Idle issue
Discussion in '2nd Gen 4Runners (1990-1995)' started by Chris907, Nov 24, 2019.
  1. Nov 24, 2019 at 5:58 PM
    Chris907
    Chris907 [OP] New Member
    Christopher
    1994 4Runner
    I noticed that my idle whether warm or cold rapidly goes up down up down a few hundred rpm at a time, also have a code 71 for the egr but don’t think that is responsible since it was there way before this problem, and when the temp drops below 30 the runner takes a decent amount of time to start. Are these connected in any way?
  2. Nov 24, 2019 at 7:44 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    Mine goes up and down too. Once warmed up it’s totally goood at 9k rpm idle... yours likely stabilizes too ...after a few minutes?
    Chris907[OP] likes this.
  3. Nov 24, 2019 at 8:17 PM
    Sounds like it could be a vacuum leak. I would also check that all of the intake tubing is in good shape and secure. We had a similar issue once with a Corolla, and it turned out that a piece of intake tubing had split.
    Good luck!
    Let us know what you figure out.
    Also, welcome to the forum!
  4. Nov 25, 2019 at 8:20 AM
    Chris907
    Christopher
    1994 4Runner
    Whether warm or cold it does this where the rpms shift widely
  5. Nov 25, 2019 at 8:21 AM
    Chris907
    Christopher
    1994 4Runner
    Thanks, I’m going to do a more in depth look this week and clean out the tb and iacv to see if that helps. I’ll keep it posted
  6. Nov 26, 2019 at 8:50 PM
    Chris907
    Christopher
    1994 4Runner
    So I cleaned the tb and checked for vacuum leaks and couldn’t find any. Still having the issue. Don’t want to break down and bring it to a mechanic
