How To Adjust Ironman foam cell Pros
Discussion in 'General 4Runner Talk' started by Diegxtr, Jan 4, 2026.
  1. Jan 4, 2026 at 3:51 PM
    Diegxtr
    Diegxtr [OP] New Member
    Diego
    Hello all i recently purchased a 2020 4runner TRD Offroad Premium with the Ironman Foam Pro Cell shocks already installed. Im looking to get my 4runner Leveled due to it having a rake to it. Does anyone have any info on how many threads or turns does it take to get it leveled. Thank you
  2. Jan 4, 2026 at 4:27 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Theres no good answer here. Who ever installed them put them at a unique height.
    As far as I know youre going to need a spring compressor to adjust the height which requires removal of the coilover. You end up guessing and checking on one side until you have jt dialed in so you can hopefully just do it once on the other side.
    Diegxtr[OP] likes this.
  3. Jan 4, 2026 at 4:48 PM
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    Start with measuring the front and rear, compare to stock measurements(20" front 22" rear i believe is the stock average) center of hub to fender.
    You dont want to add to much front lift(over 3") without uca. It may be more beneficial and cost effective to change rear springs.
    nimby and Diegxtr[OP] like this.
  4. Jan 4, 2026 at 5:03 PM
    The motion ratio is roughly 5:3. Start by measuring your existing hub-to-fender heights as hossler said, to determine how much you need to raise the front. Beware there will differences left and right due to uneven weight distribution.
    To raise the front end 1", you'd adjust the spring collar up 0.6".
    tk421 and Diegxtr[QUOTED][OP] like this.
  5. Jan 9, 2026 at 11:38 AM
    Is that pic your 4runner currently? It already looks leveled.
    It’s a pain to dial in the coil overs exactly how you want, if it’s close enough, leave it be.
    1SilverRunner likes this.
  6. Jan 9, 2026 at 11:45 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Lots of great points throughout this thread.
    Put a bubble level on the sliders/ running boards. Going off of the wheel well gaps may lead you down the wrong path since the rear arch is a bit higher than the front. Use the frame or sliders to determine if it's truly level.
    To me, it looks level already. I wouldn't lift the front any more...
