Higher tire pressure sensors?
Discussion in '5th Gen 4Runners (2010-2024)' started by RaverJack17, Aug 7, 2022.
  1. Aug 7, 2022 at 7:42 PM
    RaverJack17
    RaverJack17 [OP] New Member
    Joe
    2022 4Runner Trail Edition Army Green
    3" Lift and Tires
    I have some aftermarket tires and wheels on my 2022 Trail edition. The pressure is higher for these tires and I like to run higher on the paved roads. However, I noticed the sensors they installed with these only read up to 55 psi. Are there sensors that will read higher?
  2. Aug 7, 2022 at 8:39 PM
    Agent_Outside
    Built 2011 T4R Limited
    There is no tire that you should be running at 55+ psi on a 4Runner.
  3. Aug 7, 2022 at 10:02 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    jesus, and i thought my 33 was wicked high....
  4. Aug 7, 2022 at 10:05 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    How I imagine the OP's tires look...
    On the real though as said previously, no tire on 4Runner should be at 55+ psi
  5. Aug 7, 2022 at 10:19 PM
    This.
    Here's a handy tool to find out what you should actually be running:
  6. Aug 7, 2022 at 10:35 PM
    The sidewall is the max, not the recommended pressure. Most tires would need close to OEM pressures.
  7. Aug 8, 2022 at 8:41 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    I am guessing your rig rides like a brick and really only the center portion of the tire is touching the pavement?
    What brand, size and load rating is the tire? Wheels really don't matter...
  8. Aug 8, 2022 at 10:09 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    I have never had a pressure sensor that worked right (on 4-5 different vehicles and two sets of tires on the Blue Beast!)! I use the old "walk around and look" method. Have Discount Tire check my pressure before trips and check them when gassing every day or so.
