I ran my electrical for the accessories (Questions inside)
Discussion in '5th Gen 4Runners (2010-2024)' started by fjrunner, Jul 5, 2019.
  1. Jul 5, 2019 at 8:14 PM
    fjrunner
    fjrunner [OP] New Member
    Michael
    Clarksville tn
    SR5 4X4
    Open to ideas
    Parts
    10 Tons Hydraulic Wire Battery Cable Lug Terminal Crimper
    #4 awg battery cable
    Heavy Duty Wire Lugs Battery Cable Ends Bare Copper Eyelets Tubular Ring Terminal Connector
    Shrink Tubing
    Blue Sea Systems Fuse Blocks
    TE tyco 75 Amp High Current 12 Volt Automotive Relay SPST
    Blue Sea Systems 187 Series, 285 Series & Klixon Circuit Breakers
    #12 awg wire
    10-12 ring connector's
    Wave Type Split Loom Tubing Conduit
    Tap a fuse
    After all the work I am having a challenging time finding real estate for my switches.
    Can you please post pictures of your aftermarket push buttons/ rocker switches and the location.
    Did you make a new hole in the firewall where the 200 wires are coming through on the driver side for control wires or did I miss a grommet somewhere else?
    Thank you
    WallyT4R likes this.
