How to Pull a stuck vehicle
Discussion in 'General 4Runner Talk' started by 4runningMan, Jan 13, 2019.
  1. Jan 13, 2019 at 6:15 PM
    4runningMan
    4runningMan [OP] New Member
    New Mexico
    if I was going to pull out a vehicle stuck in snow (in the ditch, for example)... where is the best place to hook up to the 4runner?
  2. Jan 14, 2019 at 6:51 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    As a general rule, the best place to hook up a tow strap to your vehicle is the rear tow hitch as it was designed to pull stuff. Also you do not want to hook up from the front and then reverse to pull someone out. Gears are designed to have the most strength going forward, no in reverse.
  3. Jan 14, 2019 at 6:57 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    And if you stress or certainly bend anything, STOP!! It's an SUV not a Bull Dozer.
  4. Jan 14, 2019 at 7:02 AM
    billnourse
    billnourse New Member
    Bill
    Bloomfield, NM
    2017 4Runner TRD Off Road Premium
    Toytec Ultimate lift, SSO Slimline bumper and 10,000# winch, emblem blackout, hood scoop wrap.
    Either the rear receiver hitch where I have a shackle to hook a tow strap, or from the winch depending on the circumstances.
    Bill
    4runningMan[OP] and rkwfxd like this.
  5. Mar 5, 2019 at 10:43 PM
    Yotalife
    Yotalife New Member
    Owned 1 of most
    Auto to 5 speed conversion...2nd gen. 16.5" steel wheel to 15" wheel conversion
    Length by adding or shortening can help or hurt u..depending on the scenario..
    Longer strap coming up over the Crest of the ditch is a fulcrum point creating less work..
    Short and close is more control only if ya trust the one in stranded vehicle not to hit u
