Ideas for rear-facing dashcam
Discussion in 'Audio & Video' started by enoren, Dec 16, 2018.
  1. Dec 16, 2018 at 2:59 PM
    enoren
    enoren [OP] New Member
    There are a couple of threads on dashcam installation, but no one has mentioned installing both front- and rear-facing dashcams. Has anyone found a good placement for the rear-facing camera?
    I'm transferring my BlackVue DR650S from a sedan where the rear camera usually sticks to the rear window. With the 4Runner's power rear window, that's not an option. I need another way to install the rear camera.
    Has anyone else solved this problem?
    If you're unfamiliar with dashcam installations, it's generally done with 3M tape on a flat surface with the power cord hidden in the headliner. I don't see any good flat surfaces in the rear with good options for hiding the cord. Has anyone else found a good creative solution?
  2. Dec 16, 2018 at 3:04 PM
    WallyT4R
    WallyT4R New Member
    Scroll down to post 6...
    https://dashcamtalk.com/forum/threads/toyota-4runner-rear-camera-mount.29476/
    Here is another one...
    https://www.blackboxmycar.com/blogs/news/37054721-toyota-4runner-2-channel-dash-cam-installation
    7385 and Backslider like this.
  3. Dec 16, 2018 at 3:38 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    I have a vanture on the dash, it does the front, and in cabin, and use the OEM piped to my to my kenwood for anytime full rear.....
  4. Dec 17, 2018 at 5:29 PM
    enoren
    I appreciate the links WallyT
  5. Dec 17, 2018 at 5:47 PM
    WallyT4R
    WallyT4R New Member
    you are welcome :thumbsup:
  6. Mar 13, 2020 at 12:52 AM
    9runner
    9runner New Member
  7. Mar 13, 2020 at 12:28 PM
    Braves95
    Braves95 New Member
    David
    2019 Nightshade Special Edition MGM
    None Yet!!
    Here is my setup. The blackvue as well.
    @enoren
  8. Mar 14, 2020 at 6:57 AM
    Braves95
    Braves95 New Member
    David
    None Yet!!
    It's a great setup. Took a while to run the rear camera wire. But in the end looks great.
    :worthless:
    7385 likes this.
  9. Mar 16, 2020 at 9:58 AM
    toy33
    toy33 New Member
    T. Batey
    CA: OC LA SD BB
    2024 TRD Pro Tundra - Terra
    PPF Front end hood, grill and headlights
    This is the Momento M4 rear camera … the shop that installed just drilled a hole in the camera plastic base and used existing oem tab to secure. Been holding up great and can remove anytime and no-one would be the wiser.
    Slimwood Shady and 7385 like this.
  10. Mar 16, 2020 at 10:09 AM
    toy33
    toy33 New Member
    T. Batey
    CA: OC LA SD BB
    7385 likes this.
  11. May 25, 2020 at 12:43 AM
    tmjones
    tmjones New Member
    Trevor
    2019 Limited
    None yet, need ideas!
    I purchased the VanTrue T2 dashcam and so far its been decent, good enough to keep. I have it connected through the ODB as this cam has 24/7 recording when it detects motion.
    I'd like to get another cam for the back to record what is going on behind the vehicle, mainly for getting rear-ended while driving or while parked if anyone backs into the vehicle. However, for this to happen, it will need to have power when the vehicle is off.
    I cant run an additional camera to the ODB as its already in use. So my questions:
    1) how can i use the USB in the rear to power the came when the car is off?
    2) are there other options to keep a cam powered 24/7?
    2019 Limited 4Runner.
    Link to the VanTrue T2 - https://www.amazon.com/gp/product/B07DV9DHVR/ref=ask_ql_qh_dp_hza
    Thanks!
  12. May 25, 2020 at 11:27 AM
    PandaKyle
    PandaKyle New Member
    2019 Toyota 4Runner SR5
    I have a Rexing V1P in my T4R which is hardwired to the battery so it is always recording. It doesn't draw so much power that I've had an issue with a dead battery, and have been running this setup for about a year so far. I installed a Rexing V1LG in my folks vehicle which has a rear facing camera. Wired it the same way, so it's always recording front and rear, and they haven't had issues with a dead battery for the 2ish years it's been installed. To answer your question about the USB port being powered while the vehicle is off, it would have to be overridden in order to function as such. I'm sure you could do it, but it might be easier to just run a live wire to the rear and either hardwire the cam, or create an always live port that you could tie into.
  13. May 6, 2022 at 3:31 PM
    BLACKT4RPRO
    BLACKT4RPRO New Member
    Johnny
    2019 4Runner TRD Pro
    Did you have to drill into the headliner to install? Would love to know where you purchased the mounting bracket and how you wired the rear camera.
  14. Jul 1, 2023 at 12:11 PM
    atk411
    atk411 New-ish Member
    Orange County, CA
    2022 Barcelona Red Off Road Premium
