Help please
Discussion in '2nd Gen Builds (1990-1995)' started by 4Runner416, May 24, 2025 at 11:23 PM.
  1. May 24, 2025 at 11:23 PM
    4Runner416
    4Runner416 [OP] New Member
    Saturday
    Bryan
    2002 forerunner SR5
    Stinger bumper, LED lights all around
    I have a 2002 forerunner I changed the transmission support and the Front and rear you joint Still getting some vibration What could it be?
  2. May 25, 2025 at 3:39 AM
  3. May 25, 2025 at 3:47 AM
    Welcome from Wisconsin! Did you install a lift of some type? Incorrect pinion/driveshaft angle, I'm not sure if Toyota uses weights on the driveshaft, like maybe one of them is missing, that's if they even use weights. Trans./transfer case output shaft faulty bearing, but then you might see seepage from a worn/bad seal.
    4Runner416[OP] and BS67 like this.
  4. May 25, 2025 at 3:54 AM
  5. May 25, 2025 at 5:59 AM
    4Runner416
    Saturday
    Bryan
    2002 forerunner SR5
    Yes it has some weights I marked the driveshaft position before I removed it there’s no fluid leaking anywhere so I don’t think it’s a seal from the transfer case I’ll check the bearing thank you
    Toy4X4 likes this.
  6. May 25, 2025 at 6:15 AM
