Icon 2.0 rear shocks questions
Discussion in 'Suspension' started by Hwnrunner, Mar 16, 2019.
  1. Mar 16, 2019 at 12:06 AM
    Hwnrunner
    Hwnrunner [OP] New Member
    Hawaii
    2019 4Runner SRS Prem 2wd
    TRD Pro Struts/ Coils, Toytec 1" spacer, Dobinsons C59-505 Springs,TRD Pro Sema Wheels, TRD Pro Lower Valances, Ceramic Tint
    Found a great deal on a pair of Icon 2.0 shocks for the rear, and it bothers me to look at the box in the garage. I was wondering if ok to install on a stock 0 lift suspension as I wait on the other components I plan to add soon. Icon states 1-3 inch, but others like Eibach & Bilstein say 0-1 or 0-2. Is it ok to run these at 0 for a while? Any harm?
    Icon_Adrian likes this.
  2. Mar 16, 2019 at 3:11 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    I don’t see why not. You shouldn’t gain lift from the shock itself and as it states from 0-whatever you’ll be with in their specific range
    Enjoy- will be a better ride
    Hwnrunner[OP] likes this.
  3. Mar 16, 2019 at 5:20 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Put them on. Won’t hurt a thing.
    Hwnrunner[OP] and scottalot like this.
  4. Mar 16, 2019 at 12:37 PM
    Hwnrunner
    Hawaii
    thanks for the feedback, had to edit my first post typo, the Icon is 1-3 " of lift, not 0. I'll definitely install this weekend, looking forward to the better ride.
    SlvrSlug likes this.
  5. Mar 16, 2019 at 2:45 PM
    Hwnrunner
    Hawaii
    couldn't wait, the Icons are on! Took for a shake down test drive.... WOW, I know it's mostly mental but it does feel less loose and nose dive is almost gone. Can't wait to upgrade the front. I watched a bunch of utube install vids, nothing really great. The main key is to know to hold the oem shock shaft from spinning while loosening the top lock nut with locking pliers or whatever you have on hand. Get your self a offset 17MM & 19MM (ICON NUT) ratchet wrench. It saves a lot of time. Install skill level 1 -5, it's like a 1.5!
    Icon_Adrian, HoBoDanny and SlvrSlug like this.
  6. May 22, 2019 at 3:20 PM
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riversdie CA
    It's likely you will never experience a problem on day yo day driving conditions but the 56505 shocks provide a good amount of additional travel. So much in fact that at full extension the coil spring can come loose, now this was tested and confirmed in an off road setting (similar to this). You do have the option of adjusting the extended length of your shock to fit a stock coil spring and rest easy knowing your shock it not too long. I can get you that part numbers and a point of contact for you nearest service center.
    Feel free to reach out if you have any questions.
  7. May 22, 2019 at 7:00 PM
    Hwnrunner
    Hawaii
    I added a Cornfed 1" spacer for the rear springs shortly after. Should be ok?
    Icon_Adrian[QUOTED] likes this.
  8. May 23, 2019 at 8:46 AM
    Icon_Adrian
    Adrian
    Riversdie CA
    With a 1" spacers you are okay.
