HID Headlight Adjustments? Normal?
Discussion in 'Lighting' started by raekit, Feb 27, 2019.
  1. Feb 27, 2019 at 9:10 PM
    raekit
    raekit [OP] New Member
    Kit
    Tustin, CA
    2016 4Runner Trail w/ KDSS
    TRD Pro Wheels 275’s BFG KO2 5100’s Bilsteins @ 1.75” front Cornfed 1” spacer in the rear
    I just upgraded my low beams with XenonDepot Xtreme HID’s....easy to install and the brightness is incredible compared to the stock bulbs. I’m really pleased.
    One question....the step in the headlight cut off line seems pretty large...is this normal?
    Any feedback or help would be great!
    RichardHopkins and WallyT4R like this.
  2. Feb 28, 2019 at 5:52 PM
    kbp810
    kbp810 New Member
    I think that's still a decent cutoff; you've got the steps, yes, but no scattered glare. Might want to perhaps try adjusting them down a bit more and see if it flattens out a little more? Might be catching a small reflection or something.
  3. Feb 28, 2019 at 7:32 PM
    GunRunner
    GunRunner New Member
    2018 4Runner OffRoad
    I installed XD hids also and had to adjust my beams down because I was blasting people in the face.
    2016Pro likes this.
  4. Mar 1, 2019 at 9:11 AM
    jester243
    Dan
    Spokane, WA
    I had to adjust down just a little bit. With the halogens it was fine but the increase with the HID and I got flashed a couple of times.
  5. Apr 25, 2019 at 9:06 PM
    raekit
    Kit
    Tustin, CA
    Did your HID’s have the same step on the left side?
  6. Apr 25, 2019 at 10:32 PM
    4runningMan
    4runningMan New Member
    What do you mean by step?
    The light should be lower on the driver's side. As you move toward passenger the pattern should rise.
