Humming while I drive 35 to 45
Discussion in '5th Gen 4Runners (2010-2024)' started by Scubba rubba, Jun 4, 2022.
  1. Jun 4, 2022 at 5:06 PM
    Scubba rubba
    Scubba rubba [OP] New Member
    2019 4runner
    Lifted
    Hey was curious if any one knows about a humming noise almost like a loping noise while I drive but stops when I go over 50? I did replace the needle bearing for a bushing and was curious on what else it could be?
  2. Jun 4, 2022 at 8:35 PM
    Mtbpsych
    Mtbpsych New Member
    Could be the infamous vibration that the 4Runners get, or your tires. I get a humm/vibration at lower speeds but goes away at highway speeds.
  3. Jun 4, 2022 at 8:49 PM
    Scubba rubba
    2019 4runner
    Lifted
    I had the stock tires on before I up graded, would a front diff drop help or is it any serious issue?
  4. Jun 4, 2022 at 9:29 PM
    Mtbpsych
    Mtbpsych New Member
    You could try it, cheap and easy enough to test. I have one and it definitely helped bring the cv angles closer to stock.
  5. Jun 5, 2022 at 4:06 AM
    Daddykool
    This started after a tire upgrade?
  6. Jun 9, 2022 at 4:35 PM
    Scubba rubba
    2019 4runner
    Lifted
    Alright ill check into to and yea right after the lift it started and I only have around 50k miles.
  7. Jun 9, 2022 at 4:36 PM
    Scubba rubba
    2019 4runner
    Lifted
    And no it was doing it right after the lift with my stock tires.
  8. Jun 10, 2022 at 11:11 PM
    How did you lift, and how high?
  9. Jun 11, 2022 at 8:20 AM
    Scubba rubba
    2019 4runner
    Lifted
    I just did a 3in suspension lift kit.
  10. Jun 11, 2022 at 11:24 PM
    Next time it’s making the noise, check to see if it goes away if you put into 4hi. Although, with the new bushing, I wouldnt expect that’s the sound. Did you do the bushing at the same time as the lift? If not, was it making the sound after the bushing install?
    If you drove the bushing too deep into the diff, it can cause noises if it ends up contacting rotating parts in the diff. Hopefully its not that.
    The noise could be coming the driveshafts/pinion angles, wheel alignment, a bad wheel bearing unrelated to the lift…
