Idling issues
Discussion in '2nd Gen 4Runners (1990-1995)' started by 2ndgenrunner94, Oct 15, 2019.
  1. Oct 15, 2019 at 5:22 PM
    2ndgenrunner94
    2ndgenrunner94 [OP] New Member
    Allan
    Florida
    1994 Toyota 4runner
    Hey everyone,
    I’ve got a 94 4runner 3.0 v6 auto that has been having some idling issues. I’ve cleaned out the throttle body, put in a new Mass airflow sensor and she’s improved in some other areas but still noticing a rough idle. She kinda stutters when I accelerate too. Any thoughts? She’s close to 200k miles.
  2. Oct 15, 2019 at 6:14 PM
    Have you tried running a bottle of fuel injector cleaner through it?
  3. Oct 15, 2019 at 6:40 PM
    Do a simple tune-up. You know cap-rotor, wires and plugs. I would go with OEM parts...
  4. Oct 16, 2019 at 12:45 PM
    2ndgenrunner94
    Allan
    Florida
    1994 Toyota 4runner
    @Thatbassguy theyre new injectors. Not even a year old. Do you still recommend it though?
  5. Oct 16, 2019 at 12:47 PM
    2ndgenrunner94
    Allan
    Florida
    1994 Toyota 4runner
    @SR5 Limited cool I got that stuff ready to be installed I’ll see what she does. Thanks!
  6. Oct 16, 2019 at 2:41 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    get new OEM plugs, if not fixed, then check and do a new timing belt.... could be an air starvation item also, check the filter and air flow lineage to the engine..
  7. Oct 16, 2019 at 3:25 PM
    Maybe, if the tune-up doesn't do the trick. Has the fuel filter been replaced?
    These types of problems can be difficult to diagnose. Could be a sensor, vacuum leak, ETC.
    I hope you get it figured out.
  8. Oct 20, 2019 at 1:41 PM
    Twisted Bow
    Twisted Bow New Member
    '95 3.0
    I threw my hands up already with my rough idle. My truck sounds like it's breathing haha. Replaced fuel filter, cap/rotor, plugs, the bird nest in the air filter canister, cleaned throttle body. I think I'm shafted into it being injectors or timing...
  9. Oct 20, 2019 at 2:35 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    Dang all new stuff now.. it’s prob the “computer” / ECU maybe.. heck I would try it at idle with no air filter just to check. You can choke up the idle cable also to higher rpms.. next step I think is one or all injectors .. worth the money. When it’s done and fixed your guts will be all new and replaced.. you could also do a throttle body clean out with some sea foam.. I’ve seen that fix idle problems in one application. You tube sea foam engine clean out.. how’s the smog test? Pass?
  10. Oct 20, 2019 at 2:44 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    You checked for vacuum leaks?
