Hope there's no wind
Discussion in '5th Gen 4Runners (2010-2024)' started by citykid, Jan 3, 2026.
  1. Jan 3, 2026 at 5:30 PM
    citykid
    citykid [OP] New Member
    St. Augustine, FL
    2019 TRD Pro
    Man, I forgot how bad these things get blown around by wind. It's like a giant sail instead of a truck. Going over a bridge and I get pushed around. Today on the highway a truck passes me and I get pushed by the air pocket. Add in it was pretty windy today and I had a death grip on the wheel all the way home.
    My 3rd gen was bad with it and I see no difference with my new 5th gen. I was in some deep soft sugar sand and it performed tremendously! But if you sneeze near my truck it'll rock side to side.
    Mr.DRZ likes this.
  2. Jan 3, 2026 at 5:44 PM
    WalterCat
    WalterCat New Member
    Limited 2015, stock
    I just got into 4runner pros and cons recently and a frequent topic is handling in general. Very interested in reply to your post. Mine has new XREAS system and rides fine but I'm still going to tackle the highway handling now that the holidays have past. Has anyone found an upgraded sway bar package? Or felt the need to consider.
    For Limited.
  3. Jan 3, 2026 at 5:58 PM
    Tama1968
    Tama1968 New Member
    Florida
    2018 SR5 Premium Magnetic Grey Metallic/2019 SR5 Celestial Silver
    our '18 and 19 Runners do a little shimmy if we're in the burble behind a semi but otherwise no worse than the Blazers/Trailblazers I drove back in the 90s. That said, the vehicle was originally designed more for off road than the highway so I never expected it to be super smooth.
  4. Jan 3, 2026 at 6:09 PM
    I expected it to be a bit unsteady when a hard or stiff wind blows. I mean, it's a body on frame truck that's almost 10 inches off the ground. A higher center of gravity is gonna mean more body roll. The really shitty thing about a strong wind is when it's a HEAD wind.
    Then I get blown all over the road AND my MPG's drop by 4 - 5 (or more) MPG. I experienced this a few weeks ago in Dallas. The wind was strooooooooooong that day my friend. I usually get 20-ish MPG's while driving to and from work. But that day when I was driving home, I got 15MPG.
  5. Jan 3, 2026 at 6:15 PM
    They do get blown around some, but, I have to say not nearly as much as my previous FJ brick.
    Guppy1301 and Mr.DRZ like this.
  6. Jan 3, 2026 at 6:29 PM
    Shredder
    Shredder New Member
    tip of the mitt, Michigan
    23 OR
    Tires, shocks
    Putting bilstein 5100’s shocks helped my off road on the highway quite a bit. Still not great but better.
    Whammo and TrailSpecial22 like this.
  7. Jan 3, 2026 at 6:53 PM
    Fly_Guy
    Fly_Guy New Member
    Eric
    Placitas, NM
    2023 Lunar Rock ORP
    2023 ORP ... Dobinson IMS suspension with ~ 2" lift, chrome delete interior and exterior, slim line front bumper with winch install, misc. little mods.
    On our move from MD to New Mexico in September, the MPG's were brutal west of Oklahoma City ... constant strong head wind dropped me down to ~11.5 MPG.
  8. Jan 3, 2026 at 7:14 PM
    WalterCat
    Limited 2015, stock
    These 4.0 engines fail when it comes to head winds. If Toyota could send diesels to us it would be great.
    I drive a Duramax and still adjusting to my new to me 4runner. Don't get me wrong they are nice SUV's but under powered. I still cringe when thinking about a 4 cylinder in them. I'm Oklahoma with those winds.
  9. Jan 3, 2026 at 7:15 PM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    Increase caster to maximum of manufacturer recommended range. That improves straight line stability. Helped a lot with my 2020 Limited. This truck will never be as relaxing a highway cruiser as your typical SUV. BOF, 10 inches of ground clearance, a suspension made for off roading and the aerodynamics of a brick all add up to some wandering at highway speeds. It is what it is. But upping the caster sure helps. Any shop that does alignments can do it for you.
    The downsides are minor but do exist. First, you increase steering effort and reduce turning radius a bit (which of course makes perfect sense when you think about the fact that increasing caster gives you better straight line stability by pushing the wheels farther toward the front of the truck). Likewise, if your tires are a bit on the large side, eg knobby ATs, you may get a slight bit of rubbing when both turning and backing up in reverse. I did on new tires. But it was very slight, only occasional, causes no problems and stopped once the tires wore a bit. You can also heat the inside of the fender liner to push it forward a bit to eliminate this entirely. If however you are running actual oversized tires it could be more of an issue. See the 1 million "will it rub" threads on the forum :D.
    Shredder likes this.
  10. Jan 3, 2026 at 7:19 PM
    WalterCat
    Limited 2015, stock
    What was your caster reading adjusted too?
  11. Jan 3, 2026 at 7:43 PM
    once you upgrade the struts/shocks it reduces it a lot
    2Toys, Shredder, BS67 and 1 other person like this.
  12. Jan 3, 2026 at 7:44 PM
    Singleminded
    OEM LED foglights
    I can't find the alignment report at the moment, but our AI overlords claim that the manufacturer recommended range is 2.0 degrees to 4.0 degrees, and that tracks with my recollection of mine being adjusted to about 3.9.
    WalterCat[QUOTED] likes this.
  13. Jan 3, 2026 at 7:45 PM
    Higher the caster # the better
  14. Jan 3, 2026 at 8:21 PM
    Just steer into the wind like they do with 777s
    roooo and BS67 like this.
  15. Jan 3, 2026 at 9:24 PM
    Plan your route to get a tailwind, then you will smile at the mileage. ;)
    Photon_Chaser and BS67 like this.
  16. Jan 3, 2026 at 9:34 PM
    I don't remember mine been that dramatic even having a roof cargo box. In route to Wyoming the LED displays said 75mph gusts. Just little effort needed to correct it. Maybe poor alignment on OPs 4runner making the steering very loose on the road? Skinny over inflated tires?
  17. Jan 4, 2026 at 4:20 AM
    We just went through getting blown around a little, add in some slick spots, oh ya, interesting. Having good numbers on caster on the alignment helps high speed stability, suspension upgrades help a little for the body roll, but I'm thinking these 4Runners are always going to be susceptible to the effects of wind. It's really not 'dramatic', it's just that we all seem to describe things differently.
    Singleminded and BS67 like this.
  18. Jan 4, 2026 at 11:52 PM
    It sure does get rocked around. Especially if it’s on the stock shocks/springs that come on the SR5 and Off-Road trims. If you don’t need the off-road clearance, but you like the 4runner, heavier rate aftermaket springs/coils help a lot. I bet if you lower it a couple inches from the stock height, get larger wheels that will let you run lower profile tires, and remove all the roof rack hardware, it will handle strong crosswinds like most other cars. But then it be like most other cars.
    By the way, most real trucks/semi’s get blown over by strong wind gusts. The 4runner isn’t that bad in comparison. If you mean to compare them to pickup trucks, they’re not a fair comparison since they don’t have a backside to get pushed around like a sail.
  19. Jan 5, 2026 at 3:12 AM
    In 45-50 mph wind nothing is good on the road. I'm guessing by 'strong' wind gusts you're talking 60+ mph, it's real dangerous to be on the road with high profile vehicles in that wind. We only had 25 maybe 30 mph wind, gusts and it was no fun, with suspension up-grades. Does it seem realistic someone would modify the shit out of their vehicle just to deal with wind? Maybe you're on vacation with the roof rack full... going across Wyoming, the wind gust capital of the U.S. It'll be OK, but when I see birds flying backwards, I take notice. The 4Runner is just not aero quality.
    BS67 likes this.
  20. Jan 5, 2026 at 9:35 AM
    Interstate 80 in Iowa, cross winds were insane. First time experiencing that kind of wind and how it pushes the truck. We saw semi trailers rocking so we called it quits. Got off and stayed at a hotel for the night. Sometimes you have to acknowledge that mother nature will always win.
    Toy4X4 and Singleminded like this.
  21. Jan 5, 2026 at 11:06 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Just curious what the OP had as a vehicle prior to/as compared to a 4R?
    Toy4X4 likes this.
  22. Jan 5, 2026 at 12:16 PM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    Cross wind is best served on ice! That way you can experience the real thrill of the wind physically pushing you 1-2 lanes in the direction the wind is going as you slide sideways at speed on the ice. o_O
    Toy4X4 likes this.
  23. Jan 5, 2026 at 1:45 PM
    citykid
    St. Augustine, FL
    2019 TRD Pro
    I came from a Chevy Silverado. But to be honest, my Harley doesn't get pushed around as bad either.
  24. Jan 5, 2026 at 3:57 PM
    alittleoff
    Steve
    406
    '16 TP
    Not really a good comparison. Lots of variables. Hopefully you'll get used to it.
  25. Jan 5, 2026 at 7:11 PM
    I wasn’t sure how much the OP wanted to keep his 4runner, so I was just listing out what would probably be needed to make a 4runner feel a little more stable in gusty winds. And no, personally I don’t think it’s reasonable to do all those things…unless you really really love the 4runner “form factor”. Which might be a possibility. After all, driving the 4runner to work and back is a positive part of my day, that I usually look forward too. I haven’t really had a car before that I liked this much.
    The OP might also just be making an observation, not necessarily regretting his 4runner. I admit, it’s a pretty spicy ride in gusts. But depending on one’s frame of mind, it could be entertaining.
    As far as 60mph gusts, I don’t think most people really have the experience to appreciate what gusts like that can do to anything that’s outside, much less on the interstate. The wind is bad enough, but I would worry more about lawn furniture, garbage cans, or other unsecured/liberated liberated debris getting thrown your way. Can you imagine getting a trampoline through the windshield at interstate speeds? :eek::D.
    Toy4X4[QUOTED] likes this.
  26. Jan 6, 2026 at 3:24 AM
    I understand what you're saying, just didn't want to hear someone complain that they spent $5,000 on suspension and still have an aerodynamic brick/kite. Iguess I look forward to driving the 4Runner too, it's been a long time since I had my '86 Toyota pickup, which I loved, and by the way, it was a handful in the wind also!
  27. Jan 6, 2026 at 5:32 AM
    Charlievee
    Charlievee Not new member.
    Haven't had an issue with wind, can comfortably drive with two fingers at highway speeds (75mph+) in Kansas. Tire pressure is key, a good suspension goes a long way and not driving around with a bunch of crap on the roof is always helpful. Hell, opening the windows can help but it may mess up ones hair.
    Toy4X4 and Curlystooge like this.
  28. Jan 6, 2026 at 8:47 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Worst I've ever experienced was the panhandle of Texas. 25mph constant wind. 50mph gusts. I had a 3" OME lift and the time. I was holding the wheel 20-30 degrees off center to go straight. Passing an 18-wheeler turned into a guessing game trying to find center again.
    As others have stated better shocks and high caster does seem to help with stability. But wind is wind...
    These things have the aerodynamics of a refrigerator.
    Toy4X4 likes this.
  29. Jan 6, 2026 at 9:15 AM
    2019 TRDP w/Kangs brah!
    I just drive it. My 2010 DCSB Tacoma got blown around too but I would get a kazoo whistle due to the windshield seal configuration.
    A derzul just for wind?
    Charlievee likes this.
  30. Jan 7, 2026 at 6:15 AM
    Charlievee
    I was one of the last cars on the Bay bridge tunnel in Virginia before they closed it for a squall. Couldn't tell if it was rain or waves hitting the roadway at times. 18 miles totally exposed, good times.
