How high can I raise the front (Bilsteins) with no rear spacers and still be level?
Discussion in '5th Gen 4Runners (2010-2024)' started by Biggenbr, Mar 26, 2019.
  1. Mar 26, 2019 at 1:49 AM
    Biggenbr
    Biggenbr [OP] New Member
    Seth
    2017 4Runner Limited
    Blacked emblems
    im new here, have to add lift soon.
    How high can i go in the front (with the 5100s all around) without rear spacers and it still being level or close to level as possible with highest height??
  2. Mar 26, 2019 at 8:42 AM
    WallyT4R
    WallyT4R New Member
    Welcome! :thumbsup:
    I would suggest measuring your center hub to fender distance front and rear and then subtracting to find out how much you need to lift the front to be level.
    Thatbassguy, ThatToyota, 7385 and 2 others like this.
  3. Mar 26, 2019 at 11:03 AM
    4Paw
    4Paw Don't Tread On Me
    Paul
    Watertown MA
    2017 T4R prem
    Viper remote starter, Carista fob mod, Aries mats, Rhino Rack mast holder, BLACK Fluid Film, TRD forged billet oil & radiator caps, LED puddle mirror cargo & reverse bulbs, Kat's battery wrap, Bilstein 5100 level lift, OEM hitch cover, glove box organizer, ARB Scuba mod, Lamin-X yellow w/ Calais yellow LED, lift gate stickers, dipped emblems, and the fake Pro grill
    I went the full 1.75" with Bilstein 5100s up front, stock rear - no spacer, because I didn't care for the factory rake of my 2017 SR5 Premium. I have read on the forums this causes negative rake. What I found: I measured from hub center to fender and see 21 1/2" front and 22" rear. I love the level look!
    417tundra and nimby like this.
  4. Mar 26, 2019 at 2:22 PM
    :worthless:
  5. Mar 26, 2019 at 2:35 PM
    Do this. With the SR5 and TRD Off-roads there is quite a bit of factory rake. For those vehicles, 1.75" gets you the closest to level. Your limited might not come with as much factory rake (I don't know much about the Limiteds) so you might find the 0.8" setting gets you closer to level.
    Also make sure the Bilstein 5100's are compatible with your vehicle.
  6. Mar 26, 2019 at 10:19 PM
    travieb1
    travieb1 New Member
    Travis
    Seattle
    2018 Toyota SR5 premium with 3rd row seating
    2018 SR5 Premium with sunroof and 3rd row seating- tinted windows, debadged side emblems, blacked out rear emblems, AVS low profile Rain Deflectors, AVS Aeroskin 2, Toyota Cargo cover, AJT Design Fob, AJT billet Aluminum red TRD battery bracket, AJT climate control knobs, TRD Skid Plate with Red TRD Inlays, Custom Fuse/Relay Block fabbed from High-Density Polyurethane, Borla Exhaust, N-Fab Nerf Bars, Blue Sea battery meter with additional USB and cigarette lighter with full time power, OEM Audio Plus Reference 500Q System with dual Sub Woofer, Fulltime backup camera mod with AOB switch, Precision LED Full interior LED lighting kit, Xenon Depot HID kit, Diode Dynamics switchback Turn signal LEDs, Precision LED backup LEDs, Diode Dynamics taillight as blinker mod, AJT Customs DRL’s, Toyota “Canadian” 3rd row Cargo mat, Bilstein 5100’s, Toytec 3” lift, JBA Upper Control Arms, Nitto Ridge Grapplers 285/70/17, YodaTEQ Underhood Lighting Kit, TRD hood with flat black hood insert, TRD shift knob, TRD Oil cap, TRD Cold Air Intake, TRD SEMA wheels, Spidertrax spacers, Diode Dynamics SS3 fog-lights, Matte black painted TRD front end, TRD valances front and back painted matte black, Gobi Stealth rack, Gobi ladder, Rotopax with Red Fuel pack, Overland Equipped bolt on step, Kuat bike rack, White Raptor lights with Yoda LED’s switch, Pedal Commander, sequential side mirror blinker LED’s, Bunker Industries Recovery Boards with custom roof mounts, Tepui Awning with Gobi stealth mounts, CVT Mt Shasta Extended Summit Edition RTT, Southern Style Off-road Lo-Pro bumper with 20” Rigid light bar, Accessorides Remote Start.
    I did 1.75 up front and 3/4” Cornfed rear spacers In back and I absolutely love it. To me, without the spacers it would look like it has reverse rake... if you put heavy anything in back you’re going to have even more reverse rake...
  7. Mar 27, 2019 at 6:16 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    Why does everyone measure the fenders? 1.75 will level your fenders but your frame has reverse rake. .85 is the way to go without a rear spacer. This is with an empty 4 runner also, once you have the back loaded up, you reverse rake will look terrible. There is a reason for a little front rake, I suggest you leave a small 1” front rake which .85 will give you.
  8. Mar 27, 2019 at 10:04 AM
    People measure at the fenders because the 4Runner has a bunch of design cues that lend it to looking like it has more rake than it actually has (i.e. the front fenders being lower than the rear and the window line sloping downward from back to front). If you like a leveled look, than 1.75" will get you that look. A little bit of reverse rake at the frame is not as big a deal as people seem to make it around here and not everyone carries heavy shit in the back of their vehicles.
    Also, I think the way someone lifts their trucks is regional. Some people in California, Arizona, and Nevada are inspired by desert racing for example. A lot of the trophy trucks and prerunners have some reverse rake to help get a bit more travel and clearance in the front of their trucks. Other regions are known for rock crawling or swamp bogging.......creating different needs that require different lifts.
    Here's my truck at 1.6" in front and nothing in the rear. It doesn't look like it has reverse rake to me.
    taco_runner, Idbrn4u, DrewMan and 6 others like this.
  9. Mar 29, 2019 at 8:58 AM
    Biggenbr
    Seth
    Blacked emblems
    All the shops around either wanted an arm and leg or didnt want to mess with my XREAS, so i went with the toytec 2.5/1.5 spacer kit. I wont be doing any off-roading, so i know people talk shit about spacers, but its going to be a pavement princess.
    WallyT4R likes this.
  10. Jul 24, 2020 at 1:07 PM
    cory15000
    cory15000 New Member
    2011 4Runner SR5
    TBD!
    Hi All,
    I recently purchased a 2011 4Runner SR5 and was told by the inspector that the front struts will need replacing in the near future. I assume the coils are fine, so I am hoping I can get two birds stoned at once here (lift and replacement) by installing a pair of Bilstein B8 5100's in the front. I was originally hoping not to have to touch the back end (yet) and just wanted to confirm that I am following along properly.
    Setting the front's to .85 and not touching the back will ensure that it is level, all while allowing for larger tires, correct? or am I out to lunch?
    Any insight is much appreciated.
    Cheers!
  11. Jul 24, 2020 at 2:21 PM
    Take a look at this, you'll see a lot of examples:
    https://www.4runners.com/threads/bilstein-5100s-pics-with-settings.12877/#post-138153
  12. Jul 24, 2020 at 3:27 PM
    Welcome to the forum.
  13. Jul 24, 2020 at 3:55 PM
    cory15000
    2011 4Runner SR5
    TBD!
    Thank you @glwood54, the visuals help a lot. I guess the next question is it ok to only replace the front shocks or does this put me at risk of blowing the rears out? Again, this is all fairly new to me. I live in BC, Canada and don't plan and riding it off road too hard, mainly just forest service roads on weekends for camping and to access some hikes. Doubtful that i'll go the RTT or full overland route.
    @SlvrSlug thanks!
    Thanks again in advance.
  14. Jul 24, 2020 at 6:46 PM
    I don't see any harm in just replacing the front struts. Some have done that...(@nimby?)
    On the other hand, if the rear shocks are original, they are 9 years old...not a bad idea to replace them...
  15. Jul 25, 2020 at 5:23 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Agree. The rears are cheaper, and aren't in a strut. You can do them in 30 minutes while the truck is on the ground. Just knock it out now and you'll be done.
  16. Jul 25, 2020 at 8:02 AM
    Yeah, you don't have to replace the rear shocks to match the fronts, but as @glwood54 already said, if they are 9 years old it's time to replace them anyways so you might as well.
    SlvrSlug likes this.
  17. Aug 2, 2020 at 7:06 PM
    cory15000
    2011 4Runner SR5
    TBD!
    Thank you for your insight @fajitas21 & @nimby for your insight. I've managed to find a pair of lightly used B8 5100 Series Height Adj 0-2.5" Front (24-196499) for dirt cheap locally but they are missing the spring seats (picture attached). Does anyone know if these can be purchased from anywhere? I've reached out to Bilstein and Essex but haven't had any luck.
  18. Aug 2, 2020 at 7:12 PM
    That's the lower spring perch. Maybe contact Toytec or Wheelers to see if you can get a set from them.
    You'll also need the snap rings that go in the grooves of the shocks to hold the spring perches in place.
  19. Aug 3, 2020 at 12:31 PM
    Stuffy
    Stuffy New Member
    DFW
    2014 4runner SR5 2WD
    SCS RAY10 17" BFG KO2 TRD PRO FRONT GRILL HID LOW BEAM, LED high/fog/interior Ceramic tint all around TRD CAI Blackout emblems
    Set at 2.5 front
    B12 1.5" springs and 10mm ome lean spacer in rear.
    jason2006 and DrewMan like this.
  20. Aug 4, 2020 at 4:24 AM
    JohnMurphyNC
    JohnMurphyNC New Member
    2020 ORP
    I like that a lot. How’s the ride?
    Side note: What sliders are those?
  21. Aug 4, 2020 at 5:39 AM
    Stuffy
    Stuffy New Member
    DFW
    The ride is definitely not like stock anymore and is stiff but not rough. I have no problems going over train tracks.
    Sliders are Cali Raised LED. I like the bc it is cheaper than most brands and it attaches not only to the side of the frame but also to the bottom of the frame (L-shape).
  22. Aug 29, 2020 at 8:10 AM
    cory15000
    2011 4Runner SR5
    TBD!
    I've managed to track down the lower spring perch's from Summit Racing but after picking up the shocks I noticed they are also missing the small washer (picture attached & mentioned at 11:00 in this install video: https://www.youtube.com/watch?v=dEnMvblCHyo). It looks like the OEM washer/cap is still able to sit on the ledge of the spring without but I am curious if anyone has installed these without the small washers?
    Thank you!
  23. Aug 29, 2020 at 8:22 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    I put Bilsteins all around at .85 front and nothing added in the rear, all stock springs. I am just about even all around with the back still slightly higher (no weight in vehicle). I love the ride. Eventually, if I start towing more again, I may replace the rear springs but will wait and see. Definitely increases comfort and decreases side to side roll.
  24. Aug 29, 2020 at 8:30 AM
    Stuffy
    Stuffy New Member
    DFW
    I have these springs.
    doc4216[QUOTED] likes this.
  25. Aug 29, 2020 at 3:31 PM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Thanks!
  26. Aug 30, 2020 at 5:45 PM
    I wouldn't go without that washer. You could potentially bend your shock shaft without the stability that washer provides.
    I would call Bilstein to see if they have a couple to sell you.
  27. Aug 30, 2020 at 8:46 PM
    Idbrn4u
    Idbrn4u New Member
    5100’s all 4
    1.75” in the Front.... Just did this and leave the rears stock height
    Because I’ve read conflicting info online I questioned the techs at Off Road Warehouse in San Diego. They insisted
    The end result was a 3/4” rake and I’m very pleased
  28. Aug 31, 2020 at 7:01 PM
    71GS3504sp
    71GS3504sp New Member
    George
    2018 white 4runner
    I did some thing a little different when I installed my 5100. Prior to my current 4runner I have owned a FJ for over 10 year with almost 200k miles on it before I sold it in 4 days. I installed 5100 at 0.85 lift (2nd notch from the bottom) and due to the typical Toyota lean I installed a 3/8" spacer on the driver side and 1/4" spacer on the passenger side. Here are my before front lift LF 29.00" RF 29.25" LR 31.25" RR 31.25" after installing my 5100 at 0.85 lift with spacer LF 30.75" RF 30.75 LR 31.25 RR 31.25. Here is a photo with my pro rims and stock size all terrain tires.
    taco_runner and Stuffy like this.
