I swear, I tried to find the thread about recovery points
Discussion in '5th Gen 4Runners (2010-2024)' started by peter2772000, Mar 26, 2020.
  1. Mar 26, 2020 at 4:26 PM
    peter2772000
    peter2772000 [OP] New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    The loops under the front end of my 2019 are supposedly only good as tie-downs for transport, not to use to pull stuck vehicles. There's a set of brackets I saw on this site which bolt to the frame and allow shackles to be connected to them.
    I have used the search function, I swear. Anyone? Please?
  2. Mar 26, 2020 at 4:27 PM
    Dillusion New Member
    KYle
  3. Mar 28, 2020 at 3:51 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Thank you so very much. I owe you a beer. Ordering as soon as I finish typing this....
  4. Mar 28, 2020 at 5:17 AM
    The search function on this forum doesn't always work very well. Usually, you're better off Google searching the keywords you're interested in followed by 4runners.
  5. Mar 28, 2020 at 5:24 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Gotcha, thx for the heads-up!
  6. Mar 28, 2020 at 7:21 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    '24 ORP
    I haven't snapped a loop yet, I think the aftermarket ones are an answer in search of a question, but it's not my money...
    Jynarik and Thatbassguy like this.
  7. Apr 1, 2020 at 3:35 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    I dunno man. I think it depends largely on how/what you're pulling out. Slowly pulling out a 3,000 lbs compact out of a snow bank probably wouldn't cause any damage. Pulling out a 5,000 lbs SUV stuck in mud, especially if taking a running start....not quite so sure.
    Using my rad support to help pull a stranger out of a ditch scares me, I'd rather err on the side of caution.
    WallyT4R likes this.
  8. Apr 1, 2020 at 7:40 AM
    MeefZah
    Lexington, Ohio
    '24 ORP
    You shouldn't be pulling like that in reverse anyway. I wouldn't use a kinetic strap on those loops, either. I'm referring to self recovery with a winch and a snatch block doubled back to a frame loop.
  9. Apr 1, 2020 at 8:52 AM
    KYle
    Works perfectly fine IF you know what you are looking for.
  10. Apr 1, 2020 at 9:36 AM
    Seeing as how your initial search attempts fell short, how about helping the next guy/gal out with theirs? In the interest of someone else searching this subject, how about changing the thread title to something more appropriate to the subject being discussed, rather than "I swear I really tried, really"...just a suggestion.
    Roberge01 likes this.
  11. Apr 1, 2020 at 10:39 AM
    Still not as well as Google...
  12. Apr 1, 2020 at 11:57 AM
    KYle
    He didn't even know them as recovery points. Thats why it didn't work.
    Sometimes I draw a blank to what stuff is called and search sucks ass.
  13. Apr 1, 2020 at 12:15 PM
    Right. Even when searching specifically for recovery points, there was only 1 result. Meanwhile, a Google search turned up multiple results from this forum.
    I definitely agree that you're pretty much screwed if you don't know what something is called.
    I've even tried to find threads by title and it seems like Google is usually more effective.
  14. Apr 1, 2020 at 12:54 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Done!
    You have to put yourself in my shoes. "Oh Christ, here's yet another newb who asks questions without even trying the Search function." I've seen it many times on other sites, so I was jez trying to warn others that I really had tried. ;)
  15. Apr 1, 2020 at 1:07 PM
    KYle
    Not to turn this thread into a how to on the search but need to use the filters better on the site. Instead of searching for 5th gen recovery point. Just search recovery point and change the search section to 5th gen.
    The more you type in the less results you will get.
  16. Apr 1, 2020 at 1:40 PM
    Why not? The OP states that he was unable to find what he was looking for using the search feature.
    You are correct! I will keep this in mind. :)
  17. Apr 1, 2020 at 8:48 PM
    Someone will benefit from the change, thanks. Been there, done that, on asking a question that seems everyone knows the answer to but you. Fortunately, I don't see a lot of "WTF are you asking THAT for???! Did you search??" on this forum. Much more civilized around here...
  18. Apr 1, 2020 at 9:33 PM
    WallyT4R
    WallyT4R New Member
    I don't even bother with the search feature here and always use google. Just include 4runners.com along with the key words and usually have great luck finding what I was looking for.
    peter2772000[OP] and Thatbassguy like this.
