How can I stop my doors from freezing shut
Discussion in '3rd Gen 4Runners (1996-2002)' started by Trekker, Oct 29, 2020.
  1. Oct 29, 2020 at 8:41 PM
    Trekker
    Trekker [OP] Regular Member
    1997 3rz 5spd
    One issue I've been having lately is that my doors freeze shut over night. Sometimes the rain will freeze in the panel gap between the door and frame, but I've had this happen when it didn't rain. The ice will also stick on the gaskets and pull at them as I try to open the door, and then sometimes the handles will be difficult to actuate.
    Is there something I can do to stop this from occurring?
  2. Oct 29, 2020 at 10:33 PM
    ChristiV
    ChristiV New Member
    Christina
    Sun Valley NV
    2001 White 4Runner 280g+
    K & N Intake Going to WM soon One Inch Knurled Throttle Body Spacer Flowmaster 60+ 3in Tailpipe Bilstein F and R
    WD-40
    Clean your weatherstrip, dry, Spray some WD on a clean rag and wipe on weatherstrip, Do it occasionally and it also helps weatherstrip from drying out..
    Christi
  3. Oct 30, 2020 at 12:31 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Leave them open
  4. Oct 30, 2020 at 12:39 AM
    thirdyota
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    Shin-Etsu grease.
  5. Oct 30, 2020 at 12:50 AM
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    Move :confused:
    MeefZah likes this.
  6. Oct 30, 2020 at 7:59 AM
    While I am sure this works fine, any quality vinyl/rubber protectant (not Armorall), works too.
  7. Oct 30, 2020 at 9:40 AM
    Trekker
    1997 3rz 5spd
    Would silicone lubricant work
  8. Oct 30, 2020 at 10:50 AM
    Garage? If not WD-40 should work.
  9. Oct 30, 2020 at 11:03 AM
    Trekker
    1997 3rz 5spd
    Unfortunately no
  10. Oct 30, 2020 at 11:52 AM
    Probably fine. That stuff isn't supposed to react with much of anything.
    Not sure what the long term effects are of WD-40 on Rubber, but is supposed to be OK too.
    I use Meguiar's Rubber/Vinyl protectant throughout the car because that is what it was designed to do.
  11. Oct 30, 2020 at 8:36 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    Remove them
  12. Nov 2, 2020 at 8:09 AM
    Jerico
    Jerico New Member
    1998 4runner
    Lifted w/17" wheels
    Move to Arizona. :cheers:
  13. Nov 2, 2020 at 8:13 AM
    catus
    catus New Member
    Centennial, CO
    2019 Tundra Double Cab TRD Limited
    No major mods yet
    Bacon grease. Smells good too. Might have to chase off raccoons though.
    Tama1968 and thirdyota like this.
  14. Nov 2, 2020 at 4:36 PM
    Tama1968
    Tama1968 New Member
    Florida
    Plus it complements the soy-based wiring nicely. Goes well with a nice red wine.
    catus[QUOTED] likes this.
  15. Nov 2, 2020 at 4:39 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    move to cancun....heh heh heh.....
  16. Nov 11, 2020 at 4:25 PM
    Sisu
    Sisu New Member
    1999 4 Runner
    Nothing so far
    I use silicon spray on a cloth or blue shop towels then coat all the rubber seals and then spray Si on the door sections that match the seal, especially at the top because that’s where things freeze up. I live in Juneau, Alaska and we get a lot of funky wet winter weather with freezing. This works most of the time unless it’s an ice storm, then no matter what you are screwed.
