I flubbed a roof rack install.....and have a TRD Pro rack for sale
Discussion in '5th Gen 4Runners (2010-2024)' started by BoldBrass, Apr 26, 2020.
  1. Apr 26, 2020 at 8:26 PM
    BoldBrass
    BoldBrass [OP] New Member
    Scott
    2020 TRD Pro Army Green
    Prinsu Roof Rack Rago Fab Storage Panels
    Hey there Fam, newbie here.
    Heres an album above (or pictures below!) of what im talking about,
    https://imgur.com/a/v25I8R6
    First picture is just my Pro with my girlfriend hanging off the rack, next is the new prinsu rack I installed today, the third picture is from another user here showing the White Plastic Inserts on roof rack attachment points, and, the 4th picture is showing one of my mounting points missing those plastic parts. Long story short, they broke off during the removal of my pro rack.
    I found this spare part https://www.toyotapartsdeal.com/oem/toyota~bracket~roof~rack~rear~63187-35020.html and ordered two of them, issue is, I cant tell if they come with the White parts (which are what I need I need t the screws to bite), and need to remove my headliner or not to install them, and I don't think im good enough to pull the headliner if needed....
    Last but not least, the detached pro rack. EDIT: I cant sell the rack yet because I need to reach the minimum required post amounts, check the market place at a later date!
  2. Apr 26, 2020 at 8:28 PM
    BoldBrass
    Scott
    TLDR: I broke the white plastic bits for one of the four brackets, and they appear to have fallen into the headliner. Now I don't know what to do, kinda nervous that I wont be able to fix this or I ordered the right replacement part for the plastic white bits. Any help appreciated!
  3. Apr 26, 2020 at 9:06 PM
    Welcome to the forum!
    I can't help you with your problem, unfortunately. I thought I would mention that there is a minimum amount of posts required before attempting to sell things here.
    https://www.4runners.com/threads/4runner-marketplace-rules.1410/
    Good luck with your roof rack installation! Hopefully someone here will have some good advice for you.
    BoldBrass[OP] likes this.
  4. Apr 26, 2020 at 9:11 PM
    BoldBrass
    Scott
    Thank you for letting me know! I will delete the portion of the post that talks about selling the pro rack, and thanks for the well wishes
  5. Apr 26, 2020 at 9:16 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    That sucks. I had one side drop down and had to remove some of the sealing to get it out. Factory bolts were on so damn tight with red loctite
  6. Apr 26, 2020 at 9:18 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I think you can just reach in and re-install the clip. The new ones does include the white tubes. Either old one or new ones will work.
    Oldtoyotaguy likes this.
  7. Apr 26, 2020 at 9:18 PM
    BoldBrass
    Scott
    Did you have to remover your headliner? Just trying to get an idea of how you fixed it
  8. Apr 26, 2020 at 9:20 PM
    BoldBrass
    Scott
    Datonaviolet YOU'RE MY HERO. I was stalking your old posts (check your DM's lol) and that's what encouraged me to make an account and start posting. I bought these https://www.toyotapartsdeal.com/oem/toyota~bracket~roof~rack~front~63185-42020.html …. but, do you know if I can drop them in from the top? or do I need to remove the headliner to replace the plastic parts from underneath the roof?
  9. Apr 26, 2020 at 9:22 PM
    Daytonaviolet
    Bay Area, CA
    I actually never had this issue. There’s a procedure on how to remove these bolts so the clips don’t fall off
    which corner clip fell off ? was it the driver side rear? if so, just open tailgate and list on the rubber moulding. you'll need a panel remover tool and pop out the headliner clip. but i think you may need to remove some plastic too.
  10. Apr 26, 2020 at 9:32 PM
    BoldBrass
    Scott
    Yeah I saw that after I made the mistake, impact hammer was a no no but there was so much locktite on the bolt I didn't really have a choice. The clip that fell off was the rear driver side bracket
  11. Apr 26, 2020 at 9:33 PM
    Daytonaviolet
    Bay Area, CA
    yeah you got to remove the headliner in that area :(
  12. Apr 26, 2020 at 9:41 PM
    BoldBrass
    Scott
    Okay good to know! Not the end of the world I hope, do you know how difficult it is to remove the headliner? Is it a safe install / uninstall, or is it something left to a dealership?
  13. Apr 26, 2020 at 9:47 PM
    Daytonaviolet
    Bay Area, CA
    Personally I never removed the headliner on the 4runner. But it looks simple enough. if your able to install the rack, headliner removal should be simple.
    BoldBrass[QUOTED][OP] likes this.
  14. Apr 26, 2020 at 9:51 PM
    BoldBrass
    Scott
    ;) famous last words. Ill have to give a shot, if I do this right ill post an update. Looks like ill have to remove my Rago shelf system too which makes this a much larger pain
    mdmglobal likes this.
  15. Apr 26, 2020 at 10:10 PM
    Daytonaviolet
    Bay Area, CA
    Yes. Tear down so you can access that area.
  16. Apr 26, 2020 at 10:15 PM
    BoldBrass
    Scott
    To be clear though, I can still access this area, do I still need to tear it down? Corner headliner.jpg
  17. Apr 26, 2020 at 10:25 PM
    Daytonaviolet
    Bay Area, CA
    The clip you need to access is somewhere on the other side of the head liner. You’ll need to remove that plastic area and drop the head liner. Once that is done, you should be able to find the fallen clip and re-install it.
  18. Apr 26, 2020 at 10:29 PM
    BoldBrass
    Scott
    Gotcha thank you!
  19. Apr 27, 2020 at 3:19 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    That’s suck Scott. That pic is from my install showing the white tubes. There might be other info on removing headliner on the other Toyota.org web site. You are not the first this happened to. I cannot help not sure about removal of liner.
  20. Apr 27, 2020 at 3:41 AM
    RusPro17
    Don
    Pa.
    Hey Scott, Trying Looking thru this post. This is from the other Toyota site. There are other posts on this. It will probably help you out.
    KSJ08 likes this.
  21. Apr 27, 2020 at 6:23 AM
    fiftyxp
    fiftyxp New Member
    why not go ask a dealership for the part numbers? especially since you have 1 part number already you can ask them about it and see what else comes with it.
  22. Apr 27, 2020 at 6:25 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    I just installed a Front Runner rack on my 4 Runner the other day, and when I was doing it, I imagined that this could happen as I was removing the OEM rack. The problem is the red loctite on the bolts and the nut clip moves and wiggles as you ratchet out the bolts. I just tried my best to keep everything from rocking back and forth with the ratchet, and it all worked out. Ok, having said all that, what to do? If you go to you tube you will see how various installs removed the headliner. At the back of the truck, Victory has one for their camera relocate kit, for example. Front Runner has one that removes the front section for their full length rack, where you need to drill holes in the roof. As someone said already, just be careful, and use a proper panel removal tool so that you don’t damage anything. All those panels pop off, and it’s not a difficult job to fix the problem. Good luck BoldBrass!
    Shit happens all the time, no big deal!
  23. Apr 27, 2020 at 6:32 AM
    fiftyxp
    fiftyxp New Member
    BoldBrass[OP] and Oldtoyotaguy like this.
  24. Apr 27, 2020 at 6:36 AM
    Oldtoyotaguy
    That’s it, fiftyxp, but I think he has the part, it’s just rattling around somewhere inside the headliner, likely right below where it became detached. I’m not sure how these parts are attached but once you pull the headliner down a bit, it should possible to hold it in place while someone threads a bolt from up top.
  25. Apr 27, 2020 at 7:23 AM
    Agent_Outside
    Built 2011 T4R Limited
    That stinks that you went from the worst OEM rack to the worse aftermarket rack, but on the bright side it’s pretty simple to partially drop the headliner to access that area. The interiors on these things are put together like legos inside, super simple to disassemble/reassemble. Where are you located, I might be able to help you out?
    BoldBrass[OP] and Wvmoonshiner like this.
  26. Apr 27, 2020 at 11:20 AM
    BoldBrass
    Scott
    So glad to hear your front runner rack install went well! Yeah I think that I can tackle this no problem, I just need to deploy a little patience and work eithic. Appreciate your reccomendations! :cheers:
    Oldtoyotaguy[QUOTED] likes this.
  27. Apr 27, 2020 at 11:22 AM
    BoldBrass
    Scott
    Appreciate you taking such a clear picture of the tubes! Let me take a peek here and see what I can learn from it :D, appreciate you taking the time to help me out here!
  28. Apr 27, 2020 at 11:24 AM
    BoldBrass
    Scott
    haha, bummer to hear you dont like the prinsu racks. Ive heard they are pretty decent and I wasn't prepared to drill new holes. To each their own though. Thats comforting to hear in regards to whats underneath the headliner. once the parts come in this shouldnt be too difficult of a fix
    grizzlypath likes this.
  29. Apr 27, 2020 at 11:27 AM
    BoldBrass
    Scott
    Perfect! the part itself broke when removing the factory screws (way to much locktite to salvage the plastic bits) but I have two replacements on the way. Good to know im not crazy here, I was hoping I could find those plastic parts separately and just drop them in from the top but getting it up into the headliner is just as easy I guess
  30. Apr 27, 2020 at 11:49 AM
    Daytonaviolet
    Bay Area, CA
    I opened mine up to take a look. It’s doable. I just removed two liner clips, hanger clip has 10mm bolt, and the plastic just pulls off.
    Spare Parts, Sothras, ForRun and 4 others like this.
