Icon Squeak
Discussion in 'Suspension' started by Dillusion, Oct 6, 2021.
  1. Oct 6, 2021 at 10:29 AM
    Dillusion [OP] New Member
    KYle
    I know most aftermarket stuff will squeak. But this is more than a squeak its sounds like something dying at low speeds.
    Took the bolt out and the bushings. Greased every damn part. Put it back together and its worse!
    Had the wife use a jack under the LCA and it does sound like its coming from the UCA and nothing else. About to throw these POS in the trash.
    Less than 5k miles on the suspension over couple years and greased every oil change.
  2. Oct 6, 2021 at 10:47 AM
    Mtbpsych
    Mtbpsych New Member
    Have you tried checking the bushing on the UCA? Or are they stock?
  3. Oct 6, 2021 at 10:53 AM
    KYle
    Its the Icon bushings that come with the UCAs.
    Took um out and greased them again then greased through the zerks when I put it back. I guess I could order new ones and try.
  4. Oct 6, 2021 at 11:02 AM
    EffinNewGuy
    EffinNewGuy Completely clueless
    Southeast
    Absolutely nothing
    Wasn't there something within the past year where Icon stated they know their UCA's have issues with bushings and were replacing them?
    Or was that another company?
  5. Oct 6, 2021 at 11:02 AM
    Mtbpsych
    Mtbpsych New Member
    My UCA bushings went bad a couple months ago, horrible squeaking. Got new ones under warranty, problem solved.
  6. Oct 6, 2021 at 11:05 AM
    KYle
    Do I contact Icon direct or do I need to go through my local store?
    If I have to deal with back and forth I'll just pay for the new ones because its annoying as hell.
  7. Oct 6, 2021 at 11:09 AM
    Mtbpsych
    Mtbpsych New Member
    I have SPC so no experience with icon. I contacted SPC directly though, they verified I ordered through an authorized retailer and the process started. Took about a day to get everything squared away, got a core charge for the new ones, sent old/bad ones back, refund. SPC did send me an entire new UCA minus the ball joint FYI. Not sure if icon would do the same.
  8. Oct 6, 2021 at 11:11 AM
    KYle
    Screw it I just bought um.
    The store I got them from closed down and I guarantee I didn't keep my receipt. $70 for some quiet I hope.
  9. Oct 6, 2021 at 11:16 AM
    Polyurethane bushings I'm assuming?
    What grease are you using on them?
    If you're not using silicone grease, you should consider trying it.
  10. Oct 6, 2021 at 11:28 AM
    KYle
  11. Oct 6, 2021 at 12:23 PM
    kbp810
    kbp810 rebmem wen
    Uniball or Delta Joint arms? I assume Delta Joints as no mention of Uniballs was made (as they would have also been a likely source of the squeak; as is often the nature of Uniballs)
  12. Oct 6, 2021 at 1:04 PM
    KYle
    Delta Joints.
    I've move the joint around by hand when I had the UCA disconnected with no noise but its not bearing any weight then either.
    Guess I'll take a look at that as well
    kbp810 likes this.
  13. Oct 6, 2021 at 1:42 PM
    kbp810
    kbp810 rebmem wen
    Should be good if it’s the delta joint; but doesn’t hurt to rule it out. My ask was more of a, “if you happen to have uniballs, then those are almost definitely the source” kind of thing, lol.
  14. Oct 7, 2021 at 7:48 AM
    Perhaps the green grease is drying your bushings out over time.
    Here's why a silicone based grease is better on poly bushings. It explains how they dry out when using some alternative grease products.
    https://www.suspension.com/blog/the-best-grease-for-polyurethane-bushings/
  15. Oct 7, 2021 at 9:58 AM
    KYle
    Any recommendations? I only use it because I saw others using it in other threads. I have no problem switching since new bushings are on their way.
    Orileys is the closest to me. I see Moly grease but nothing that says silicone.
  16. Oct 7, 2021 at 10:07 AM
    KYle
  17. Oct 7, 2021 at 1:18 PM
    I would personally use this over the Red and tacky. Red and tacky is lithium based and this one is silicone based with PTFE. It will last longer on poly bushings without eating them.
    screen-shot-2019-07-09-at-1-32-43-pm-png_b2753c8179eb3c7a26ebcfc2f1166cf4d3f3aede.jpg
    Kfish and kbp810 like this.
  18. Oct 7, 2021 at 1:21 PM
    kbp810
    kbp810 rebmem wen
    Yep, this ^^^ a PTFE/Teflon based grease works best on poly bushings. Super lube is the best priced and most readily available of those.
    LandCruiser and nimby like this.
  19. Oct 7, 2021 at 1:24 PM
    And you can eat it :hungry:
    LandCruiser and kbp810 like this.
  20. Oct 7, 2021 at 1:32 PM
    KYle
    Go figure Oriley doesn't carry. Guess I gotta find someplace else.
  21. Oct 7, 2021 at 2:39 PM
    kbp810
    kbp810 rebmem wen
    Oddly enough, I've found it at my local Ace Hardware. If you've got an Ace nearby, I'd try there.
  22. Oct 7, 2021 at 2:57 PM
    KYle
    NAPA has it.
    Home Depot Nope
    Lowes Nope
    Ace Nope
    Welcome to Hawaii.
    LandCruiser likes this.
  23. Oct 18, 2021 at 6:02 PM
    KYle
    Ok well I'm about to throw these ICON POS things in the trash.
    - New bushings drivers side only
    - I used Red N Tacky since NAPA said they had super lube but of course they didn't. And it was recommended by Icon.
    - Lubed the hell out of the bushing before installing
    - Lubed through zerk
    - Tightened to 85 ft/lb with wheels on the ground
    The m'fer still squeaks or should I say squeals. And its only the drivers side. Passenger side I didn't change since it doesn't make a single peep.
    Any last ditch ideas before I change UCAs? I do notice the ICON emblem on the new bushings and the old ones do not so I'm assuming I got the new ones.
  24. Oct 19, 2021 at 8:28 AM
    kbp810
    kbp810 rebmem wen
    Give it a few more days of driving to see if the squeak starts to disappear before losing all hope; could just need a little break in time. Also, maybe could try some boeshield T9 or Triflow and spray the ends of the arms where bushing meets the coil bucket, and also maybe your lower bushings, just for good measure.
    Sorry to hear they're still being a PITA; chasing squeaks can be a persistently annoying choir.
  25. Oct 19, 2021 at 10:06 AM
    KYle
    I don't mind a squeak but this is way more then that.
    I gotta find someone that will send Boeshield here.
