How much poke -18 offset
Discussion in '5th Gen 4Runners (2010-2024)' started by ICEMAN600, Jan 8, 2022.
  1. Jan 8, 2022 at 7:11 PM
    ICEMAN600
    ICEMAN600 [OP] New Member
    Can you post some photos if you are running a -18 wheel offset.
  2. Jan 8, 2022 at 10:43 PM
    homesteader
    homesteader New Member
    2022 4Runner TRD OR lunar rock w/KDSS
    I would like see also. But in 10 wide.
  3. Jan 8, 2022 at 11:22 PM
    ICEMAN600
    10 wide -18 offset... im guessing that would require a bit of chopping.
  4. Jan 9, 2022 at 10:04 AM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
    there are very few wheels out there with that offset (black rhino is the only company making them as far as I know?). width of wheel matters too when considering poke.... how wide is the wheel you are looking at? with an 9 or 9.5" wide -18 offset wheel you will almost certainly be trimming as well.
  5. Jan 9, 2022 at 10:21 AM
    The tire will sit in the same place regardless of rim width.
    Keep in mind that 10" wide wheels are too wide for most of the tire sizes used on 4Runners.
    Mtbpsych likes this.
  6. Jan 9, 2022 at 10:33 AM
    ICEMAN600
    Yeah im looking at 17x9 -18 offset wheel.
  7. Jan 9, 2022 at 10:39 AM
    Mtbpsych
    Mtbpsych New Member
    Found this picture, claims to be 17x9 with -12mm offset on stock tire size with a 2” spacer lift upfront. Should give you a good idea, -6mm won’t make a huge difference.
    ICEMAN600[OP] likes this.
  8. Jan 9, 2022 at 1:09 PM
    HornedOwl
    HornedOwl New Member
    Washington State
    This is 17X8.5 -12 offset
    Backspacing: -12 is 4.28"
  9. Jan 9, 2022 at 1:17 PM
    I thought this was interesting, don’t know anything about it but it looks pretty nice.
  10. Jan 9, 2022 at 1:33 PM
    FWIW, I have
    That looks a lot of negative offset. Maybe -30-40mm.
    Kinda has that "bro" look.
    SlvrSlug[QUOTED] likes this.
  11. Jan 9, 2022 at 1:41 PM
    HornedOwl
    Washington State
  12. Jan 9, 2022 at 8:46 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    This site should help. Just need to type in the specs.
  13. Jan 9, 2022 at 9:08 PM
    Mtbpsych
    Mtbpsych New Member
    It must be on wheel spacers because I have a different model of the SCS wheel but same specs and my tires don’t stick out anywhere near that far out, even with -38mm offset.
  14. Jan 9, 2022 at 11:39 PM
    homesteader
    I’ve been looking at few 20X10 -18 and think of 285/55/20 or 295/55/20. Yes kinda the bro look but not that bad. There are a few choices out there. Got a wheel picked out. Thinking of really pulling the trigger and if it needs trimming or BMC then let it be .
  15. Jan 10, 2022 at 8:50 AM
    The tires are 35/12.50 so maybe that is why.
