Heritage grill for limited
Discussion in '5th Gen 4Runners (2010-2024)' started by 2019-NiteShade, Nov 26, 2022.
  1. Nov 26, 2022 at 7:53 AM
    2019-NiteShade
    2019-NiteShade [OP] New Member
    George
    Hi guys,
    Why heritage grill won't fit the Limited 4Runner? Is it because the front chrome piece? Can that chrome piece be remove?
    I really like the look of Heritage grill, but everywhere I check, it always says "will not fit Limited".
    Thank you guys
  2. Nov 26, 2022 at 8:03 AM
    I don't see why it wouldn't work, as you are only replacing the upper grille portion, and covering the middle section with a new cover. Unless the dimensions of the center section are just different. I think I've read of someone doing this, but it seems they had to do some trimming to make it work. I'm sure someone will chime in...
  3. Nov 26, 2022 at 9:13 AM
    Kezin
    Kezin New Member
    ‘21 and ‘17 Limiteds
    Chrome piece under the Toyota logo is thinner than other models. CarTrimHome makes one for the Limited. Tons of people run ones that “aren’t for Limited” just fine including my wife’s 4Runner. You just won’t be able to stick the bottom tape on
    glwood54 likes this.
