How do you turn on outside light on rear hatch?
Discussion in '5th Gen 4Runners (2010-2024)' started by rmiked, Apr 8, 2023.
  1. Apr 8, 2023 at 9:48 AM
    rmiked
    rmiked [OP] New Member
    Fort Mill, SC
    There is a light below the spoiler on the rear hatch. How do you turn it on? I couldn’t find the bulb either in the owners manual for replacement instructions?
  2. Apr 8, 2023 at 10:09 AM
    rmiked
    Fort Mill, SC
    Yes, I feel like an idiot. I assumed the light would be red. It’s clear but turns red once it illuminates. I thought it was some exterior light when using hatch at night. My mistake. Thank you61D0138A-63F1-455F-9123-DBD7B8811A5C.jpg
    kolter45, Startrek, djwantke and 3 others like this.
  3. Apr 8, 2023 at 11:17 AM
    steelevo
    Utah
    Don’t feel like an idiot. That’s what the forum is for. We all learn from these questions. Some are just too shy to ask.
  4. Apr 8, 2023 at 11:43 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    it's the brake light but it would have been cool if that was also a rear light when needed (like a bed light on pick up truck)
    ecoterragaia, Thatbassguy and Ironguy like this.
  5. Apr 8, 2023 at 1:20 PM
    3rd brake light. Will come on when braking only.
  6. Apr 8, 2023 at 2:13 PM
    NorthernSailor
    NorthernSailor New Member
    Alberta
    2023 Black 40th Anniversary
    Elka 2.0's up front, Sherpa rack, WeBoost Overland cellular booster, Nokian Outpost rubber
    Like those interior LED panels that have a red AND white light modes...That would have definitely been cool!
    photo8 likes this.
  7. Apr 8, 2023 at 8:14 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    No worries. I noticed that this third brake light console retains water after a rain..... days after a rain.... water drips' down once the trunk is lifted or opened. Is this normal for everyone?
  8. Apr 8, 2023 at 9:41 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Ya know. That would be cool if someone like MESO would make a combo brake/flood light with a dedicated switch for that location.
  9. Apr 8, 2023 at 9:45 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Yes, it's kind of stupid design. I have to clean mine out every so often as it gets all green and mossy.
  10. Apr 9, 2023 at 3:53 AM
    rmiked
    Fort Mill, SC
    How do you clean it out? Remove the lens screws? And then just clean back side of lens?
  11. Apr 9, 2023 at 5:34 AM
    Yes, 100%, this is exactly how you would clean if the need arises.
  12. Apr 9, 2023 at 9:10 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    This thread has gone from "C'mon man!" to "Hey, that's a great idea!"
    rmiked[OP] likes this.
  13. Apr 9, 2023 at 9:52 AM
    NorthernSailor
    Alberta
    Sign of a good forum, perhaps
  14. Apr 9, 2023 at 11:57 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Meso had this prototype tease from about 3 years ago but haven't heard about it since. Capture+_2020-01-07-18-49-06.jpg
    Kezin likes this.
  15. Apr 9, 2023 at 1:46 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Funny I've actually been taking things apart and finding a wire path to this location for a rear flood (truck bed light), or rear chase light that strobes for dusty trail groups. I've even contemplated fishing 12v power supply into headliner, down pillar and below truck then up into cargo 120v outlet for easy on/off since it wouldn't be used often.
    https://www.ebay.ca/itm/125783401417
  16. Apr 9, 2023 at 6:03 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Can’t say I love the look, but do love the idea. Don’t they have a hatch light prototype too that hasn’t seen the light of day?
  17. Apr 9, 2023 at 6:12 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Design looks like the 70s. if it doesn't also trap rain.
  18. Apr 9, 2023 at 9:40 PM
    atk411
    atk411 New-ish Member
    Orange County, CA
    2022 Barcelona Red Off Road Premium
  19. Apr 10, 2023 at 9:53 AM
    RoyL
    RoyL New Member
    2021 Limited 4Runner
    stock from dealer
    My 2021 Limited has two lights located on the rear hatch, each have a 3 position switch, (on, hatch, off) if in the hatch position they light up when the hatch is opened. Hope this helps.
  20. Apr 10, 2023 at 9:58 AM
    The problem with having a cargo light in the 3rd brake lamp assemble is that it would be useless with the hatch open.
  21. Apr 10, 2023 at 4:35 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    The 4Runner Lifestyle one does that.
    https://www.4runnerlifestyle.com/pr...rake-light-replacement?variant=43415295525109
    It’s got an extra white wire that can be used to make it a reverse light too!! It also blinks when the brake is first pressed. The red one is always in stock but the smoked one is always out of stock. They just restocked it but it’s out again. I’m going to get the red because it’ll be brighter during the daytime & nighttime. Mainly I’m buying it because it’s red & blinks & I don’t want some texting idiot to hit my shit! :argue:
  22. Apr 13, 2023 at 2:08 PM
    RoyL
    RoyL New Member
    stock from dealer
    rmiked. Did you find the lights? I had to look specifically for lights, since I usually open the hatch during daylight hours I never noticed them. They are there! My 2021 owners manual shows them under 'Back door' page 133. RoyL
  23. Apr 13, 2023 at 2:19 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Agreed. May be neat to utilize the reverse lights for this. Could use a relay (normally closed?) with a switch to allow them to be turned on when the vehicle is off. Would have to think thru it some more to figure out exactly how to wire it to ensure it doesn't cause an issue with normal function.
  24. Apr 13, 2023 at 2:37 PM
    I swapped in Archlights all around and they are really bright for open hatch use.
  25. Apr 13, 2023 at 2:40 PM
    rmiked
    Fort Mill, SC
    RoyL, I’m my 2023 Manual “back door “ is on page 124. It describes the 2 interior door mounted lights, each independently switchable for “on”, “off” and “door” position. Another area of manual describes the license plate lights on outside of rear door hatch. Another area of manual describes the high mounted brake light, that I originally thought was for general illumination outside (but was wrong). I don’t see any other lights except the corner lens containing brake lights, turn signals, parking lights and back-up lights.
  26. Apr 13, 2023 at 3:05 PM
    08TXRunner
    '20 SR5P
    I still think you've got your million dollar idea staring you in the face :bananadance:
  27. Apr 13, 2023 at 4:41 PM
    Kezin
    Do you like them though? I had them in my wife’s and opted to replace with Meso in the map and dome lights and some KC Cyclones in the hatch lights. Didn’t even bother with the ArcLights in mine. The dome light switch sticks down too far and has been broken off twice now by me fiddling with stuff in the back seat. The map lights have never fit well and jostle around on any slightly bumpy roads. The hatch lights were ok but were constantly being pressed by bags and dogs and whatever else in the cargo area. The KCs don’t have a button and the amber seems like a good middle ground between white and red
  28. Apr 13, 2023 at 4:51 PM
    I like them. The only issue I have had was knocking the button off of the dome when changing in the back before a hike. I haven't installed the map lights yet.
    Kezin[QUOTED] likes this.
  29. Apr 13, 2023 at 5:16 PM
    Kezin
    Ah. Well I am of the opinion that they are hot garbage and everyone should avoid them at all costs
