Highway Speed Shakes
Discussion in '4th Gen 4Runners (2003-2009)' started by temerson03, Aug 21, 2025.
  1. Aug 21, 2025 at 11:07 AM
    temerson03
    temerson03 [OP] New Member
    2006 SR5 RWD 4runner
    Upgraded tires and front shocks
    Hi y’all,
    I’m trying to figure out where a shake is coming from or what it could possibly be… I have been experiencing a shake at highway speeds anywhere from 50+ MPH the shake is mostly felt in the steering wheel but the whole car kind of shakes. I had my front tires balanced and also replaced my whole driveshaft assembly. I’m wondering whether it’s tires or suspension system, i’ve done the shake test on the front wheels and didn’t really solve much for me. If there is anything that I could try or test that would be great!
    Captain Spalding likes this.
  2. Aug 21, 2025 at 11:55 AM
    welcome, were the tires road force balanced ?
  3. Aug 22, 2025 at 9:58 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Try rotating rears to front.
    Sometimes tech doing balance does it poorly.
    Old weights removed first. Spot on inside of wheel must be cleaned for weights to stick. Weight cannot get dirt on it before stuck to wheel.
    Rarely a wheel tosses a weight off (due to poor attachment).
  4. Aug 25, 2025 at 1:43 PM
    temerson03
    So I rotated tires front to back and I am still feeling the shake??? Help this shake is killing me, it seems my alignment is a little bit off but I dont think it would cause this severe of a shake.
  5. Aug 25, 2025 at 1:55 PM
  6. Aug 26, 2025 at 2:47 AM
    Welcome from Wisconsin! Alignment, then get the tires road force balanced, you might have a bad tire(out of round, ply separation) a tire tech with a bunch of experience should be able to sort this out, maybe a bad wheel also, mud stuck on the inside of a wheel. Good luck
  7. Aug 26, 2025 at 3:30 AM
