How much frame rust is too much?
Discussion in '4th Gen 4Runners (2003-2009)' started by dizzynymph, Jun 12, 2024.
  1. Jun 12, 2024 at 1:34 PM
    dizzynymph
    dizzynymph [OP] New Member
    Maya
    Silver 03 4Runner
    I just bought this 03 Sr5 v8 with really low mileage in amazing condition but I’ve been reading about the rust issues they have and wanted an opinion on it. I have no idea how much is too much, and if I should take preventative measures to help extend the life. It’s at 100k miles and I’d like to have it for a really long time. Thanks so much in advance ! IMG_1546.jpg IMG_1549.jpg IMG_1546.jpg IMG_1549.jpg
  2. Jun 12, 2024 at 1:37 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Hi Maya, welcome to the forum.
    The rust doesn’t look too bad, but get it treated
  3. Jun 12, 2024 at 1:40 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Welcome to the forum!
    It doesn't look too bad but a little fluid film treatment should keep it from getting worse.
    There are other products that last longer but I find fluid film applied every 6-12 months works well for my area.
    dizzynymph[OP] and Dabigono like this.
  4. Jun 12, 2024 at 1:43 PM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    This is not ideal, but doesn't look structural. If you simply start applying Krown or Fluid film each year, you will likely can get 10 years or more out of this frame. No, it won't last forever as rust already started.
    Looking at the picture, I'd be more concerned about alignment bolts not coming out.
    dizzynymph[OP] likes this.
  5. Jun 12, 2024 at 3:03 PM
    dizzynymph
    Maya
    Silver 03 4Runner
    @Sin4R ok thank you, is it easy to do yourself or should I get a professional to do it ?
  6. Jun 12, 2024 at 3:16 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    You can buy it in spray cans and do it yourself. I'd put some paper down to catch any drips.
  7. Jun 12, 2024 at 3:16 PM
    Its not bad but hope you used it to negotiate it lower.
    You can do it your self it you don't mind getting under there.
  8. Jun 12, 2024 at 5:54 PM
    Sin4R
    Mall crawling kit.
    It is messy but not difficult job. If you can pay someone to do, I would. Make sure they use oil-based product like Krown. It drips and leaves mess behind but effective at slowing down rust. Just make sure to avoid tar-based undercoating like Ziebart.
    R4Adventure and dizzynymph[OP] like this.
  9. Jun 12, 2024 at 6:04 PM
    Never mind the rust, I can't stop laughing at your screen name.
  10. Jun 12, 2024 at 6:34 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey, not bad rust there really, for that year.
    I’m currently sanding surface rust fairly similar to some of your photos. You wanna first degrease it, sand with wire brush / wire wheel, then metal prep and “paint”.
    Effective diy rust treatments are available at all auto parts stores and are fundamentally easy yes. Like anything, products come with different levels of difficulty/labor (and $$$).
    I’d say if you’d call yourself a handy, and, frugal person, do it yourself on the street and protect the area including yourself from overspray & drips.
  11. Jun 12, 2024 at 6:41 PM
    dizzynymph
    Maya
    Silver 03 4Runner
    I paid 5k for it so , I thought I made away pretty good for a 4Runner
    R4Adventure likes this.
  12. Jun 12, 2024 at 6:45 PM
    At 5K, could pay a shop to do a Krown treatment for you. Some folks swear by shop Krown treatments. Wool Wax is very good too.
  13. Jun 13, 2024 at 4:38 AM
    Sin4R
    Mall crawling kit.
    Sounds like a steal for a working 4Runner with no other issues.
    You didn't ask, but I will mention just in case. Make sure you know when each fluid was changed. Thing is, people tend to not do maintenance when they know they are about to sell the car. Unless your truck came with records, assume that every maintenance item is overdue.
    In order of importance:
    1. Change engine oil and filter.
    2. Change brake fluid and service brakes
    3. Change transmission fluid
    4. Check engine air intake filter
    5. Check alignment and tires, don't forget to check spare.
    Less important, but still very worthwhile to do:
    6. Change differential oil
    7. Change transfer case fluid
    8. Change cabin filter
    9. Change power steering fluid
    10. Change spark plugs
    11. Run high-PEA injector cleaner (e.g. BG 44K in a tank of ethanol-free gas)
    12. Inspect radiator hoses, accessory belts, check radiator for leaks
  14. Jun 13, 2024 at 4:52 AM
    Sin4R
    Mall crawling kit.
    I live where they salt roads a lot. Everything rusts here, but I apply Krown every fall since new and my cars are rust-free. It is messy, it can drip and stain driveway, but it is worthwhile to not have to deal with rust.
    R4Adventure and djwantke[QUOTED] like this.
  15. Jun 14, 2024 at 6:42 AM
    R4Adventure
    R4Adventure New Member
    Omaha, NE
    2004 Gray 4Runner SR5 V8
    2.5" Bilstein lift, 1" body lift, 34" tires on 17x9 Method Racing 312 wheels, CBI front bumper with Warn EVO10s winch, full RCI under armor and rock sliders, ARB front and rear air lockers, 8.2" rear axle house swap, etc....
    Welcome to the forum and congrats on purchasing a 4Runner. I have seen much worse for rusty frames. Yours is still manageable if you do as others have recommended.
    I would add the need to treat the inside of the frame rails. The 4Runner uses a boxed frame which is stronger than a c channel type frame but is difficult to get rust protection into and is often overlooked. I know that Fluid film can be bought in a spray can form that includes a spray tube that is inserted into the frame rails. It's tricky to use but better than nothing.
    I am fortunate that I found a reputable rust prevention shop in my town that does a thorough job, which includes inspecting those frame rails with a scope as well as occasional touch ups, like after replacing a part.
    https://www.gottschsgoo.com/
    If you can find a shop in your area that does something similar, I'd expect the cost to be less than $400. Note that these are not long term treatments. If you use Fluidfilm and apply it yourself, expect to do this annually to maintain it's effectiveness. The treatment I have on my 4Runner lasts about 18 months. Depending on where you live and the types of roads you drive on, more frequent treatments may be required.
    Ultimately, practicing these methods will drastically prolong the life of your 4Runner.
    djwantke likes this.
  16. Jun 14, 2024 at 8:14 AM
    this! ^
    well said
    *also rinse out your frame rails first with a pressure washer or hose :)
    original_ad031309-0981-4b5a-bd3d-8ff542220823_IMG_20231015_151515244_HDR_Original.jpg
    R4Adventure[QUOTED] likes this.
  17. Jun 14, 2024 at 10:55 AM
    Sin4R
    Mall crawling kit.
    Careful with a pressure washer, depending on the nozzle and distance it can lift/strip paint inside the rail.
