Humming Sound
Discussion in '5th Gen 4Runners (2010-2024)' started by Johnny99, Dec 23, 2022.
  1. Dec 23, 2022 at 1:16 PM
    Johnny99
    Johnny99 [OP] New Member
    2022 4runner sr5
    Hey I am new here and I have a little issue with my 4runner.
    I have a 2022 4runner which I got in may and it has 8000km on it.
    At 7000km I needed a new front differential. Had a humming sound coming from the front and I could feel some vibration.
    After a week of driving with the new front diff the humming sound came back when I drive at speeds 50kmh and up. Also when I exelerate to 110kmh and get off the gas and let it roll it humms like I have offroad tires on it. The 4runner is all original nothing modified.
    I tried 4x4 and there was no humming sound.
    Had it at the dealershio again and they could not find anything. They blamed it on the cold weather. Don t think thats the issue as it is the same at plus degrees.
    Anybody out there that experienced something like this too??
  2. Dec 23, 2022 at 1:20 PM
    Bad diff needle bearing. Very common.
  3. Dec 23, 2022 at 1:45 PM
    Yup. Mine did it on the drive home from the dealership brand new. The cold weather shouldn't be an excuse the dealer uses to get out of it, even though it’s true it happens in cold weather. In my case, it only happens in cold weather. Well, “happened”…because my noise is almost completely gone at this point after 39,000 miles.
    Search “needle bearing”. There are some good threads here that will give you all you need to know.
    After you read up you’ll understand your options better. Which will basically be:
    -having the dealer keep replacing diffs and maybe eventually getting one with a needle bearing that stays quiet.
    -just cut to the chase and have the needle bearing in the diff replaced with the ECGS bushing. This has solved the problem for good for everyone who has done so. The dealer will not do this.
    djwantke, DirtyHairy and Johnny99[OP] like this.
  4. Dec 23, 2022 at 2:16 PM
    Johnny99
    2022 4runner sr5
    Thanks for the reply's guys. Very helpful.
  5. Dec 23, 2022 at 6:46 PM
    2018’ SR5 w/ 31k miles. No humming yet.
  6. Jan 9, 2023 at 6:03 PM
    Johnny99
    2022 4runner sr5
    So, I just picked up my 4runner after they replaced the front diff for the second time. The humming sound is still there and I think even worst than before. Might have to follow Mcspazatrons advice and just get the needle bearring replaced.
    djwantke likes this.
  7. Jan 16, 2023 at 11:03 AM
    Johnny99
    2022 4runner sr5
    I guess Toyota finally put a stop sale order on the front diffs and they produce a whole new batch which is available in around 3 month. According to the Dealership.
  8. Jan 16, 2023 at 11:07 AM
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    I would be pretty aggravated if I had a brand new defective front differential installed and then tossed around like it’s normal. I noticed mine at 100 miles, replaced at 950 and was good when sold at 7,000. Hopefully stays good for the next owner!
  9. Jan 22, 2024 at 6:01 AM
    Johnny99
    2022 4runner sr5
    So In september 2023 they put another front diff in
    Should have been a new batch they said. It went again just before christmas. In the shop now for another new one. Is it worth getting the dealership to involve toyata ?? The dealership would have to start the paperwork to vet the factory/toyota involved.
  10. Jan 22, 2024 at 6:33 AM
    Daddykool
    I have a question on that, as I may need this fixed, too. My 2019 is at 130k miles, and it's making noises that hint toward the needle bearing. My tech brain tells me a needle bearing assembly will roll on its shaft (CV axle), keeping wear to a minimum, whereas the ECGS bushing is a sleeve with no moving parts. In that case there are two stationary parts rubbing against each other. Maybe there's adequate lubrication to prevent wear on the bushing/axle? I'm simply curious as to how the bushing holds up longer. Do you have experience with it long-term? Thanks.
  11. Jan 22, 2024 at 6:38 AM
    You should pose your question to ECGS. I've wondered the same thing, and it seems they would be the best source for that answer.
    One thing's been verified by users of the bearing - there's much less play where the CV shaft rides in the differential with the bushing.
    Daddykool[QUOTED] likes this.
  12. Jan 22, 2024 at 6:43 AM
    Daddykool
    I don't plan to do it myself, but I've seen so many recommendations for this on the forum that I half assume it's a good long-term solution. My next step was going to be to see if the dealership would make this substitution.
  13. Jan 22, 2024 at 6:47 AM
    I've not seen anyone disappointed with the ECGS fix, but also haven't seen anyone who'd convinced a dealership to install the bushing.
    Daddykool likes this.
  14. Jan 22, 2024 at 6:52 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Cold weather irritating Issue. Will go away when its warm.
    If not fixed now whilst its cold. Forget it.
    Cheers
  15. Jan 22, 2024 at 6:54 AM
    Daddykool
    And if not, I probably won't push it. If the next needle bearing will go another 130k, that's going to take me 7 or 8 years down the road.
  16. Jan 22, 2024 at 6:57 AM
    Have you verified the noise goes away when putting the TC into 4H?
  17. Jan 22, 2024 at 8:54 AM
    Daddykool
    No, it is very intermittent and I haven’t been able to test that. It happens for a few seconds at a time. Started with this recent cold snap. So if it’s that, I’m probably in the early stages of it. I do plan to do that once I figure out how to get it to happen regularly.
  18. Jan 22, 2024 at 10:53 AM
    Tmiesowicz
    Jesus this craps still going on :laser:
  19. Jan 22, 2024 at 11:36 AM
    I don’t have personal experience with it since I haven’t installed it. A buddy who works with machining and industrial equipment told me that type of bushing used by ECGS is fairly standard for this type of application.
    The needle bearing should support the axle shaft evenly across the width of the needles, but I think that is essentially the problem here…they don’t because the axle has too much space to float inside bearing. My understanding is that inc4wd, the axle is driven by the diff, so it doesny float. But with 4wd off, the axle is driven by the wheel, allowing it to float around in the bearing and puts load on the ends of the needles. The ECGS bushing has a tighter fit into the axle, so loads should theoretically be distributed better across the face of bushing. Oiling is a question I have myself. But maybe this material requires less oil…not sure.
    Update on my needle bearing, the noise is back after I increased the preload/ride height on the front suspension back up (because it sagged after installation of skidplates). This needle bearing is very particular to cv angle. It seems mine is quiet when the angle is zero. Zero angle seemed to happen for me with about 1.5 to 2 in of lift compared to how mine came from the factory. I’m slightly above that now.
    Daddykool[QUOTED] and djwantke like this.
  20. Jan 22, 2024 at 11:46 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @Johnny99
    Man, I feel for you. Please continue to keep us up to date.
    @McSpazatron is a great resource
    Thanks guys, I have humming too that I don't believe is just my tires. Added a 3/2 lift, load E 285's on 9" wheels, 1.25" wheel spacers... ECGS!
    I'm actually gunna test 4wd humming difference tonight thanks for that
  21. Jan 22, 2024 at 2:23 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Are you sure they are even replacing them? I would mark them in a hidden spot and verify next time.
  22. Jan 22, 2024 at 3:03 PM
    This^
    Greasy ppl, they are
    Rocko9999[QUOTED] likes this.
  23. Jan 22, 2024 at 3:57 PM
    Daddykool
    Thanks for the explanation. Too loose a fit on that needle bearing makes sense.
