Hot smell coming from Back tire area
Discussion in '5th Gen 4Runners (2010-2024)' started by Bazman, Oct 21, 2019.
  1. Oct 21, 2019 at 11:03 AM
    Bazman
    Bazman [OP] New Member
    Brian
    2016 Limited 4 runner
    I was driving the other day and noticed a strong smell coming from the rear end. It smelt like rubber that was hot. Has anyone else had the same issues?
    Crossfit4Runner and 2016Pro like this.
  2. Oct 21, 2019 at 11:28 AM
    SCMountaineer
    SCMountaineer New Member
    Upstate South Carolina
    Not since I gave up Taco Bell.
    TechNRK, 2016SR5P, jester243 and 7 others like this.
  3. Oct 21, 2019 at 11:34 AM
    AsianAnts
    AsianAnts New Member
    ....:rofl:
    To answer your question, no
    thirdyota likes this.
  4. Oct 21, 2019 at 11:37 AM
    2016Pro
    Haha check your drawers. Lmao great title.
  5. Oct 21, 2019 at 11:39 AM
    wawuzit
    wawuzit New Member
    steve
    2019 Blue 4 runner
    none
    Goggle search...a lot of talk about exhaust hangers getting hot. (rubber cushions)
    djwantke likes this.
  6. Oct 21, 2019 at 5:12 PM
    thirdyota
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    This thread was better before the title change.
  7. Oct 21, 2019 at 6:05 PM
    Maybe your spare is off center and touching exhaust? Or have you undercoated maybe on the exhaust?
  8. Oct 24, 2019 at 9:53 AM
    Metalman73
    Metalman73 New Member
    I get that smell on my '19. No clue what it is.
  9. Oct 24, 2019 at 2:27 PM
    danssr5
    danssr5 New Member
    Dan
    2017 sr5 premium 4x4
    Only when power-braking!
    2018 Limited likes this.
  10. Oct 25, 2019 at 11:46 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I had this rubber smell on my 2016 runner when new.. I moved the exhaust hangers furthest from the pipe.. reduced the smell and after a few months smell is gone..
  11. Oct 26, 2019 at 9:19 PM
    MountainMan
    MountainMan New Member
    Pacific Northwest
    Mine also has it. My daughter's older CRV also had the same phenomenon.
  12. Oct 26, 2019 at 11:54 PM
    Anotherreject
    Anotherreject New Member
    Mine did the same thing, i did not know about the exhuast hanger issue
  13. Mar 10, 2024 at 4:50 PM
    TheSponge
    TheSponge New Member
    Can you or anyone else explain what this hanger issue is? I believe have this smell on my 2016, and at first I thought something was leaking or broken but this smell is consistently there especially if I back up.. and I’m covering miles and miles with no actual vehicle issues but the smell drives insane when I get out and smell it
  14. Mar 10, 2024 at 7:31 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    The exhaust hangers smell when they get hot enough. Poor rubber choice by toyota is most likely the culprit. Mine does it less than now that it has 30k miles
  15. Mar 11, 2024 at 2:48 AM
    This is interesting! I've noticed this every once in awhile and never really looked into it. Thanks for the information, guys!
  16. Mar 11, 2024 at 6:08 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    Exactly. I get this after driving like a maniac pushing through traffic out of the city trying to get home. Stop go, stop go very fast, stop.
  17. Mar 11, 2024 at 5:35 PM
    TheSponge
    So is there a remedy for this hanger issue? Will the rubber melt/fail?
    And you are right, it smells like rubber so I was super confused what it could be but next time I smell it I’m going to crawl under the vehicle and try and get near the culprit to see if it’s stronger at the source
  18. Mar 13, 2024 at 4:23 PM
    j cat
    j cat New Member
    massachusetts
    I had this rubber smell on my 2016 runner when new.. I moved the exhaust hangers furthest from the pipe.. reduced the smell and after a few months smell is gone.. 8 years ago no 4runner inspected it of my maintenance .... very great 4runner !
  19. Mar 13, 2024 at 5:17 PM
    LetsTacoboutit
    LetsTacoboutit New Member
    Adobe
    OP should also check for axle leak. Rear dif fluid on brake shield or other parts can also cause an odor at rear axle.
    4runner had an odor originally when bought new that went away after a year. Cut to last fall when a different odor presented at rear driver's side which ended up being a minor seep from seal. Wouldn't hurt to look underneath at both axles with a flashlight.
    TrailDad likes this.
  20. Mar 14, 2024 at 2:08 AM
    Gripster
    Gripster New Member
    2016 Trail Premium
    You can also get grease slinging from the drive shaft spiders if recently greased. It can sling onto exhaust.
    jgalt likes this.
  21. Mar 17, 2024 at 7:57 PM
    j cat
    j cat New Member
    massachusetts
    the axle of the venting of the rear diff .....the sealer of the diff the higher pressure and the worn issue !!!!!!!!!
    corroded venting issue ...
