Help with front-end knocking diagnosis
Discussion in '5th Gen 4Runners (2010-2024)' started by bobby4runner, Nov 10, 2024.
  1. Nov 10, 2024 at 10:19 PM
    bobby4runner
    bobby4runner [OP] New Member
    Los Angeles
    2022 TRD Pro MBM
    Hey all. I'm having trouble diagnosing the root cause of a front-end knock right now. The sound is coming from the undercarriage + left and right wheel well. It doesn't occur over big bumps; it happens more under high-frequency unevenness on the road from 5-40mph.
    I've had a reputable shop retorque all suspension components, but I still can't figure it out. It happens under braking, going down parking garages, and even over thicker painted lines. However, it doesn't knock with speed bumps, driveway entrances, or big bumps. Any input would be appreciated. 2H vs. 4H didn't make a difference.
    The truck's got ~43000 miles, with the stock pro fox suspension. I don't feel it in the footrest, brake pedals, or steering wheel, just hearing the knock.
    The video shows me going over some road imperfections at around 7 mph.
    https://youtube.com/shorts/oMYULfVvuOw?feature=shared
  2. Nov 10, 2024 at 10:32 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I would check skid plate bolt torque - that was my issue. Upon other recommendations I also checked the hood latch and greased it to rule it out. May want to check that as well
  3. Nov 10, 2024 at 10:36 PM
    bobby4runner
    Los Angeles
    2022 TRD Pro MBM
    Yea I'll take a look at the hood latch, but the shop took the skid off and put it back on, so I suspect it isn't that. I'm wondering if it would be something steering rack related? Just based on how it's mounted. Weird thing is it happens on very small unevenness, I wouldn't even call it bumps.
  4. Nov 10, 2024 at 10:46 PM
    A few things to check because you never know
    When did you notice the sound? Was it after a service?
    Is your tire pressure set correctly?
    Is there anything loose is the cabin that could explain the sound?
    Open the sunroof to see if the noise goes away.
    Turn out the rubber bumpstops on the hood to preload it a bit. Note their original position so you can reset them if it’s not the problem.
    Are the wheels torqued properly?
    Do your fox shocks have the TSB for noise?
  5. Nov 10, 2024 at 11:04 PM
    bobby4runner
    Los Angeles
    2022 TRD Pro MBM
    Definitely some great ideas here I’ll check for tmr. Could you talk a little more about the TSB for fox shock noise?
  6. Nov 11, 2024 at 4:05 PM
    Did you add recovery points to the front? I kept hearing noise drove me crazy. Ended up being the shackles bouncing around
    McSpazatron likes this.
  7. Nov 11, 2024 at 6:06 PM
    bobby4runner
    Los Angeles
    2022 TRD Pro MBM
    It looks like the truck had the pre 2021 PRO shocks on it for some reason (even though mines a 2022), and that’s what’s making the clunking noise. I’m going to call up my dealer to see if they can get it replaced under the TSB.
    I suspect the previous owner took the sold the stock shocks and when it came time to sell just bought the cheapest set from fb.
  8. Nov 12, 2024 at 2:55 PM
    Glad you found the culprit!
  9. Dec 9, 2024 at 7:24 PM
    bobby4runner
    Los Angeles
    2022 TRD Pro MBM
    SOLVED: I hope this can help others in the future.
    The culprit is the front OEM TRD Pro FOX shock absorbers (PTR89210, found on MY21 and MY22 Pros). Took the car to the dealer and told them about the issue, took the tech on a test drive, and showed him and the service advisor TSB-0094-20. They agreed my issue was the same as the one described in the TSB. Unfortunately, the TSB didn't cover MY21 and onwards (I have a MY22). Luckily, my car is a CPO and the warranty took care of it, otherwise it would've been $3k+ out of pocket. The dealer replaced them with PTR89240 (found on MY24 Pros), and the knock is completely gone.
  10. Dec 9, 2024 at 9:39 PM
    Good deal!
