HELP. Won't start
Discussion in '3rd Gen 4Runners (1996-2002)' started by TX_twink, Sep 29, 2018.
  1. Sep 29, 2018 at 1:50 PM
    TX_twink
    TX_twink [OP] New Member
    Shawn
    2002 SR5 mildly built, 2016 Lightshade daily
    Plenty of window stickers and Pine Tree air freshner
    Drove home Wednesday after work just like every other day, no problems. Didn't try to start it again until Friday evening. Turn the key over and it sounded like the starter just jams into the flywheel and won't mesh with the teeth...tried again and the same result. Had the starter tested at two different auto stores and both times it checked out good. Re-installed starter and tried again, sounds worse this time. Battery has 12.5 volts, timing marks look good... I'm dumbfounded to say the least. Any ideas fellow Runners?? 2000 3.4 245k miles, 2wd auto
  2. Sep 30, 2018 at 8:32 PM
    akjff
    akjff New Member
    AK
    86 4runner, 91 4runner
    Fr & Rear Detroit TrueTracs, 4.56:1 R&P, ARB leafs, Poly bushings, Headers, 8500lb winch, Rooftop cargo and awning.
    see attached image from '91 toyota fsm. i assume starters still work the same in later generations and the magnetic switch controls the position of the pinion. for some reason the pinion may be prevented from full extension. what does it sound like? slam, grind, spinning motor? did the shop test the starter with a load on it?or just install a different starter.20180930_191425.jpg
  3. Oct 1, 2018 at 6:47 AM
    I would try swpping the battery out.
  4. Oct 1, 2018 at 10:50 AM
    TX_twink
    Shawn
    It sounded like the starter wasn't meshing with the flywheel. No, neither auto parts tested it under a load. I reinstalled it and it sounded worse. My next assumption was the engine wouldn't turn over. I pulled the timing cover and nothing out of the ordinary there either. Finally I used a 19mm socket to turn the engine over past the stroke it was on, about a quarter turn. Turned the key forward and it started just fine. No idea what happened or caused this but maybe I should carry that socket around from now on...It sucks not knowing if this vehicle will start every time I turn the key forward.
  5. Oct 1, 2018 at 10:50 AM
    TX_twink
    Shawn
    The battery showed 12.5 volts.
  6. Oct 1, 2018 at 2:02 PM
    Yeah, i went down that road with my 02 and changed the battery out, then no more problem.
  7. Oct 1, 2018 at 2:48 PM
    TX_twink
    Shawn
    What was the initial problem? Similar to mine?
  8. Oct 1, 2018 at 4:32 PM
    Yes sir.
    TX_twink[QUOTED][OP] likes this.
