I have a 2016 Trail Edition with 211,000 miles.
Discussion in '5th Gen 4Runners (2010-2024)' started by SkiSun2405, Oct 30, 2025.
  1. Oct 30, 2025 at 11:42 AM
    SkiSun2405
    SkiSun2405 [OP] New Member
    2016 4Runner Trail
    For several months now it will idle between 500-700 RPM. I had it tuned up by local Toyota dealer at around 150K. What would fix this?
  2. Oct 30, 2025 at 2:06 PM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    You likely have a vacuum leak somewhere, but it is hard to diagnose over internet.
    Find a reputable independent garage and take it there. Stay away from dealerships, they will overcharge you and perform unnecessary repairs.
  3. Oct 30, 2025 at 2:11 PM
  4. Oct 30, 2025 at 2:15 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Dealers, in my opion, only replace suspect malfunctioning parts with new same parts. You pay labor and parts price even if replacement does not provide fix.
    For a an evaluation/assessment find a quality independent shop.
  5. Oct 30, 2025 at 2:38 PM
    Nice. Make sure to get your 200k mile sticker from Toyota! I just got mine a couple weeks ago, I'm at 202k on my 2013.
    Mr.DRZ and Rocko9999 like this.
  6. Oct 30, 2025 at 3:24 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    In park, In drive, Warm, Cold? Do anything to it lately?
  7. Oct 30, 2025 at 5:50 PM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Clean the MAF and throttle body. Couple good YouTube videos on it. One is by the Care Care Nut.
  8. Oct 30, 2025 at 6:19 PM
  9. Oct 30, 2025 at 7:51 PM
    What's a "tune up" on a vehicle built after the turn of the century with distributorless ignition? Spark plug replacement and throttle body cleaning? Did the high idle begin right after the dealer service?
  10. Oct 30, 2025 at 7:54 PM
    I would start with cleaning the throttle body. Get some Seafoam spray and a toothbrush and clean the carbon off of it.
  11. Oct 30, 2025 at 9:30 PM
    OP stated he is experiencing 500-700 RPM at idle. Considering normal is around 600-800 after warmup, I wouldn't characterize his as high.
    Rocko9999 likes this.
  12. Oct 30, 2025 at 9:59 PM
    ^ @SkiSun2405 can try a throttle relearn then:
    1. Disconnect negative battery terminal, wait ~30 sec then reconnect negative battery terminal.
    2. Turn the ignition key to ON or press the Start button twice, without starting the engine, to let the butterfly valve cycle.
    3. Turn the ignition key to OFF or press the Start button again to turn off electrical power.
    4. Start engine as normal.
