Hub Centric Wheels
Discussion in '5th Gen 4Runners (2010-2024)' started by thatchtt2001, Jun 10, 2021.
  1. Jun 10, 2021 at 7:31 PM
    thatchtt2001
    thatchtt2001 [OP] New Member
    TTT
    Northwest Ohio
    2016 Trail
    Eibach Stage 1 Shocks with OEM Springs.
    I purchased my 4runner with aftermarket wheels (XD Series) and recently purchased new tires and kept getting a slight shake over 60mph and I had two different shops try balancing four times with no luck, I then figured out that my wheels were 106.25 and when I loosened the lugs and spun it I could could see a slight gap on the hub. I took aluminum tape and carefully cut pieces and went around the hub twice without overlapping on each hub and it totally fixed it, smooth as butter... I am leaning towards getting the TRD Pro rims to go back to hub centric but I am curious if there are wheel brands that are exact at 106.1mm out there?
    babaki1 likes this.
  2. Jun 10, 2021 at 7:58 PM
    thirdyota
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    a47chuck and thatchtt2001[OP] like this.
  3. Jun 10, 2021 at 8:03 PM
    My Black Rhinos have adapters to fill the gap. Smooth as butter on the highway.
    thatchtt2001[OP] likes this.
  4. Jun 13, 2021 at 4:39 PM
    a47chuck
    a47chuck New Member
    Central Oregon
    '19 Limited Nightshade, Midnight Black Metallic, front leveling kit, 265/60-20 KO2's and Magnuson Supercharger.
    Had Stealth 6's on my '13. When the tires on my "donk" 20's need replacing, I'll be gettin' another set of Stealths in 17".
  5. Oct 10, 2024 at 6:43 AM
    babaki1
    babaki1 New Member
    JB
    2019 ORP
    I know this post is old, but I have to bump it. I have been dealing with this issue for a few weeks and this solved my problem. Method 316 wheels, 106.25mm hub bore. Bad shake at 60mph. Multiple road force balances, all said they were as good as they were going to get. I found this thread and said to myself, what the hell, I'll try anything at this point. This SOLVED my issue 100%. Thank you!
  6. Oct 10, 2024 at 8:12 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    How many layers and what brand of tape did you use?
  7. Oct 10, 2024 at 8:21 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Why not just get the correct hub bore wheels? There's literally hundreds of choices out there. This fix seems a little janky.
    Slopemaster and raimieb like this.
  8. Oct 10, 2024 at 8:40 AM
    babaki1
    babaki1 New Member
    JB
    2019 ORP
    The tape really just helps you to center the wheel, its not providing any structural integrity. Once the lugs are torqued down it doesn't matter anymore. Trust me, I thought it was stupid as well, but it absolutely solved my steering shake. I bought Method wheels because they seem to very popular in the 4Runner community. They are advertised on TireRack and the Method website as "hub centric" for 4Runner. I don't know if I am in the minority or what, but that tiny .15mm of space made a HUGE difference for me.
    I used Nashua brand foil tape, and I used 2 layers.
  9. Oct 10, 2024 at 11:48 AM
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    i read about hub centric wheels and wanted to see if that will help with my shake.. i read several articles on what size to get. i ordered some off Amazon but when I had my new tires put on a few weeks back they called and said the hub centric rings i got do not fit. i just don't have all the proper tools to take the wheel off and torque back the lugs.. i have stock size tires with TRD Pro rims.
    i went with sizwe O.D. 108mm and I.D. 106mm
    https://www.amazon.com/dp/B09SYV988L
    i'm still trying to find out a resolution for this..
  10. Oct 10, 2024 at 12:06 PM
    I’m pretty sure if those are stock TRD Pro wheels that they’re already hub centric. If so, you wouldn’t need the rings, because the wheel would fit perfectly over the hub.
    j4unner[QUOTED] likes this.
  11. Oct 10, 2024 at 12:11 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    i changed out these rims.. it came with the stock rims, when i purchased the 4R..
  12. Oct 10, 2024 at 12:45 PM
    Are the wheels you have now OE Toyota wheels? If so, I’m pretty sure the bore would be perfectly sized. However, the bore may be oversized if they are aftermarket reproduction wheels. You would need the hubcentric rings only if the bore of the wheels is oversized.
  13. Oct 10, 2024 at 12:54 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    the silver rims and tires shown in the pic are the OE set when I purchased the 4R.. now I currently have stock tires size but AT tires and the TRD Pro bronze wheels i purchased from toyota..
    i just would have to take off the tire and measure it myself.. I read a few articles and just assumed that size they mentioned for the hub rings where the same for me as well since I had trd pro rims..
  14. Oct 10, 2024 at 2:48 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    A lot janky. But why not risk your wheel vibrating the lug nuts off while traveling 60mph+ in a 5,000lb automobile? What’s the worst that can happen.
    TAPE = NUTS!!!
    A insurance company would sue you into oblivion if you caused a wreck with tape balancing your wheels. Insane that we take these risks for aesthetics.
    catbrown357[QUOTED] likes this.
  15. Oct 10, 2024 at 3:26 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Yeah, I have Method wheels, and I bought the correct ones with 106.1mm bore.
    raimieb likes this.
  16. Oct 10, 2024 at 3:37 PM
    A toyota parts department could give you the exact bore hole specs, that way you don’t have to take off the wheels to check.
  17. Oct 10, 2024 at 3:59 PM
    babaki1
    babaki1 New Member
    JB
    2019 ORP
    The tape is not balancing the wheel. It is simply providing the ~.15mm of space to center it on the hub. That's all its doing. You can literally rip the tape out once the lugs are torqued down. Its the exact same concept as centering rings, except they don't make centering rings that thin.
    nice! which ones?
    Rocko9999 likes this.
  18. Oct 10, 2024 at 4:42 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Oh I get it buddy. Ty for the engineering report. Still a bad idea. Good luck.
  19. Oct 10, 2024 at 4:42 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Ty for being sane!!!
  20. Oct 10, 2024 at 6:32 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    309
  21. Oct 10, 2024 at 7:01 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Do us a favor and show a picture of one of your lug nuts. Reason being, even though it says "hub centric" the reality is that most aftermarket wheels are "lug centric". [​IMG]You're going to want something that looks like this that will not only seat the wheel, but center it as well. See how it's conical and then tapers to the size of the wheel stud bore? It doesn't matter if you put all of the tape in the world on the hub if you don't have the correct lug nuts. If you repeatedly hit bumps, eventually it's going to crush the tape and the wheel will move. Remember that aluminum wheels are only torqued to 90ish ft. lbs. Thats plenty to keep them on, but it's not going to prevent wheel movement around the bore.
    In my case, I not only have the correct hub bore size (106.1mm), but I also have the correct lug centric nuts. Toyota OEM are both hub and lug centric.
    j4unner, Lost Woods and raimieb like this.
  22. Oct 10, 2024 at 8:18 PM
    ace96
    ace96 New Member
    2016 Super White 4Runner SR5 premium, 2023 Solar Octane 4Runner TRD Pro
    TRD Pro wheels, TRD pro valence and grill, black out lettering.
    talk about overreacting. Seriously people run aftermarket wheels with no issues. The tape is completely unnecessary as long as you have correct lug nuts and tighten them in correct pattern. Have over 100k on aftermarket wheels on my Tacoma with no issues.
    babaki1 likes this.
  23. Oct 11, 2024 at 2:25 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    And they should be wheel or hub centric. Or needing tape. It’s not about after market or not my friend. I’m not the one missing the point here. Best of luck.
  24. Oct 11, 2024 at 6:48 AM
    ace96
    ace96 New Member
    Not exactly considering you were concerned about tape that is practically doing nothing and has no affect on the lugs.
    babaki1 likes this.
  25. Oct 11, 2024 at 7:22 AM
    Rocko9999
    2011 Limited
    Don't the OEM lugs do this already.
  26. Oct 11, 2024 at 7:35 AM
    Lost Woods
    Lost Woods New Member
    @babaki1 You also want these because Toyota studs are short to go with the mag style lug nuts from the factory. Minimum thread bite should be the width of the stud (12mm) but with my Method 701s, I was only getting 7mm in the front.
    https://www.amazon.com/gp/product/B00SF8FF86
    j4unner and babaki1 like this.
  27. Oct 11, 2024 at 7:38 AM
    Rocko9999
    2011 Limited
    Those look like the won't hit the conical part before the threads run out.
  28. Oct 11, 2024 at 7:41 AM
    Lost Woods
    Nope totally fine with about ~4mm or so clearance to the hub and I've been running them since a week after I bought my wheels. I assumed what I thought was a rounding error on the spec sheet that they were hub-centric but as they're not, these fixed my vibration.
    Rocko9999[QUOTED] and babaki1 like this.
  29. Oct 11, 2024 at 7:42 AM
    babaki1
    babaki1 New Member
    JB
    2019 ORP
    thanks! these are exactly what i have only they arent gorilla, they came from Method with the wheels but look exactly the same and are extended threads
  30. Oct 11, 2024 at 10:46 AM
    j4unner
    j4runner
    nCal
    21 SR5P
    i ordered these black lugs from toyota when I put the TRD rims on..
    not from this exact dealership but here is the part # PT0766020002
    Toyota Wheel Lug Nuts, Black Pvd Part# pt0766020002 | Toyota Of Colorado Springs Parts
    it may be possible these gorilla ones recommended, may help/fix the issues.. thanks for sharing.. i willing to try anything lol..
    might go with theses..
    Gorilla Automotive Spline Lug Nut Kit K6CES-12150BGR | RealTruck
