Help with N-fab Nerf on 2011 SR5?
Discussion in '5th Gen 4Runners (2010-2024)' started by Foley777, Mar 13, 2020.
  1. Mar 13, 2020 at 10:05 PM
    Foley777
    Foley777 [OP] New Member
    I know, I know, install of N-fab Nerf bars should take less time than having a pizza delivered. And guys (and gals), I’ve used the forum search function and the Goog and YouTube- I’ve really tried before turning here for help.
    So quickly: I ordered said bars for my 2011 SR5 from a reputable eBay seller, who contacted me after the sale to verify make/model/year, great, fine. They arrive yesterday (N-fab factory box) and look great, but include no hardware (new bolts) or instructions.
    But I’ve watched install videos and figure, fine, I’ll just back out the factory screws and -if they’re in good shape- just reuse them, or if not, go buy some new ones at local big box.
    So I get under there and see a bracket of sorts at each set of screws (see below):
    Now, I haven’t seen these three brackets (on each side) in any of the install videos I’ve watched, so as one does, I start Googling/YouTubing.
    The closest thing I can find is a mention in this forum from an N-fab install thread in 2015 in which user DAGNABIT writes,
    “No spacers
    10 - 15 trail
    14 - 15 SR5, PRO
    Spacers or rocker trim
    10 - 13 SR5
    10 - 15 Limited”
    So, do I gather correctly that -given I have a 2011 SR5- those brackets are holding on rocker trim? And if so, can I... just go get some same-width but longer (backed out factory bolts aren’t long enough) bolts and bolt the nerf bars right up against those brackets? Or do I need a spacer kit if I don’t remove the rocker trim (and related brackets)?
    Thanks in advance for any suggestions or advice.
  2. Mar 14, 2020 at 6:45 AM
    There might be some helpful information in the following video, which shows the removal of the rocker trim on a limited:
    https://youtu.be/6xQ7bPfIOSw
  3. Mar 15, 2020 at 11:54 AM
    jack bauer1
    jack bauer1 New Member
    I had some N-FAb non step fake sliders for a couple months and they bolted directly to the body with existing bolts.
    Do you not have silver bolts along the underside of the body?
    I never had to remove any rocker trim.
