Help new guy here....
Discussion in '6th Gen 4Runners (2025+)' started by Speakerhouse, Apr 22, 2026.
  1. Apr 22, 2026 at 8:16 PM
    Speakerhouse
    Speakerhouse [OP] New Member
    PJ
    6th gen 4runner trd sport
    I have a 25 sport. I bought new wheels. 22x10 with 33s 12.5..... DO I NEED a lift? I didnt think I did according to a few videos I have. Pics attached. Ty
  2. Apr 23, 2026 at 2:40 AM
    Welcome from Wisconsin! Put them on, drive around forward and reverse, steer lock to lock while driving (abandoned parking lot works well for this) if they rub, you might need a lift, you don't know unless you try.
  3. Apr 23, 2026 at 3:26 AM
    Brian
    Speakerhouse[OP] likes this.
  4. Apr 23, 2026 at 5:12 AM
    Whammo
    Whammo New Member
    Southern New England
    24 Ice Cap TRDORP 4Runner
  5. Apr 23, 2026 at 5:13 AM
  6. Apr 23, 2026 at 5:48 AM
    L
    20 Venture/17 Taco
    Welcome. What offset are the wheels?
  7. Apr 23, 2026 at 6:35 AM
    We dont know
    We dont know because nobody has done it
    Why has nobody done it?
    Because the vehicle is new and your offset is questionable. The few people who have put tires and wheels on 6th gens have stayed within the realm of OEM offset and run larger tires that fit INSIDE the wheel wells. What you have is going to sit well outside the wheel well and outside the fender flare as well i would suspect. This brings on a whole slew of changes in how the tire "swings" when you turn. You are most likely going to be the first to do this particular combo and you are going to have to let us know how it goes. Then we will know.
  8. Apr 23, 2026 at 6:36 AM
    ALL the offset
    Visually, those appear to put the outer lip of the wheel about 5-6 inches further out than the OEM wheel. Gonna have a whole lotta poke.
  9. Apr 23, 2026 at 6:58 AM
    Good luck with that.
    das goot and 5thToy like this.
  10. Apr 23, 2026 at 7:27 AM
    OregonTrail
    OregonTrail New Member
    Jennings Lodge, Oregon
    2011 Silver 4Runner Trail Edition
    Dobinsons IMS & Dobinsons coils with 1.5" lift front, 1/2" lift back
    Did you ever think to ask that question before you bought the wheels/tires:cheers:
    Put them on and post a picture, should be awesome!!
    ToyotaDude99, 5thToy and Blufin like this.
  11. Apr 23, 2026 at 10:36 AM
    4Hopper
    4Hopper New Member
    24 Ice Cap 4R TRDOR Prem
    Gen6 is still so all-new that you’re mostly asking a bunch of Gen5 owners, so, greetings from the time of the BlackBerry!
    Have some fun, experiment on your own, and you tell us. Good luck, and congrats!
  12. Apr 23, 2026 at 12:08 PM
    EnsightAuto
    EnsightAuto New Member
    Really depends on the offset of the wheels. The front is where the issue will materialize first. Try installing the wheels on the front and fully crank your steering wheel in both directions while vehicle is on a lift or jacks, if there is full clearance, then put vehicle on the ground and do the same thing. Make sure there is clearance while steering is fully cranked, if so you're good to go!
    Speakerhouse[OP] and Toy4X4 like this.
  13. Apr 23, 2026 at 12:36 PM
    Install them and let us know wtf kinda post is this
    Where was your brain ?
    Toy4X4 and OregonTrail like this.
  14. Apr 23, 2026 at 1:29 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Install them and drive until the rubbing stops! :D
    Toy4X4 and 2016SR5P like this.
  15. Apr 23, 2026 at 3:28 PM
    Even the dog looks skeptical about those wheels and tires...he's like WTF?
  16. Apr 23, 2026 at 6:47 PM
    Smart dog.
    CalcityRenegade and NB4x4 like this.
  17. Apr 23, 2026 at 7:14 PM
    L
    20 Venture/17 Taco
  18. Apr 23, 2026 at 7:38 PM
    OregonTrail
    Granted I'm somewhat new to the forum but it does seem like there are a lot of BOTS that seem to post bullshit questions here?? Is that usual and doe anyone monitor it??
    Toy4X4 likes this.
  19. Apr 23, 2026 at 7:53 PM
    I agree. There are a lot of “new” members that post about weird problems and questions then disappear. I assume many are bots or trolls.
    CalcityRenegade and ToyotaDude99 like this.
  20. Apr 23, 2026 at 8:39 PM
    ToyotaDude99
    ToyotaDude99 Obsessed with 4Runners... And anything Toyota
    The Moon
    1995 4Runner
    Just stop engaging in other peoples problems (threads) and then don't even have to worry about it. Wait... stupid advice. If everyone ignores everyone's posts, this would be a forum filled with a LOT of unanswered topics/questions! :D
    Rocket-67 likes this.
  21. Apr 24, 2026 at 3:04 AM
    Yes, ^.. some of these questions are from waaaay out.
    ToyotaDude99 likes this.
  22. Apr 24, 2026 at 10:58 AM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Let’s pretend for a moment that you didn’t make a post lacking the pertinent technical information needed for us to assist you.
    Lift does not decrease the amount of rubbing you’ll experience on a vehicle with IFS. Wheel offset is going to be a major factor in how much rubbing you experience.
    Operating under the assumption that the 6th gen is comparable to the 5th gen, most people upgrade to “285s” (32.7" x 11.2"). When paired with 0 offset wheels, this setup results in minimal rubbing compared to other setups.
    I have 285/70R17s with a +5 offset and no lift, and I had to remove my front mud flaps and trim a little bit of the bumper/fender flare. The tires you have are a bit taller and quite a bit wider. If your offset is negative, you’re going to experience even more rubbing.
    Aggressive negative offset is where most people run into trouble. I would put the tires on and turn them back and forth to see where and how much rubbing occurs.
    Then you can decide how much you’re willing to remove to reduce or eliminate rubbing. Just remember, you can run whatever size you want if you own a Sawzall! :cheers:
  23. Apr 24, 2026 at 11:44 AM
    ToyotaDude99
    The Moon
    1995 4Runner
    @CalcityRenegade nice Lime Rush 4Runner! Next time I'm in Calgary I'll keep my eyes out for you! :D
  24. May 6, 2026 at 3:37 PM
    Speakerhouse
    PJ
    Oh . Ill keep ya posted. I didnt even know how to get back here. 3.5 inch lift being installed next week. Ill share. I haven't seen Many street 6th gen builds. Sorry for the ignorance. And thanks for the jerks doing what they do best. It gets me fired up.
    ChessGuy and ToyotaDude99 like this.
  25. May 6, 2026 at 4:00 PM
    Speakerhouse
    PJ
    AI can't recognize the 6th gen body yet..... but I do belive the stance seems right with 3.5 inch lift.
  26. May 6, 2026 at 4:14 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    With a 3.5in lift your going to have to do a diff drop
  27. May 6, 2026 at 7:18 PM
    OregonTrail
    :bowdown:
  28. May 7, 2026 at 9:18 AM
    Did you try mounting the tires before ordering the lift?
