High idle at start
Discussion in '5th Gen 4Runners (2010-2024)' started by Rnrdani, May 20, 2025 at 7:31 PM.
  1. May 20, 2025 at 7:31 PM
    Rnrdani
    Rnrdani [OP] New Member
    24 ORP KDSS
    I believe I have high idle somewhere between 1500-2500 rpm at start. Sometimes below 2000 rpm’s. What normal? This is at temps between 40-65 so far. It has 5800 miles on a 24. Had oil changed at 5000. Also below 1000 once I engage drive. Tia!
  2. May 20, 2025 at 7:38 PM
    Normal to have a high idle right after a cold start regardless of OAT.
  3. May 20, 2025 at 7:45 PM
    Rnrdani
    24 ORP KDSS
    yeah, I didn’t pay attention before to rpms but the last few times just sounded like I was stepping on the gas and nothing was pushing the peddle. I started to pay attention to Rpms. When warm it’s between 1000-1500
  4. May 20, 2025 at 10:24 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    that's what it does in open loop, cold startup. Within 30-45 seconds it settles out around 1100 and then 700 or so once in closed loop.
  5. May 20, 2025 at 11:04 PM
    Rnrdani
    24 ORP KDSS
    So 2000-2500 rpm is normal?
  6. May 20, 2025 at 11:50 PM
    Don’t sweat it. If the engine was doing something outside of its parameters, you’d get a check engine light.
    Toy4X4 likes this.
  7. May 21, 2025 at 1:04 AM
    As long as it drops down within a few seconds after warm up, you're fine. If you've been driving and it's still that high at a stop light, then check something.
  8. May 21, 2025 at 3:29 AM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    In my 24 south Florida cold start, idle starts around 1200, gets down to 1100 for 2-3 mins then slowly, slowly gets to 1k and less. I usually drive off after 1-2 mins of idle after a cold start.
    It can jump up kinda high initially, but settles at 1200-1100
    open vs closed loop. Open meaning dumping fuel into cylinders to get up to temp, closed meaning Ecm talking to all sensors, MAF, o2, Throttle body, etc
  9. May 21, 2025 at 3:31 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Nope. Your rig is completely broken. Not normal at all. In fact, that means the engine is beyond repair.
    Also, oil change at 5k... you completely destroyed that engine. Bummer.
    EDIT- Im sending info, to purchase your broken rig, cheap of course. Look for a email.
    Imdav2u and Rnrdani[OP] like this.
  10. May 21, 2025 at 3:55 PM
    Rnrdani
    24 ORP KDSS
    Mine used to start below 1500 but has jumped up to 2000-2500 which was strange
  11. May 21, 2025 at 3:55 PM
    Rnrdani
    24 ORP KDSS
    $57k lol
  12. May 21, 2025 at 4:09 PM
    Do you have aftermarket floor coverings over the OEM floor mats?
  13. May 21, 2025 at 4:37 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Yes, anywhere between 1500-2500 for the first few seconds is normal. Mine usually fires up around 1800-2000 with variance as we have temps from 0 to 100+ during the year.
