How wide can stock 4Runner go with tires?
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Aug 31, 2023.
  1. Aug 31, 2023 at 12:08 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Right now I am 265/70/R17 which is 10.5 inches wide I believe. I don't want a lift. I may consider new wheels if they help me get wider tires. Help!
    Thanks!
  2. Aug 31, 2023 at 12:35 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Howdy
    Prolly 275's are safe, guys say 285's with no lift or mods start to rub depending on rim width, backspace and offset. Which OEM wheels do you have?
    Cheers
    Yotaholic[OP] likes this.
  3. Aug 31, 2023 at 12:41 PM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    I have 275's and probably would fit 285's but it would be very tight, possibly running on the liner a bit.
  4. Aug 31, 2023 at 12:49 PM
    Yotaholic
    Olympia, WA
    I have TRD Offroad Premium OEM wheels and 265/70/R17 KO2s. Discount Tire is willing to take the tires back and give me wider ones. Are you folks sure 285s will not rub at full flex?
  5. Aug 31, 2023 at 12:51 PM
    San Angelo
    San Angelo New Member
  6. Aug 31, 2023 at 12:52 PM
    No one can be absolutely sure. It seems to vary by vehicle. Even the same model.
  7. Aug 31, 2023 at 12:53 PM
    Nice, ORP wheels are very sought after high quality 7.5" wide japanese wheels. I had the same wheels and sold them in two seconds on FB marketplace when upgrading to 9" wide. I didn't really know what I had at the time lol some ppl think they're a tad ugly, compared to everything on the market at least. I think most people won't guarantee you much, but will advise that you will have minor rubbing most likely
  8. Aug 31, 2023 at 12:56 PM
    Yotaholic
    Olympia, WA
    I fear a slight rub will open the pandora box, and the long dead mods' bug inside me will come alive and then you know what happens next, this nice truck will be turned into a modded nightmare, something that I am fighting with myself to not let happen.
  9. Aug 31, 2023 at 1:02 PM
    I mean my truck is a modded dream haha
    But look the only mod you'll HAVE to do, if you want wider tires as you say you do, is a minor inner front fender body trim in front of front wheels, perhaps push fender liner up/in a hair (easy), and once in a while removal of front mud guards.be prepared for these minor mods and that'll be it, reality of a 4R unfortunately, or stay stock width my man
  10. Aug 31, 2023 at 1:13 PM
    Yotaholic
    Olympia, WA
    Discount Tire says go 265/65/285 if you don't want any problems. But I have two tire choices for that particular size, Yokahama Geolander and Cooper Discoverer. How good are they compared to KO2s?
    I asked for Grabbers and Duratracs but they don't make them in that size?
  11. Aug 31, 2023 at 1:24 PM
    San Angelo
    what model of cooper discover?
    Yotaholic[QUOTED][OP] likes this.
  12. Aug 31, 2023 at 1:25 PM
    Yotaholic
    Olympia, WA
    That they didn't tell me, what model do you recommend?
  13. Aug 31, 2023 at 1:26 PM
    I had a 3/2 lift with 285’s. No rubbing issues and I got to keep the mud flaps, stock UCA’s and no BMC.
    Everyone’s experience is all over the map so I wouldn’t base your decision on any one person’s experience.
  14. Aug 31, 2023 at 1:29 PM
    San Angelo
    that depends. Are you going for
    Looks only or actual performance? It’s ok to say you want something rugged looking knowing that you are never going off-road. There are lots of 4Runners and Jeeps like that.
  15. Aug 31, 2023 at 1:31 PM
    OP wants no lift tho
  16. Aug 31, 2023 at 1:34 PM
  17. Aug 31, 2023 at 1:37 PM
    Yotaholic
    Olympia, WA
    No, that's the number they gave me lol
  18. Aug 31, 2023 at 1:38 PM
    Yotaholic
    Olympia, WA
    Looks and offroad.
  19. Aug 31, 2023 at 1:39 PM
    Yotaholic
    Olympia, WA
    Tell me the Discoveres most suited for offroad? I don't mind onroad noise
  20. Aug 31, 2023 at 2:04 PM
    San Angelo
    Rugged trek is the most aggressive in the Discover family as they are considered a hybrid / rugged terrain tire. The only other “more off-road” in that family line would be their mud terrain.
  21. Aug 31, 2023 at 2:44 PM
    Call me crazy but that's the width written twice in the same line, prolly a typo :)
  22. Aug 31, 2023 at 2:48 PM
    Yotaholic
    Olympia, WA
    Maybe I misheard them, let me call them again and get the real number lol
  23. Aug 31, 2023 at 3:08 PM
    Yotaholic
    Olympia, WA
    So it is this 285/65/R17. Cooper Discoverer comes with this.
  24. Aug 31, 2023 at 3:15 PM
    San Angelo
    Call them back and ask them for the full name on the tires they are talking to you about. Cooper is the brand and discoverer is the family. There will be a specific model i.e. DISCOVERER ATP II, DISCOVERER ST MAXX, DISCOVERER AT3 4S, DISCOVERER AT3 LT, DISCOVERER RUGGED TREK
    Then you can look up what the real size is per the manufacture.
  25. Aug 31, 2023 at 3:17 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Narrow and taller will generally yield better results off-road unless you're running on sand dunes.
  26. Aug 31, 2023 at 3:17 PM
    Yotaholic
    Olympia, WA
    He says I can take my chances with this KO2. It will also be an inch higher, so 33s basically. This will probably mess up the speedometer and sensors, and will rub. Who is here with these exact tires on a stock TRD Offroad?
  27. Aug 31, 2023 at 3:18 PM
    Yotaholic
    Olympia, WA
    I saw the Coopers they are talking about. They are no match to KO2s. I don't want them now
  28. Aug 31, 2023 at 3:22 PM
    bassist
    bassist New Member
    So I don't have those, but let me give you one piece of advice: you need to run an online tire pressure calculator when switching to LT tires. If you run the stock door pressure, they will be really under inflated and you'll possibly get vibrations.
  29. Aug 31, 2023 at 3:24 PM
    Yotaholic
    Olympia, WA
    The customer service of these guys is second to none. And you can't beat their prices either. They are willing to put these bigger ko2s on to test things out before I buy them.
  30. Aug 31, 2023 at 3:25 PM
    Yotaholic
    Olympia, WA
