Heritage grill
Discussion in '5th Gen 4Runners (2010-2024)' started by Phil, Feb 6, 2022.
  1. Feb 6, 2022 at 12:15 PM
    Phil
    Phil [OP] New Member
    Phil
    5th gen 4runner- RED-
    Bone stock!
    Does anyone know if the 2020-2021 heritage grill parts would work on a 2018 ?
  2. Feb 6, 2022 at 3:34 PM
    san diego native
    san diego native New Member
    Kore
    Bonsall Ca 92003
    5th Gen White 4Runner
    Magnaflow Exhaust, Pedal Commander, TRD CAI, Baja Designs Squadron R Pro, N-FAB Runners 3" main tube
    I would imagine it would?
  3. Feb 6, 2022 at 3:40 PM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    You can rollback, but can't roll forward. It'll fit
  4. Feb 6, 2022 at 4:52 PM
    san diego native
    Kore
    Bonsall Ca 92003
    The newer part numbers should work on earlier 5th gen 4runners. I have done a little research and ran into this little bit here from an ebay posting
    For the newer part number:
    "Product:
    New OEM Toyota 4Runner 2nd Generation TRD Pro Black Out Grille Upgrade 2 PIECE SET (Kit to accommodate Center TSS Sensor Cover)
    Part Number:
    PZ323-35058 (Center Garnish Toyota Lettering),PZ327-35056(Upper Mesh Grille)"
    For the older part number
    Part Number: PZ323-35056 (Center Garnish Toyota Lettering),PZ327-35053(Upper Mesh Grille)
    Make/Model:
    2014-2019 Toyota 4Runner SR5 & Trail team Models Only
    Only thing that throws me off is in the new part number posting it says (Kit to accommodate Center TSS Sensor Cover)
    Can anyone say that the newer trd pro grill fits on the older 5th gen's?
  5. Feb 6, 2022 at 7:59 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    It will. The newer TSS compatible pieces have a notched out part on the bottom for the sensor. If you dont have TSS on your ride, the notch is irrelevant. It will only be visable if you were to look at an upward angle at the front end. Or if your ride decided to drive on its roof...
  6. Feb 6, 2022 at 8:07 PM
    Why wouldn't you want the heritage grille parts designed for the 2018 MY?
  7. Feb 7, 2022 at 8:47 AM
    Phil
    Phil
    Bone stock!
    The newer heritage grill parts for the 2020 and up are actually a lot cheaper than the 2015-2019
  8. Feb 7, 2022 at 8:56 AM
    Phil
    Phil
    Bone stock!
    newer heritage grill comes out to around 455 with shipping from mcgregor toyota online parts department. The older part numbers for the heritage grill came out to 585$ with shipping from mcgregor toyota online parts department. I went on ebay and compared there as well. By far the newer parts are the better deal
  9. Feb 7, 2022 at 10:24 AM
    DIRTRCR13
    Jerm
    The 405
    Or you can save $3-400 and get an aftermarket one... Tons of them out there for way less money and look just as good.
    But if you want to it to say "Genuine Toyota Part," by all means. Its your money, spend like you want too...
    Mtbpsych likes this.
  10. Feb 7, 2022 at 10:40 AM
    Phil
    Phil
    Bone stock!
    Yea there are quite a few other aftermarket options. I just cant stand see the tiny gaps on both sides of the blacked out Toyota grill part. looks find on 4runners that are black or grey. Stands out to much though with my white 4runner
    DIRTRCR13[QUOTED] likes this.
  11. Feb 7, 2022 at 4:51 PM
    DIRTRCR13
    Jerm
    The 405
    2020+ WHITE TSO PRO GRILLE 4RUNNER - TRAIL STANDARD OFFROAD
