going to jack up the rear of the vehicle from the hitch, and try to visualize how much lift i want on the vehicle. Should i measure from the top of the tire to the wheel well?
    I like how the front sits, i think that the truck is just about level, if anything the rear is a smidge lower as its stock, coils right now on the rear that are pretty well worn out
  6. Feb 3, 2026 at 12:45 PM
    cp5555
    CJ
    not too shabby!!. im well aware it says 2010+ (5TH GEN) but these are a direct fit, they just add .025-.05 to a 4th gen because they are lighter!
  7. Feb 4, 2026 at 5:18 AM
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    Iron man makes good coils for less dough too. Good thing is that you can’t see the green unless you go under truck!!
  8. Feb 5, 2026 at 11:21 AM
    cp5555
    CJ
    when installing aftermarket coils, do i need to re install these things, whatever they are called?
  9. Feb 5, 2026 at 11:25 AM
    I gained two inches of stock lift back with stock coils from Autozone?
  10. Feb 5, 2026 at 11:29 AM
    cp5555
    CJ
    maybe yours were super worn out. that does concern me a little bit getting the coils i ordered because I am assuming i will gain 1-2 inches from where i am at now, but if my stock coils are worn out, i could end up with even more lift than expected. if that happens i guess ill just be adding more in the front, lol
    NB4x4 and SR5 Limited[QUOTED] like this.
  11. Feb 5, 2026 at 11:30 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Yep
  12. Feb 5, 2026 at 11:30 AM
    hvac guy
    hvac guy New Member
    Yes you should, there bump stops
  13. Feb 5, 2026 at 11:31 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Also, remeasure after about a week of driving… they’ll settle
  14. Feb 5, 2026 at 1:01 PM
    gkomo
    gkomo New Member
    San Diego, CA
    Same. When i put on my Dobinsons IMS my front coils were only for a 1.5" lift but i ended up getting like 2.5" just due to super saggy OEM coils that came off.
    NB4x4 likes this.
  15. Feb 5, 2026 at 1:20 PM
    cp5555
    CJ
    did you put the old springs next to the new ones when you took them out? i would think that even if your OEM were worn out, they should be close to the same height as a replacement(with no lift) when they are un installed
  16. Feb 5, 2026 at 2:02 PM
  17. Feb 5, 2026 at 2:04 PM
    Has rake that levels out when I hitch the boat up.
  18. Feb 5, 2026 at 2:38 PM
    cp5555
    CJ
    At fi
    how many miles were on the OG
  19. Feb 5, 2026 at 2:44 PM
    I think at like 319,000.00, just threw them on real quick it was easy. Watched a youtube vid. Ininstalled the shocks myself.
