How to tap into dome light
Discussion in '5th Gen 4Runners (2010-2024)' started by Emmantik, Oct 31, 2022.
  1. Oct 31, 2022 at 10:12 AM
    Emmantik
    Emmantik [OP] New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Did I quick write up on the other forum. Here's the link - Copied and pasted from the other site as requested;
    Hi all,
    Just thought I'd share how I figured how to tap to the dome light since there is no other post about it. This is for wanting to have accessory lights to turn on and off with the dome light. For me, I added footwell lights to my 3rd row as there is no lighting back there for the kiddoes.
    First off, I fished a wire from the rear right passenger headliner to the opening for the dome light. The overhead grab handle would need to be removed first. I ran the wire down the B pillar and down under the footwell trim to the rear wheel well.
    To remove the housing you can read about it in this thread; Once you remove the housing there is a small block that houses the electrical. You can pry up at 4 corners with a small screwdriver to release.
    Once off, there is a metal housing/cover that simply pops off - just pry up. I left it off after as I needed the extra space for wires/terminals.
    You can see with the red and black wires shown which side will give you power and which is ground. You will have to use your creativity here on how you tap/connect to these points - I will leave that up to you.
    So far it works like a charm! The lights I installed even dim with the dome light!
    Hope this helps anyone looking to do something similar!
    I added a strip light to the upper part of the wheel well pocket. As you can see, there is an angled portion that gives the perfect direction to aim the light. Here is a shot of the end result.
    grizzlypath, ElectroBoy and 4R Yota like this.
  2. Nov 9, 2022 at 9:47 AM
    Emmantik
    I ended up addling lights to the other side. Here is the result.
  3. Nov 9, 2022 at 11:14 AM
    Cool! Do you mind copy and pasting that right up into this thread? The other site is too full of pop-ups to use.
  4. Nov 9, 2022 at 11:17 AM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    Emmantik[OP] likes this.
  5. Nov 9, 2022 at 11:32 AM
    Emmantik
    Added it to the original post.
  6. Nov 9, 2022 at 11:33 AM
    Emmantik
    siblue[QUOTED] likes this.
  7. Nov 9, 2022 at 1:08 PM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    I wired to the rear hatch cargo lamp.
    Such a pain to run that wire thru the rear hatch.
  8. Nov 9, 2022 at 1:20 PM
    Emmantik
    Yes it is! I did the same for my rear cargo lights. I installed them on the trim covers that gives you access to the tail lights.
  9. Nov 9, 2022 at 1:25 PM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    Lights on the trim covers is a nice touch.
  10. Nov 15, 2022 at 1:21 PM
    Emmantik
    Decided to change the LED strips for an LED bolt. Bit more discreet and not super bright but enough for what I need it for.
  11. Mar 12, 2025 at 4:45 PM
    Trout1
    Trout1 New Member
    2018 Magnetic Gray SR5 Premium
    Hi,
    I think we can all agree that the 5th Gen dome light is too far forward and there should one over the actual cargo area? I wanted a simple solution that won't require rewiring the entire back cargo area. So....
    Bought a rechargeable push button LED magnetic light(attached)wireless dome light.jpg Amazon wireless dome light.jpg trim retainer.jpg via Amazon. I drilled a hole in the middle of the steel plate that was supplied and put the trim clip(attached) thru and reinstalled into the headliner. The light is BRIGHT( 10 LED's) and it's now portable. I can use it as the second dome, as a flashlight and an under hood light that is magnetized to the hood. Multitasking!
